3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PC Mouse Robot
PC Mouse Robot
We decided that we wanted to have some Mouse Problems at the house, but we really dont like to deal with the whole "Bio Hazard" stuff so we had to make our own mouse problem out of a Computer Mouse!
You can leave us some feedback at our website at www.hm-innovations.com and view our other projects!
We made a little robot that used the Mouse "right and left bumber" as "feelers" and it actually evaded several objects around the house. Except for our dog :( this little guy had fun till it died to our dogs superior E Mouse Hunting skills and malevoulous Jaws :(
But I can say it was fun while it lasted, RIP Mr. Mini PC Mouse Robot
this is how it worked when the mouse ran into a wall one of the motors is stoped from spining which causes the other motor to take over and spin around and away from the obstacle. The happily continue onwards
This is our video on the project.
Step 1Finding the Corpse
Finding the Corpse
Okay the first thing you need is to find a mouse CHORD mouse it has to have a tail so were going to use the USB or Mouse Connection chord as a tail.
Once you find the mouse you want to use you need to open it up, do this by taking off the secret screws usually found under stickers or under the bottom mouse pads.
See the 3rd picture for the screw spots :P
20 comments
Jun 16, 2011. 6:14 AMjpman says:
which is the positive side ??
Apr 11, 2011. 2:45 AMEuan Robb says:
hi great instructable one question though what type of mouse did you use?
Thanks
Jan 31, 2011. 2:02 AMcoolkids says:
good instructible i have a doubt can i desolder the other components?
Nov 21, 2010. 4:20 PMtheharry says:
ohh cool =D
May 23, 2010. 2:47 PMD5quar3 says:
 Thanks for posting this My only problem is that I got both motors to work except when the right motor stops it doesn't  start until you press the left bumper.
Aug 28, 2010. 11:01 AMD5quar3 says:
thx
Aug 28, 2010. 8:02 AMTheJediKnight says:
Hi there! Great tutorial! I have an old Nokia 3100 cell phone I used in high school. Would that vibrating motor be okay to use or would I need something larger? It's a small phone so I'm not sure it would work out but I figured you may know. =D
May 6, 2010. 5:03 PMpoppy24 says:
ok the robot spins in circles ONLY spins in circles pleez help me
May 9, 2010. 2:15 PMpoppy24 says:
50 bucks in wire, soldering equipment , just to have the thing spin in circles, even tried adding model wheels and axles. thanks for the waste of 15 hours and fifty bucks for a dissappointed daugther and her science project.
Apr 17, 2010. 3:10 PMpoppy24 says:
do you HAVE  to use old typewriter motors or can use something else?
Mar 16, 2010. 8:06 PMhenrybot says:
the principle is the same on the beetlebot, actually some mouse/mice uses SPDT (single pole double throw) switches which u can use for the feelers.. anyway, GOOD JOB!
Feb 7, 2010. 4:42 AMTSC says:
sweet good job
Feb 4, 2010. 12:55 PMfunnyfoo0 says:
amazing instructable
Feb 2, 2010. 9:28 AMAndyGadget says:
Brilliantly Done!
The only problem I can see is getting suitable sized motors.  The easily available ones tend to be either mobile phone vibrator sized ones or the larger cylindrical type.
Feb 2, 2010. 10:37 AMAndyGadget says:
If the weights are the split type, make a tool out of a rubber (eraser) and a couple of steel pins, around 1/16" x 1".  Push them in parallel so they rest against the flat of the weight.  Put the thing in a vice to apply pressure against the weight and that will open things up enough to pull the motor free.
If they're the solid type, a few seconds with a micro-blowtorch then a swift tug usually works.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
145
Author:HM-Innovations(HM-Innovations.com)
We are a group of Engineers, Tinkerers, Designers, Programers, and Nerds ! ---- and Since April 2011 We also have a Cupcake Maker
