Theory
The basic theory behind the shot is simple: leave the camera shutter open for a long time but block the lens most of the time. So, what we need is something that blocks out the light, is easy to open and close, and introduces a little vibration as possible. Once the light blocker is in place, we start the shot and open the light blocker at regular intervals.
This instructable consists of two distinct sections. The first section deals with creating the light blocker. The second deals with taking the shot.
Equipment
Here's a list of what you'll need:
- filter holder compatible with Cokin P Series filters
- Square filters lens hood for Cokin P Series holder
- Adapter ring (one for each lens you want to use it with
- Black nylon cloth (minimum size 16"x16" or 8"x32"; recommended size 20"x20" or 10"x40")
- 2 Magnets
- Square food container (bottom should be about 5"x5"), no lid necessary
- Plasti Dip spray
- Glue gun and several glue sticks
- Wax paper
- Old newspaper, a drop cloth, or something to protect your floors
- Scissors
- DSLR camera with full manual control
- Camera remote control or Remote Shutter Release Cable
- Tripod
- extra camera battery (optional but highly recommended)
Equipment Notes
- For filter holders, there's also an "A" Series but there doesn't seem to be a hood for it.
- The minimum cloth size requires some precision when gluing the cloth to the filter holder. The recommended size will be easier to glue (you don't need to be as precise) and will require additional trimming.
- I used nylon cloth because it's strong and lightweight. Nylon is also less absorbent than some other cloth types, which is a bonus in this case.
- Use medium strength magnets - avoid the neodymium magnets. The magnets should be strong enough hold a bit of weight but weak enough that they pull apart easily. If they're too strong, you'll introduce too much vibration and may actually pull the camera out of position.
- The Plasti Dip spray will be used to make help block out the light and cut reflection. The spray version is easier to apply than the dip version so try to get that. (Check the Plasti Dip site http://www.plastidip.com/diy_where_to_buy.php for where you can find the spray.)
- Use as sturdy/heavy a tripod as possible. This will reduce the chances of the camera moving out of position.
Additional Note
In theory, you may be able to do this by keeping the lens cap on for most of the shot. The main problem with relying on the lens cap comes when removing and reattaching the lens cap. Taking the lens cap off will cause the camera to shake, which may cause a blurry shot and/or the camera moving out of position. If you pause with the lens cap in front of lens after taking it off (to let the camera stop moving), a lot of light may come in from the sides or reflect off the lens cap interior and ruin the shot.
Remove these ads by
Signing UpStep 1Preparing the Cloth and Container
For this step, we'll need the following:
- Black nylon cloth
- Plasti Dip spray
- Wax paper
Pick a well ventilated area to work in, as the fumes from the Plasti Dip are harmful. Lay down the newspaper to protect the floor. Next, lay out sheets of the wax paper. The cloth and food container will sit on the wax paper rather than directly on the newspaper. The wax paper is less likely to stick. Put the food container on the wax paper, open side up. Spray the interior bottom with the Plasti Dip. Don't worry that you can still see through it. You'll need several coats. Once sprayed, flip the container over. Prop up at least one side of the container so that air can flow to the inside of the container. Spray the outside bottom of the container. Set aside to let dry. Once dry, repeat the spraying one or two more times.
While the container is drying, work on the cloth. If desired, fold the cloth in half (so the area is 8"x16" if using the minimum size) and iron the edge. This is to make it easier to fold. Put the cloth (unfolded on top of the wax paper. Spray one half generously with the Plasti Dip. Fold the other half on top of the sprayed portion. Place a layer of wax paper on top and press down to ensure there are no air bubbles. Place a weight on the folded edge (I used the wax paper dispenser). Let dry. After at least 15 minutes, remove the weight from the folded edge. Also remove the top layer of wax paper. This is to increase air flow and help the cloth dry. Wait until dry.
The instructions on the can say it takes 30 minutes to dry. For the cloth and the final coat for the food container, it's best to wait longer, possibly even a couple hours, just to make sure it's completely dry.
Be sure to remember the moon moves from the east to the west and either up rising or down setting so you have to frame the shot first before you take your first shot then all will go well. Yea sure and if you believe that there is a bridge for sale in New York City. LOL
Ray
Moonrise is definitely much more of a guessing game, as you suggest. The best advice there would be to do it over a span of two days. The first day, set up and take normal photos so you have an idea of where the moon is rising, the brightness, and the framing you want to use. The second day, return to the same spot and set up according to the settings that worked best the previous day. Note that there will be some differences - moon brightness, moonrise time, and location the moon rises at. The differences (except moonrise time) should be minor, though. The weather must also be ideal - clear both days - for this to work. Much more difficult than moonset but not impossible.
1. You have to solve the shutter release problem. Every brand film or digital, will be different.
2. You must have a sturdy tripod
3. You must decide on the duration of the Pause between pictures 5min-10min
4. set up your camera on the tripod.with camera on (F/8) or so
5. Release the shutter for 2 to 5 sec and place the BB cap, black hat, black cotton cloth dark rag etc. Start your count down for the next shot in the series.
6 When that time is reached gently remove the covering (You do not have to worry about movement until you expose the film or Digital sensor. When you are ready for the countdown to start move the hat or cloth from infront of the lens and give it your predetermined exposure and cover the lense when it is over.
7. Repeat as necessary until you have all of the exposures you want.
8. When you are starting off remember a couple things.
A. The moon travels (rather quickly) across the plane of the camera lens
B. On the first try do not use max telephoto, leave it wide angle so you can get several shots off.
C. I have found this to work much better if I use Manuel and set all of the parameters by hand. FOCUS, F-STOP and of course your hat will be the shutter......LOL
D. This also works well with black and white
Take lots of great shots and let me hear back
Ray
In my first use of the light blocker, I had a road behind me and I would occasionally get the headlights shining directly on the back of the camera. If I had used a hat, some of the light may have lit up the inside of the hat, ruining the shot. (There was light cloud so the shot didn't look as good as the one I used.) The second use came the following day. (The moonset photo I used was from this session.) I was in a different location for the second attempt and had some street lights behind me. There may have been enough light that a hat or cloth may not have been sufficient to block out the light.
That being said, if you can find a place where lights coming from the rear are not a worry, then your suggestion of using a cap, hat, or cloth is definitely simpler and cheaper.
I only wonder the advantage of such a contraption to a simple time-lapse system ?…
Of course, you can do it the traditional way - take numerous shots and combine them using Photoshop (or similar software). Of course, it's no longer a single photo - it's a composite image. The benefits of doing the multi-shot method is that you can take numerous shots for each frame and choose the best, resulting in well focused images throughout. With the light blocker method, it's a lot riskier, as one bad image can ruin the shot.
If you want to enter competitions that don't allow composites or major photo manipulations, this system will let you get the same effect but in a single shot. Other than that, it's mostly either personal reasons for doing it in a single shot or for bragging rights.
Maybe I should have shut my big mouth.
Thank you all the same as it really highlights many aspects of the question I was totally unaware of.
However, making it fully detachable is a good idea.
