For now, let's content ourselves with just a parabolic solar concentrator.
Before we begin, it is important to know that concentrated solar energy is very dangerous. Reasonable precautions should be taken. I cannot take responsibility for individual choices you make in the design, construction, modification, or use of this project. Have fun and be safe.
Remove these ads by
Signing UpStep 1Obtain parts
1) About 17 aluminum angle stock rods 5/8 inches (or thereabouts). An aluminum siding store will probably have this much cheaper than your corner hardware store. They're friendly folks, usually.
3) Some chrome-plated aluminum sheeting. Again, an aluminum siding store will usually provide this. You may have to special-order it. I ordered it under the name "light sheet". I am not sure if it was a brand name or a description. You will need approximately 40 square feet of it and ask them to cut it into 6 inch square mirrors. They will try to talk you out of it and think you're crazy for asking them to. They will also charge you for the cutting service. Let them. They deserve to make an honest living, but ask them to be careful in cutting it into _exactly_ 6 inch squares.
4) About 300 machine screws, 500 machine nuts and about 500 large washers. I used 3 inch screws in a 10-32 pitch. 10-24 is sometimes cheaper. It doesn't really matter, but be consistent. 10-32 and 10-24 look just alike and with so many of them, you won't want to waste time sorting them.
5) A screwdriver, drill, wrench, and ruler that will measure inches and millimeters.
6) Various other common household tools.
7) Some creativity and basic high-school level geometry.
For the heat-exchanger (if you choose to build it)
8) A length of 1/2 inch copper pipe and about 20 "T" junctions, some end caps, solder, propane torch, gloves, a little soldering know-how.
If the absorber surface temperature stays low - like at or below the boiling point of water - it does not need to be a selective absorber as boiling hot objects do not radiate much infrared energy. On the other hand, selective absorbers do not absorb infrared energy as well as non-selective absorbers do. Since sunlight at the surface of the earth has about 40%-45% of the thermal energy in the infrared range, you typically want a normal absorber like carbon black.
If you are dealing with temperatures close to the boiling point of water you have many choices for paint, but if you need really high temperature paint, try Pyromark High Temperature Paint. It is available in 800, 1200 and 2000 degree F ratings.
One of the inefficiencies of heat transfer is the temperature drop across the thickness of the metal barrier; another is mixing the fluid enough to bring all of it in contact with the hot media. I feel that the best, most efficient way to solar heat water, especially with concentrator mirrors, is to place the absorber in the water. That is, pump the water in transparent tubes into the absorber surface at the focal point. One excellent media is an open-cell black ceramic sponge (looks like an aquarium aerator stone); another is to put a very concentrated (stable) black dye in the water. (maybe use both techniques?)
I would add to the absorber discussion that the emissivity values are for thermal radiation and emissivity varies with both frequency and temperature. For solar power from most reflective concentrators, the majority of radiation is visible, not thermal. So glass is a great transmitter of visible radiation but very poor for thermal radiation. A glass mirror that looks shiny bright in the visible range looks almost completely black when viewed (with a thermal imager) in the thermal range. For concentrators that use glass mirror reflectors, nearly 99% of the reflected power is in the visible frequency range because the mirrors absorb most of the thermal radiation. However, this design uses metal reflectors and these are efficient in both visible and thermal bands. Ideally, the translucent material should transmit both visible and thermal frequencies. In addition, the receiving face of the translucent material should be flat and normal to the incoming beam. One possible solution would be to use a multichannel polycarbonate panel used for greenhouse walls. The polycarbonate has excellent visible and thermal transmission. Its important to get the window-grade polycarbonate.
2. Cover up all the reflectors EXCEPT the reference panel and the adjustment panel.
3. Adjust the screws on the adjustment panel so that the light of its beam center coincides with the beam center cast by the reference panel.
