3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pallet Adirondack Chair
Here's a fun way to reuse wood.  Make this Adirondack chair from shipping pallets or other reclaimed lumber.
Step 1The low-down on pallets
Pallets come in many shapes and styles.  They're made from lots of different types of wood.  They are readily available for free.
In fact, most companies pay people to take them away.
But there's a catch: pallets aren't easy to take apart.  They're also usually not made of very good lumber. If you use them for projects, you're going to spend A LOT of time dismantling them and you're not going to get much from a single pallet.
If you're expecting perfection, than pallet lumber may not be right for you.  You can try salvaging used material from places like craigslist.  I collected an impressive amount of wood for my other pallet instructable, the Pallet Playhouse.
If you're not interested in turning a pallet into something else or trucking around the nation looking for free stuff, substitute the pallet wood for some nice cedar or pressure treated wood.  I made a PT set in a similar pattern that's held up for 11+ years of direct exposure to the elements.  They're still perfectly sound.  You won't get that kind of performance from pallet wood.
37 comments
May 20, 2012. 5:17 PMwulfhardt says:
This is a great instructable, thanks for uploading all this good info and clear pictures.
The only changes I made are in how I took apart the pallets and the width of the chair. I used a reciprocating saw with a bimetal/demolition blade to simply cut through the pallet nails, then used a nail & hammer to tap the nail stubs out of each board. I did this because I used heavy-duty pallets with five stringers through them, making it nearly impossible to rock the boards back and forth like you would with a three-stringer pallet.
The chair itself is very comfortable. I sit in it and just don't want to get up. But I'm a big fat dude, so I wanted a little more room to spread out. So I went back and added 8 inches to the width, and the final product is ideal for my size.
Apr 14, 2012. 3:12 PMallteal says:
What size screws?
Nov 27, 2011. 4:55 PMrx7ja1989 says:
Thank you very much for your instructable. It was clear and detailed, making it easy to follow, especially the templates for each piece of this great puzzle.
I have little woodworking experience and the pictures help tremendously.
I just finished assembling my chair, no I just need to sand and apply some polyurethane.
Thanks again.
Jun 16, 2011. 2:24 PMmindstormmaster1 says:
We got two pallets free from out neighbor the other day and the next day I work up and thought you know what Im going to use those to make my dad an Adirondack chair for fathers day. After a quick google from plans I found yours and I was luckily enough to have a few days back to back to work on it and I now have a rock solid chair thanks to your great instructable! Im 99% sure I had seen this before and thats why I was inspired to build it. Anyways thanks for the great post my dad is going to love it!
Apr 13, 2010. 7:32 PMTwotim221 says:
Nice chair. I like to make things out of pallets too-recently I made hanging chair out of a pallet and made an instructable about it. Some people commented to me that pallet wood is treated and can be bad for your health to work with. Have you heard anything like this? Someone even said that you shouldn't  touch it.
Apr 14, 2011. 2:05 PMthewetturd says:
The pressure treatment that is given to wood that you can buy at your big box stores these days are not as unhealthy as it has been in the past. The arsnic based treatment has been changed to a copper based one that does not contain carcinogens although you still don't want to burn it.
Apr 8, 2011. 11:08 PMmscharf says:
A great place that I have found to salvage wood is in trashed box springs. I have found the the best place to find them is around apartment buildings and even more so around college dorms. due the high turnover rate of occupants. The wood is generally strong and in pretty good condition.
Apr 1, 2010. 7:17 AMroadzombie13 says:
Use a speed square for your saw guide.
The cut will be Square to the wood plank every time.
Apr 1, 2011. 11:42 AMBigShotUK says:
Excellent suggestion!
I was just mulling over how best to get square cuts without too much messing about when I just want the pallet to come apart. I doubt I'd have thought of using a speed square, but if I'm not mistaken I've got one buried in the garage somewhere. You just saved me a huge amount of time.
Thanks.
Aug 25, 2010. 4:34 AMgonzaloleal says:
very good
May 27, 2010. 3:02 PMno1sangel1978 says:
Roughly how many pallets do you use per chair?
Thanks for the great project!
Apr 1, 2010. 7:32 AMroadzombie13 says:
Want longer planks?
Sometimes there is enough room  to use a reciprocating (sawzall) saw and cut the nails between the two pieces of wood.
 If not I use a breaker block, which is a scrap 2x4 with a 45 angle on it.
  Place the block on the backside of the plank, angle the point toward the nail Head; hit it  a few times to free up a gap.
The blade is thin so you can work it in with minimal damage.
 You can cut all the nails this way even the center support.
This will give longer planks to work with.
If you don’t want the nail heads, just use a punch (old nail) tap the heads up and pull them out.
Note, I use junk old blades.
Mar 30, 2010. 1:56 PMdigimancer says:
 This is a pretty cool idea. I work in shipping and have access to tons of free pallets. I think i'm gonna grab a few every week and bring them home to stockpile up some scrap wood for this. I'm also gonna try to under engineer this a bit to see if I can reduce the need for jig saw cuts and use my chop saw and sander more.
Mar 30, 2010. 10:09 AMSpeidumb says:
 Great Instructable - Now I have to figure out how to haul pallets in my car.
Mar 28, 2010. 12:38 PMLoneWolf says:
Adirondack as in Adirondack Mountains?
Mar 29, 2010. 5:41 PMgravguy says:
http://en.wikipedia.org/wiki/Adirondack_chair
Mar 30, 2010. 7:43 AMLoneWolf says:
Oh, thanks for the link.
Mar 29, 2010. 12:33 PMLoneWolf says:
Aw, now I'll never know :)
Mar 27, 2010. 9:16 PMvalhallas_end says:
Very nice build, and well documented.  I've always liked Adirondack chairs - maybe I should check with my local hardware stores...friends that work there grab pallets all the time for materials.
Mar 27, 2010. 9:28 PMChrysN says:
Nicely done!
Mar 28, 2010. 4:51 AMbiker_trash_1340 says:
Very nice work, Need a few for my deck this summer. I'll have to start looking for some pallets this week.
Mar 28, 2010. 5:43 AMdomestic_engineer says:
fantastic. can't wait to make this. Love your pallet playhouse too.
Mar 28, 2010. 10:33 AMthatoneguydavid says:
great instructable.  one idea to make things a bit easier.  try sanding the pieces after you cut them all out, but before assembly.  at that point you could use any size hand sander or belt sander with no problem.
Mar 28, 2010. 12:54 PMDIY Dave says:
great job
Mar 29, 2010. 4:53 AMJademadina says:
My woodwork class had made this type of chair but it was made with white pine((treated) i never thought of pallets but not thankis to you I found an easier way.    This is brillant  thankyou.  10 out of 10.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:jkratman
