Remove these ads by
Signing UpStep 1Materials & tools
2 large wooden door stops (wedges)
1 metal bracket (see image)
4+ button head wood screws
4+ self adhesive non-slip pads
The metal bracket should be wide enough to provide adequate support for your laptop. This one was about 250mm (10inches) wide. It is important to use button head screws, as countersunk screws will not sit well in a bracket. The non-slip pads need to be thicker than the screw heads to avoid scratching the laptop.
All up this was less than $20AUD
Tools:
Drill
Drill bit
Screwdriver bit
The drill bit should be about the diameter of the screw shaft for hardwood, or about 1/2mm smaller for softwood. The screwdriver bit should match the screw head (e.g Phillips head/crosshead).
That's all. Nice and easy.
i made mine with 2 squares of 10mm board then drill a lot of holes were the speakers and fan was then in between the boards i put corner bits.
good to see you didnt just buy some cheep laptop stand =]
5 outa 5
