Remove these ads by
Signing UpStep 1Tools and Supplies
* handsaw
* PVC glue
* drill w/ bit slightly larger than wire
* pliers and/or wire cutters
* roll of white duck tape
* tape measure
* Sharpie
* Nylon cord (if you plan to make your own net)
For each goal you want to make (we constructed two), you will need at least:
* (x6) rounded PVC corners
* (x4) T-style PVC connectors
* 1 1/2" PVC pipe (amount depends on size, roughly 50' for 5'x8' design)
* 14 gauge (approximate) galvanized steel wire
Alternate 5' x 10' goal design checklist:
* (x4) 3-way 90 degree PVC connectors
* (x4) internal 45o elbows
* (x2) 90 degree joints
* 1/2" PVC pipe (amount depends on size, roughly 60' for 5'x10' design shown)
As for the PVC size- I suppose it's worth mentioning that you must have connectors that match the size of the PVC you've chosen. The original goals (not of my design) used 1 1/2" PVC, however I believe 1 1/4" is nearly as strong, as well as being slightly lighter weight and about $1.00 cheaper per 10' pipe. The smaller you go in size, the cheaper it will be, but that starts to trade off with how rigid the goals will play. It's also worth noting you may need to order connectors online, depending on what you find at the local hardware stores.
comment
Add Comment
NachoMahma
says:
Add Comment
