3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modular Wood Structure
In this instructable i'll show how to create simple or complex modular wood structure.
This method is used by professional carpenter but you can do it by yourself, with simple steps.
This is what you need:
- Drill
- Clamp
- Drill tip
- Bolt and screwed nuts (see in photo)
- Meter
- Pencil
- Allen key
- Wood (your pieces for your structure)
You can find all of these parts at the local hardware store.
Step 1Step 1
Step 1
Take a piece of wood, note that the depth must be enough to insert the screwed nut, for example if you take screwed nuts of 9mm diameter, the minimum depth can be something like 12mm.
2 comments
Jul 13, 2009. 2:20 PMjdege says:
How did you get the holes in step 4 to line up with the holes you drilled in step 2? I've never been able to do that without using a dowel center, but you don't mention how you got everything to line up so cleanly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:simohack