4. Once both beams are aligned, cover the panel adjusted and move on to the next panel, removing its cover.
5. Repeat steps 2 to 4 until all panels are aligned.
Reasoning: since the light of the reference panel moves as the sun tracks across the sky, adjusting all the other panels to it create a focus that is referenced to both reference panel focus and sun angle. Since the reference panel points to target, the entire frame can be moved to track sun. All other panels will always point to reference panel beam focus. Use of reference panel allows alignment procedure to no longer require an adjustment for sun movement.
I had the same idea using the garage floor to level the mirrored reflector so it is pointing exactly strait up.
I wanted to use pulleys , small steel cables and electrical metallic conduit for the frame.
Think etcha-sketch toy for kids.
I could then move the laser pointer around via 2 knobs in an Y and X coordinate type of arrangement.
You could then aim each of the small mirrors individually on the face of the dish at the exact focus point.
I even bought one of those party fog machine kits which will help find the laser light beam when I can't see it.
I have a project in the works that uses 7 of the old C-band satellite TVRO dishes.
I want to recycle the dishes and heat my house with the collected heat .
4 of them are 8 feet in diameter and 3 of them are 10 feet in diameter.
That is why I need a more rigid system to aim them with before I install them.
The nice thing is that I can do this inside the garage where the weather or sun is not a factor.
That's a lot of power at your command. Remember to use you power for good.
Hey Mech, let me(us) know how it woks out, OK?
I laid a sheet of black rubber roofing membrane that was about 1.15mm or .045inches thick on a bright sunny day .
It got soooo hot beneath the rubber sheet that it literally killed everything that was growing in the soil at that time even the weeds and thistles.
I had to reseed my grass lawn to get it green again .
Depending on how long it is left on the soil and how hot it got ,it might make a very worthwhile weed control system.
I should do another experiment like this again and this time install some temperature probes at different depths in the soil beneath the black rubber sheet like right on the surface and then every 1mm or so and record the results.
I believe to be effective ,the heat needs to get down to about 3 inches or 7-8mm in depth to kill all spores ,roots ,nodes etc.
Again you would have to rely on the sun for the heat but it would be very clean as there would not be any chemicals involved .
The rubber sheet could be moved in the mornings or evenings to a new location once it cools enough to hold onto .
I then realized the wall I installed it on faces more east than I initially thought and is not heating enough to be of use. Could I just put 2 long mirrors on the north side of the heater to curve around and reflect the light in? How do I figure out what angles to put them? I appreciate your help.
http://www.cerebralmeltdown.com/projects/suntrackprogram/default.htm
It works by first calculating the position of the sun and then sending signals out through the parallel port for controlling stepper motors.
I wrote the program for controlling my heliostats, so there are some features that you won't need. Otherwise though, it should work fine for something like this. Just choose "Point at Sun," and the program will track the sun instead of reflecting it to a single target like with a heliostat.
I added the sun tracking feature to this program because I noticed that there are a lot of people who were building solar concentrators and getting stuck on the tracking.
I would really like to build one of these myself someday, but I don't have the time right now. Hopefully, my program will be of use to somebody so that they can more easily build their own. That way, I can live precariously through them. :)
Awesome instructable by the way. I'll have to keep that chrome-plated aluminum sheeting in mind for my future projects.
The other pretty cool thing about the dish in question is that it is shaped to only use part of the parabolic shape, This means that although the dish rotates to track the sun, the focus point stays static, therefore there is no need to have an arm with a collector!!
I have seen the dish on a documentary, and it is being manufactured with simple tools at low costin 3rd world countries. Cant find the original site, but this one http://www.inforse.org/asia/M_III_solarcook.htm has the dish, with (small) diagrams of the dish focus point stuff. Scroll down a bit :)
http://www.instructables.com/id/Tracking-parabolic-Barbecue-the-wave-of-the-futur
is a video of mine. I bring it up because it has a different way of attaching the array to the equatorial mount than the way it is done in community solar cookers.
In community solar cookers the dish gets deformed through the year to keep it correctly aligned.
(I believe the way I suggest is much simpler)
Perhaps you could adapt your array of mirrors to work with this method? Brian
