P.A.D.D from star trek voyager
Fan of star trek? always wanted to own a prop from the show? well, nows your chance, I recently purchased seasons 3 and 4 of voyager, and have slowly been working my way through them. When i noticed what would make for a great remake, one of the P.A.D.D devices that they use.
I did some googling, and found the easiest way was to use three layers of material (plastic or card) simple cut out, sprayed, and stuck together.
I set out planning to trace some screen shots/web images, to make a template, however, along the way i stumbled accross, Matt Munson who had a wide range of templates free for personal use.
Update - Matt Munson commented on this Instructable with the news that he had been prompted to add the files to his site again.
You can access all the templates here - www.mattmunson.com/props/
Thank you Matt, for allowing access again, so everyone can make what is one of the best props out there.
I am not providing the templates here, as he explains that he had previous problems with people using the templates for professional gain.
So, here is how i did it.
You need,
  • Some world famous, gmjboard (super dense thick strawboard/cardboard)
  • Some thin plastic transparencies
  • a household inkjet printer
  • a good scalpel and stanley knife
  • Some double sided tape
  • a sharpie
  • some silver spray paint
Step 1Get cutting.
Get cutting.
Firstly we need to gather are materials,
Print out some of the templates, or design your own if your feeling creative, Its very easy to draw a simple design.
Stick the paper templates down to your selected board, My suggestions are to use either card, or plastiboard/styrene, both these can be cut using the stanley knife. Though the card is a much easier material to work with, it does give a slightly more rough finish.
Take your time with the cutting, many strokes, and less pressure is the way to go.
The corners are most difficult, but i found if i used the scalpel, and slowly nipped away around the corner it gave a cleaner better cut.
102 comments
1-40 of 102next »
Jan 15, 2012. 7:53 AMthe dashing hero says:
You could... get a tablet (touch screen) an make a cardboard frame...
Aug 21, 2011. 11:49 PMszulli-randall says:
I am going to try making one with a form of Tablete computer inside! Will try to get picture.
Oct 4, 2009. 4:06 AMNykus79 says:
Awesome!! I'll try build that one when i get material all I needs. By the way. those link in step 1 Matt (whatever last name) site is down or non-exist
Jul 18, 2011. 3:56 PMChirpoff says:
Try here: http://www.mattmunson.com/props/padds/
:D Have fun!!!!!!!
Jul 18, 2011. 3:51 PMChirpoff says:
I can't find the main picture you used with the UFOP on it. Could you point me in its direction? I've been to Matt's site (thank you, Matt!), and found everything but that. Thanks!
Jul 18, 2011. 3:55 PMChirpoff says:
Oh, I just found it! Sweetness! Thanks again! :D
Jun 6, 2011. 3:17 PMultralegomaster5096 says:
You know what? This gives me an idea. iPad 2 case. Working (if different software) padd.
Nov 12, 2010. 9:23 AMhappybirthday says:
Where can I buy gmjboard? or will normal cardboard work?
Oct 9, 2010. 12:30 PMMattMunson says:
Hey gang. Great to see some folks looking to build up PADDs! These have always been one of my favorite props.
Someone pointed me to this discussion, and I have re-posted all of my templates for ALL of the padds I ever drew, and also put up a bunch of graphics that I made over the years.
As always, my only request is that these are used for personal use, not financial gain.
you can find everything you need here:
I forget what the various thicknesses are for the different padds. If I figure that out, or can find my notes somewhere, I will post that too.
Thanks again for all of the interest in my templates. I hope you make great use of them!!!
Sep 4, 2010. 4:33 PMfloryzzz says:
Of make a case for the iPad out of it. I doesn't have a iPad myself so i cant make one. If you make one please PB me a picture :)
Sep 1, 2010. 1:57 PMThat Inventor Dude says:
you sir are a genius. i did this ages ago when i was 8 in white and orange so as to resemble the next generation ones using instructions from my dads old star trek annuals and the next generation tech manual.
Sep 2, 2010. 5:45 AMThat Inventor Dude says:
the only flaw is the vital templates are not given and they dont seem to exist anymore
Aug 22, 2010. 12:49 AMLyokoking99 says:
It would also be great for use as a "functional" prop. Make the screen Green, then Chroma Key and rotascope your animated/interactive interface.
Feb 20, 2010. 8:20 AMflamespinner1 says:
 HE'S right it dosen't
Jan 22, 2010. 6:36 PMflorio08 says:
Hello all, i wanted to know if anyone knew where to get the template for the PADD.
thanks
Sean
Dec 1, 2009. 6:22 AMgmprops says:
Great job on that large Voyager PADD. I have done several PADDs myself using a combination of acrylic and styrene plastic sheets. I have also successfully integrated about 20 working LEDs, 10 different sounds, and a softswitch to turn the PADD on. I got the original templates from Matt Munson. I have also done several tricorders with lights and sound.
Dec 7, 2009. 5:44 PMNykus79 says:
u made that too? put up on site i wanna see how u do that
Nov 27, 2009. 8:20 PMlucek says:
I'll admit I'm a little disappointing with this. I thought this was a case mod for a pda. well still cool.
Oct 16, 2008. 5:30 PMcaitlinsdad says:
Cool, you need to embed an LED to make it glow and make the surface a touchswitch so it will chirp when pressed. I'm more of a tri-corder man myself...
Oct 20, 2008. 1:56 PMLithium Rain says:
Oooooooooo...that would be the pinnacle of sweetness...
No, on second thought, the pinnacle would be to make a working padd.
Oct 4, 2009. 8:20 AMNykus79 says:
Styrene? "The White sheets are used to construct buildings for your railroad diorama's and layouts. They may also be used for various scratch craft projects and miscellaneous projects." from towerhobbies.com very same one? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTLB3&P=FR
Sep 18, 2009. 1:47 PMArticas says:
Where can i accuire this Gmjboard you speak of
Oct 4, 2009. 8:06 AMNykus79 says:
i think he mean cardboard strong enough... than box cardboard. I has been look though in this http://catalog.uline.com I don't know which one... I hope GMJ will reply.
Oct 18, 2008. 10:06 AMjoe57005 says:
you can make a "real" one using a nokia internet tablet and this theme.
Oct 19, 2008. 1:43 PMjoe57005 says:
just be careful which version of the os you use. there's a glitch in every pre '08 version that makes uninstalling the theme nigh impossible.
Oct 21, 2008. 3:56 PMjoe57005 says:
Superior hardware only.
Oct 22, 2008. 6:18 PMjoe57005 says:
I just prefer open source software. I like to do things myself, in software and hardware. (i soldered 8gigs of storage into the device and modified the software to support it.) I don't want to start a flame war. it will only piss people off and get people (including me) banned.
Jul 22, 2009. 11:38 AMDerin says:
STARDATE 22249.6
Nov 6, 2008. 3:59 PMDJ Radio says:
a lot of famous star trek gadgets have been made in reality- and better (for example, the communicator is a cell phone in real life.) the only exception is the teleportation beam
Jan 20, 2009. 1:19 PMMr. Brownie says:
The cell phone shall never triumph over the communicator! *pulls on klingon suit* Today is a good day to die!!
1-40 of 102next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
561
Author:gmjhowe(Instructables Chatroom)
I work as a Graphic Designer/Artworker, my time is spent creating a miz of Cyberpunk and Tech related creations for your viewing pleasure. If you have any questions, you can normally find me in the ...
more »
