Before we look at preparing the Arduino/Freeduino microcontroller for connection to the nixie tube driver modules described in Part I and Part II, you can build this power supply to provide the high firing voltage required by the nixie tubes. This switch mode power supply easily outputs 50 mA, which is more than most, and offers a variable output from 150 to 220 VDC, when driven by a 9 to 16 VDC source.
Remove these ads by
Signing UpStep 1About the Circuit
A 12 volt source at one amp will easily drive this nixie tube supply. There is sufficient power produced by this switch-mode supply to drive at least eight of the nixie tube driver modules (I've had 12 of the nixie tube driver modules running off of one of these boards, that's 24 IN-12A nixie tubes!).
A typical nixie tube power supply offers 170 to 250 VDC at 10 to 50 mA. A switch-mode power supply is desirable because it's small and very efficient. You can fit it inside your clock and it won't heat up. The schematic for the project is taken directly from the MAX1771 datasheet, however, because of the large voltage jump from input to output, board layout and low ESR type components are critical.
Microcontrollers make everybody happy. You can try some Arduino flavour solutions, and drop in some code.
Much has gone in to designing this SMPS circuit so that it operates over its range of 150-220VDC. Due to the nature of the way SMPS supplies produce their power, it would be quite a challenge for it to both boost power and operate over that broad of an output range. You might get a solid 80-150 VDC, but it would involve completely redesigning the circuit.
Helluva quick response.
Thank you so much.
See: http://www.desmith.net/NMdS/Electronics/NixiePSU.html
For full details.
I do think people should give credit where credit is due.
You can request free samples here. When delivered, it comes in an insulated package to keep it cold.
The part number for the solder paste used in this instructable is: SN96.5-511-F I've had very good results using this particular paste, though you'll find many variations on the EFD web site.
