For the mojito recipe I designed it on Photoshop and then I reverted the image in order to write it on the good position on the plexiglass.
It is pretty cheap DIY and it is a low comsuption energy system because you can use 2x 1,5v battery or 3x 1,2v battery.
Remove these ads by
Signing UpStep 1Print your model
To engrave it I used a dremel with a small peak.
The plexiglass is a 0,5mm thick.
It is important to have the same led serie which work on the same voltage.
Hope it helps :)
Thanks and much appreciated.
But if you try a simpliest model! I did an other one in 10minutes
