More info and other projects can be found on shoestringpavilion.blogspot.com
Step 1:
(If you're making one lounge chair you'll only need 3 pallets but this tutorial is for two chairs)
- Four pallets of the same size, preferably rectangular
- One pallet slightly wider than your other pallets, more square than rectangular
- Scrap 2X4s or pallet scraps of the 2X4 kind
Step 2:
Make sure your one remaining pallet is wide enough to fit as a back rest. A pallet usually consists of three layers of wood: the top boards, the middle boards (often 2X4s) and the bottom boards. In this case the top boards need to be long enough to fit as a back rest while still accommodating the 2X4s on each side of the seat. So they need to be the width of the seat plus at least 4 more inches, if they're an inch or two longer than that you don't have to be so precise and it'll make your life easier.
Now it's time to deconstruct the backrest pallet and here's where the hard physical labor comes in... Remove all the bottom boards of the pallet and the two outside (edge) middle boards. Leave the one or two (depending on how your pallet is constructed) 2x4 boards in the middle where they are to help you keep the top boards in place. Save all the scraps, some will be used later in this project.
The arrow in the picture shows the nails holding the original middle board to the top boards, everything else was deconstructed.
Cut the remains in two halves. Make sure you cut so the slats will be in the same direction as your seat (i.e. only cut the middle board, not all the top boards).
Take your 2x4s, either from another pallet like I did or use new from the lumber yard, and attach them to the top boards on either side. These need to be longer than your back rest (top boards) so they can reach down and fit next to the seat pallets, as you can see in the picture.
Step 3:
Step 4:
The last picture is the view from the back to clarify the construction.
Step 5:
At this point I went ahead and primed mine and eventually painted them red but it's entirely optional. Home made cushions make them ready for lounging!
Visit Our Store »
Go Pro Today »
A couple more 2x4s and you wouldn't have to have a bigger pallet for the backrest. Cut the backrest pallet in half all the way across, and screw a full length 2x4 on to each side. This would use parts of more pallets though, and you've got a really optimal solution here.
I use the reflector from a street light buried to an inch of it's rim and filled with dirt to about two inches from the rim for a fire pit. That'd be a way to get rid of excess pallet. An oven rack makes a nice grill for it. :-) Just watch out for treated wood, but you wouldn't want to use that for a seat either. The splinters are nasty.
I made Sparkle Balls and I have 2 liter Wind Spinners as well.
My neighbors love me.
These lounge chairs are great cause they are nice and wide and the cushions
are a nice touch.
5.0 !
