Mini Charcoal Furnace.
In this instructable I will explain how I made my second bigger foundry yet again mostly constructed from scrap I collected and recycled it into something more usefull.
The biggest advantage of this design is that it has a very strong body made from an empty gas cylinder and the best part is that it will last for a long time, the only thing that might have to be changed or repaired is the inside refractory.
As I wrote on my last ible my aim is to create some aluminium sand casting of differrent objects.
At this stage I piled my aluminum ingots and did a few experiments with my foundry, some successful others went wrong which I have learned from. It is really exciting to create some new aluminium object knowing what it was in its former "life" cycle.
I will also try and explain a little bit about sand casting to my knowledge.
I am no expert it is all based on my hobby experience so I hope you enjoy it.
_____________________________________________________________________
A few Saftey words: Coming into contact with fire and boiling melted metal can be very dangerous so always work safe using proper full body protection including respirator mask against toxic fumes and dust from mixing refractory materials. Never melt in a wet area or near water, if water comes into contact with the boiling aluminium it might "blow" in your direction.
The info in this instructable is based on my experience.
I disclaim any responsibility for any resulting damage, injury, or expense.
All use by you of this website is at your own risk, work safe.
Remove these ads by
Signing UpStep 1Cutting the gas Cylinder
When using a grinder it is recommended you wear eye and ears protection.
If you dont know what you are doing take it to a professional. Mis-use of pressured gas cylinders can cause injury and even fatalities.
This not an instruction or a guide how to do it, I am sharing with you how I used a gas cylinder based on my own experience and knowledge.
Anyone who attempts this he/she will do it on their own risk
I will not be liable for any injuries in anyway.
One thing I would recommend though is that you modify it a bit and put a propane burner in instead. Much easier than charcoal, and you have a more controllable heat. From the looks of yours, all you would have to do is insert a propane line into the blower pipe, and you're pretty much there. You would just need to add a flame holder, but that's fairly simple.
Very well done!
How long is the inlet pipe ?
Is the length critical ?
Is the flange important ?
Great job.....Roger
How well Is your refractory holding up? How many times have you fired it?
I repaired the oldest one and we are restoring it but he tore the rest apart for the pistons and such that he uses to make statues.
The rest of the mowers were set to be thrown out but I grabbed a large amount of aluminium pieces. Just testing my furnace i threw a chunk in and it melted beautifully and was quite strong when I later pulled it out.
I recommend saving them and smashing the cast base into smaller pieces as well as the tougher engine pieces.
you might find this interesting. It's a link to a catalog website that has all sorts of antiquated methods for making things at home. pretty interesting. This page particularly deals with a book that you can order that shows you how to make a crucible.
http://www.lindsaybks.com/dgjp/djgbk/cruc/index.html
I have a question if I may? Do you have any problems with the surface of your castings? I need to make some aluminium moulds (for pouring molten lead into for fishing weights) but they really have to be nice and smooth. Any ideas how I can achieve this?
Take care.
Kevan
You are welcomed to visit my blog I have a few projects using sand casting. I believe you can get very good results using this type of sand and you can make a mould for many fishing weights in one pour.
Just one thing and this is up to you to decide, I wouldn't melt any lead at all, Lead is a poisonous metal and can cause serious health problems especially among children. Link:
Lead health effects
If you have any questions I will be happy to answer thanks again.
Anyway, Petrobond sand. Any idea what makes it special as opposed to ordinary sand. It sounds like a trade name and it's not one that I know of here in the UK. I was thinking of using what we call silver sand. This is a very fine and very clean sand that is used for children's sand (play) pits. It has to be fine, soft and ultra clean because of this. I'll add fuller's earth clay to this to create my moulding sand but don't yet know in what quantities.
Lead. Yep, nasty stuff but then so is aluminium fumes. Lead casting is quite common still over here in the UK and I will only be doing it outside. There are still an awful lot of houses that have lead water pipes ours included. Having once been a plumbing and heating engineer I can tell everybody that the danger from lead is real but very much overstated. It's bad if you ingest it in anyway and that does indeed include fumes, hence my proposing to cast the weights out of doors, it's safest that way.
Thank you for the health warning though it is appreciated :)
Take care.
Kevan
Thank you and take care.
Kevan
Another simple option is using card board or plastic cylinder to form the inlet hole, after refractory is set take the cylinder out.
In my image I drew blue line that represent metal angle brackets and the red dots arepresent metal screws.
Hope this will be useful to you.
DANGER:
Cadmium is extremely toxic even in low concentrations. The fumes given off by zinc is toxic also when heated.
