NiftyBender Deluxe - A tool for the stripboard user. by AndyGadget
Featured
The NiftyBender Deluxe is a simple jig which allows you to quickly and simply bend link wires to fit a 0.1" pitch matrix board spanning 1,2,3,4,or 5 holes.
This was initially just the NiftyBender, but then I thought of a refinement to let you make a link in 10 seconds or less.  So was born the NiftyBender Deluxe.
Step 1: Tools and Materials.
You will need a scrap piece of matrix board (Veroboard).  The unclad is better for this than the copper strip type as it is easier to work.  You will also need 8 or so connection pins (Veropins).
The essential items are a sharp craft knife, pliers and cyanoacrylate adhesive (superglue).  I used Gorilla cyanoacrylate as it's a gap-filling glue.
A Dremel would be useful, but use a small flat file if you don't have one.  The best tool for cutting the board I found to be a nibbler (see pic) but the knife and pliers will suffice.  A pair of wire cutters (not your best ones) also works well.
(Instructables - Many thanks for the Dremel Minimite - now being put to good use, once I'd bought a 240V to 110V adaptor.)
park47 says: Sep 4, 2011. 11:40 PM
Thanks....your invention made my Weekend a lot happier. :)
kooth says: Jun 1, 2011. 9:52 AM
Awesome!
Build_it_Bob says: Aug 17, 2010. 5:57 PM
I will be making one of these! Great idea and easy to do. Bob
thatoneguydavid says: Feb 8, 2010. 10:55 PM
not to burst your bubble, but this too does exist:
http://evilmadscience.com/partsmenu/68-bender
AndyGadget (author) says: Feb 8, 2010. 11:36 PM
No bubbles burst.  Someone else mentioned that device by PM.  That is similar to my first design which was a bit fiddly as you have to form both sides at once and it is harder to get the angles accurate and the corners sharp.  (The cutaway for the component is a good idea though.)  The 'trapping' mechanism of my Deluxe version speeds things up and gives a better end result.
zoltzerino says: Feb 8, 2010. 10:43 AM
 Very nice, bruvva!
Fred82664 says: Feb 7, 2010. 5:01 PM
cool make your own staples file the wire ends to a sharp edge as well for the electronics jumpers
Blofish says: Feb 7, 2010. 9:29 AM
Outstanding! Very useful!
lemonie says: Feb 6, 2010. 10:53 AM
That looks useful!
L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
