3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Minty LED Tester
Minty LED Tester
Stop fumbling around for a 3V battery, build your own LED tester, and freshen your breath while you are at it!
Let's get started.
Step 1Materials
Materials
You will need:
16 comments
Nov 27, 2010. 10:30 AMJ-Five says:
That's very Ingenious!
Jul 2, 2010. 9:13 PMiamseer says:
cool idea. But the problem is some red and IR led works on 1.5V or 1.2V. That means the 3V cell may given them a sudden death because of the large current. But a single resistor will solve the problem. I think hundreds ohms will do.
Jul 3, 2010. 12:11 AMzack247 says:
maybe, but most red and ir leds are 3.6v ones, so you should be safe.
Jul 3, 2010. 12:50 AMiamseer says:
May be the leds you find is more than one in serial. The longer the wavelength, the lower voltage the led needs. Of course the leds from different manufacture may work at a slightly different voltage. But the error can hardly exceed 20%. http://en.wikipedia.org/wiki/Light-emitting_diode#Colors_and_materials
Jul 5, 2010. 7:58 AMGoodhart says:
Since there is so much extra space in the tin, one could set up 2-3 sockets and have different resistor values on each to provide lower current to the other sockets....then you could "start" at the lower end and if it doesn't light move up to the next higher level until the LED lights or is proven defective.
Jul 22, 2010. 11:08 PMmxc1090 says:
Same current...lower voltage. 1.8 - 2.0 for Red/Orange 3.0 -3.2 for Blue/UV/Green
Jul 23, 2010. 11:16 AMGoodhart says:
Hmm, then in stead of current limiting resistors, one could set up "voltage dividers".
Jul 23, 2010. 1:25 PMmxc1090 says:
Correct.... So lets say you have a perfect 12V source. If you would like to achieve 3V across one resistor and 1.8V across another @ .025A (25mA) you would do something like this: V=IR 12V=(.025A)(R) Total resistance of the circuit = R = 480 ohms To achieve 3 V across one of the resistor the value of the resistor must be: R1=3V / .025A R1= 120 ohms To achieve 1.8 V across one of the resistor the value of the resistor must be: R2=1.8V / .025A R2= 72 ohms Total R must equal 480 so.... 480 = 120 + 72 + r So the value of 'r' (the last of the 3 resistors in this circuit) = r = 288 ohms then you make it so when your plug in an LED the current will bypass the resistor and flow through the LED and it would have no affect on the rest of the circuit. (Make sure you know the Amperage of the LED, it is vital to the circuit)
Jul 5, 2010. 7:59 AMGoodhart says:
Oooo, I see LOTS of potential with this one :-)
cool! i need one of these.
Jul 5, 2010. 1:31 AMzombiefire says:
email me at bored19@hotmail.com.au thanks
Jul 3, 2010. 8:46 AMzack247 says:
thats ok, making stuff is a lot more fun
Jul 4, 2010. 3:08 AMmeh301 says:
Great! A small project where I can finally recycle almost useless coin cell batery holders!
Jul 3, 2010. 12:49 AMAndyGadget says:
Would there be room in there to add a 2nd battery and a resistor (270R or so)? If so, it would be a lot safer for the LEDs.
The 'voltage' of a LED isn't the voltage it's designed to run on, it's the voltage 'lost' inside the LED.  A typical red LED has a drop of 1.8V so the current through it from the 3V battery could possibly kill it.  A bit more info on LED voltage drops HERE.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:Brennn10
Brennn10 is now at college studying Electrical Engineering. He is also currently researching nanotechnology applications for solar cells.