Lots of materials around that we need to be careful we don't breath the fumes it makes when we are heating it.
Once it is burned off, you are probably okay. Just remember to not breath any of the white smoke/fumes. They are toxic/poison. If they never get heated hot enough to smoke/cause fumes, there shouldn't be any problems from using cad plated parts.
Great instructable!
Ken
102410 2029
Is there any way to know when melting coated object if the paint contains cadmium?
Or the best thing is just to melt clean parts such as car pistons act' ?
Second, what are you using as a mold for the ingots? They're all a nice standard size and very professional.
Third, this is awesome.
As for the ingots, I am using metal muffin tray (not teflon). All you have to do is pour the molten metal into it and you get a nice aluminum muffin. You can also make a container for the ingots DIY style like the one I welded from metal angles. I am using it to make slim ingots for my pipe cruicble.
Thank you.
A professional iron worker once told me that cast iron cookware works well for a crucible. There are a variety of pans, pots, "dutch ovens" and other styles to choose from. Maybe there are cast iron muffin pans waiting to be found at a junk sale.
DIY-Guy
I have had few issues with smoke, and I use charcoal. Just start your furnace like you would your grill and give the coals a few minutes to really be hot, then turn your air on, and it will blow the fire out for a few seconds... THEN BOOM! It cuts on and sounds like a small rocket engine, and there is NO smoke.
I did have issues with smoke when I used painted aluminum, or impure aluminum. Be careful with that, and use a higher quality, like cracked engines, transmissions, etc... SODA CANS ARE THE WORST! Try and avoid them as much as you can.
Manifolds, cylinder heads, blocks, internal engine parts etc are made from aluminum alloys. (as is nearly every piece of aluminum you might encounter*)And they vary drastically in composition and purity of aluminum.
319.0 Alloy composed of (in weight percentage) 90.50% Aluminum (Al), 3.50% Copper (Cu), and 6.00% Silicon (Si) and is used in manufacturing Manifolds, cylinder heads, blocks, and internal engine parts.
332.0 Alloy which contains silicone (for high temp applications) and several manufacturers are adding ceramic fibers for more tinsel strength is used for Pistons
356.0 Alloy 91.13 % Aluminum (Al),0.25 % Copper (Cu), 7.00 % Silicon (Si) 0.32% Magnesium (Mg) 0.35 % Manganese (Mn) 0.35 % Zinc and 0.6 % Iron (Fe)
Cylinder heads, manifolds are often made from this.
A380.0 Alloy 86.70 % Aluminum (Al),3.50 % Copper (Cu), 8.50 % Silicon (Si) and 1.30% Iron (Fe) is often used for Blocks, transmission housings/parts, fuel metering devices
383.0 Alloy 87.00% Aluminum (Al), 2.50% Copper (Cu), and 10.50% Silicon (Si). Brackets, housings, internal engine parts, and steering gears are often made with this alloy.
B390.0 Aluminum-Silicon Cast Alloy: 73.45 % - 75.45 % Aluminum 16.0 % - 18 % Silicon (Si) 4.0 % - 5.0 % Copper (Cu) 1.5 % Zinc (Zn) 1.3 % Iron (Fe) 0.50 %Magnesium (Mg) 0.50 % Manganese (Mn) 0.10 % Titanium (Ti) and 0.10 % Nickel (Ni)
Ring gears, die cast valve bodies, compressor housings in pistons, and internal transmission parts are often comprised of this alloy.
As for just grabbing "aluminum" scrap from an engine or elsewhere and melting it and expecting to get pure aluminum ingots, with the exception of aluminum beverage cans, it is not going to be pure and could be far from it...
Aluminum soda and beer cans however are extremely pure, close to 100% I believe some aluminum can smelters guarantee 99.9% pure by weght. It is also the only way a consumer is usually exposed to a pure* aluminum product, everything else is an alloy.
*Pure aluminum is entirely to soft to be practical in applications other than beverage cans.
FWIW, I do a little aluminium casting too, I use alloy car rims as my base material, they're easy to come by for little or no money and it casts beautifully.
Hope it helps someone.
You make a good point, pure aluminum is crappy. I use 2160 when I do my castings when using pure aluminum, and I use ZAl23 when I am not. The alloy melts lower, faster, pours better, and is stronger in all senses. (If behaves about like cast Iron) It is also a hell of a lot safer at only 900F.
Guess that means it is a good idea to go with the pro's and switch from pure aluminum to a good alloy suited to your needs.
The impurities in cans by the way are the printed labels. They smoke like hell and leave a LOT of slag. I have NEVER had a good melt with aluminum cans. They are crap.
