Paracord wrist lanyard made with the snake knot
 by Stormdrane
Featured
This instructable will show how to make a wrist lanyard using paracord and the snake knot. The lanyard can be used to secure a key chain, knife, multi-tool, flashlight, cell phone, camera, binoculars, compass, etc. More projects, links, knot references can be seen on my blog page, Stormdrane's Blog.
Step 1: Supplies
You'll need about 4.5 feet of paracord(you may use other types of cordage if desired). The paracord I used is from the Supply Captain. I left the inner strands in the paracord, but you can remove them if preferred. If done in one color, it will be one continuous 4.5 ft length, if done in two colors, you'll need 3 ft for the primary color that includes the wrist section, and 1.5 ft for the second color that will show in the snake knot. Also used are scissors, tape measure or ruler, lighter, hemostats or needle nose pliers(not necessary, but they make it much easier), and a swivel clip, key ring, snap hook, cell phone lariat, carabiner, or whatever attachment you prefer to use.
Step 2: Attaching two colors of paracord
If using two colors of paracord, you will insert one color about 1/2 inch into the other color. You may remove a small amount of the paracord's inner strands by pulling them out, trimming with scissors, and pulling the paracord outer sheath back over the strands, leaving room to insert the other color. For various projects, I've used three different methods for attaching two colors of paracord: melting, sewing, or gluing. The choice is yours, I usually sew them together, it doesn't matter as long as it's a good connection. It will be hidden under the first knot.
Step 3: Find the center of the length of paracord
Take the center of the length of cord and bring it thru the attachment, I'm using a swivel clip. For this tutorial I'm measuring the wrist loop at about 10 inches from the attachment. The connection of the two colors will be just on the other side at this point.
Step 4: Making the snake knot
The snake knot will be made 'around' the wrist loop section of paracord, the loop strands being the 'core' of the knot. I've added a series of photos showing the steps I use. By using two colors, you'll see that I flip the lanyard over after making each knot, so that I'm working with the cord on the right side of the lanyard. I bring it under all the other cords, working the hemostats under the previously tightened knot and pulling the cord back thru. Then tightening up the knot keeping the cord from twisting and working it up against the previous knot. Again flipping the work over, you'll see two parallel cords of the same color which will be split with the cord on the right going under, around, and pulled thru with the hemostats, then tightened up. Continue this procedure until you've done about 10 snake knots(you can count them down either side.
Step 5: Count your knots
Once you have 10 snake knots you're almost done. You'll notice from the photos of both sides of the lanyard, that one side has the snake knots alternating all the way down and the other has a set of parallel knots at the top and botton of the sequence of knots. You'll always have those at the start and finish of the snake knots, I prefer to have them end up on the same side of the lanyard so one side appears to have a more uniform look, but it's not required.
Step 6: Trim and melt the excess paracord
Use the scissors to trim off the excess cord and quickly melt the ends with a lighter so they don't fray.
Step 7: You're done!
You can make a range of variations using less or more cord/knots. Shorten the loop for a double ended key chain or make the loop longer for use as a neck lanyard, a Lanyard Break-Away Connector could be added for the safety conscious. You can also add a wooden bead, skull, cord lock, etc. Visit my blog page for more knot related projects, links, and resources: Stormdrane's Blog. You can find ideas for other gear/gadgets to attach to your lanyard on EDC Forums.
1-40 of 107Next »
killeryeti4217 says: Aug 19, 2012. 9:11 AM
I added a diamond knot to where i wanted the snake knot to end.
Gunner7800 says: Jun 9, 2012. 8:22 AM
Is there any way to use this knot to make a continuous loop?
Stormdrane (author) in reply to Gunner7800Jun 9, 2012. 2:15 PM
I've not tied the snake knot that way, but if you tied it around a separate loop of cord or start with making a loop first,  maybe like these slip-on type paracord bracelets, you could have the end finish right up against the start, where it may not be very noticeable and give the look of a continuous loop...
mbreukel says: Feb 27, 2012. 9:59 AM
really nice knot! just made mine, with woodland and black.
i was wondering, of you take enough cord, could you wrap things with it? like a lighter?
Stormdrane (author) in reply to mbreukelFeb 27, 2012. 11:03 AM
Yes, you can make the knot around other objects as the core of the knot, like a lighter, walking staff, flashlight, knife handle, etc...
tomtom88 says: Jun 2, 2009. 9:16 PM
Excellent Instructable! I've made countless cobra stitch bracelets since I first read your Instructable and finally tried this one out. Very clear instructions makes it really easy to follow! Great job! Now if only you could make an Instructable for a monkey's fist!
Stormdrane (author) in reply to tomtom88Jun 2, 2009. 10:28 PM
I did make a video for making a monkey's fist using rope. The thing that I think most folks have trouble with when tying them, is that you need to gradually tighten up the fist by just working a little of the slack out from one end to the other over several passes before it's eventually as tight as you can get it.
tomtom88 in reply to StormdraneJun 4, 2009. 3:17 PM
yup, you sure did haha. nice vid. the first directions i saw for making a monkey's fist were pretty clear and precise. it definitely looks easy. i guess the tightening part would be the most difficult part as you say.
reeseecup in reply to tomtom88Jan 13, 2012. 12:14 PM
it is very hard
SIRJAMES09 says: Nov 2, 2011. 2:04 PM
TY Sir for sharing. :)
Excellent Ible.
tphan4 says: Oct 25, 2011. 9:06 AM
Stormdrane, how much paracord would i need to make this a 72" dog leash?
Stormdrane (author) in reply to tphan4Oct 25, 2011. 11:52 AM
If you're going to make a dog leash just like the wrist lanyard is tied, I'd figure on starting with around a 75 foot length of paracord to be on the safe side and not come up short, but how much you actually use may vary by how tight or loose you make the knots as you go...
tphan4 in reply to StormdraneOct 26, 2011. 12:06 AM
How long for primary color and then the secondary color
Stormdrane (author) in reply to tphan4Oct 26, 2011. 2:01 AM
This is just a guesstimate since I haven't made a dog leash length version of the snake knot lanyard, but around 45 ft for primary color 30 ft for secondary. Once attached, figure at least 12 ft or so of primary will be doubled up for the core/wrist loop, and then the attached section of paracord will be looped around your swivel clip/snap hook where you can begin knotting, as in the instructions...
With using two colors instead of one, make sure you do a secure job of joining the paracord, whether you sew, melt, or super glue them together, since a dog leash will be under greater strain than a wrist lanyard would, and you don't want it to be pulled apart with a dog on the leash. ;)
nkillingsworth vi says: Aug 28, 2011. 7:56 PM
stormdrane, I love all the things you've done with paracord. Can you figure out how to make this type of lanyard? I've looked and cannot for the life of me figure out how to make this. I don't know whether to begin with the knot on the end or the snake knot. Any ideas are helpful! Thanks!
Stormdrane (author) in reply to nkillingsworth viAug 29, 2011. 6:37 AM
I would guess the Chinese cloverleaf knot is tied first, a loop made with one strand coming from the knot, then both used to snake knot back towards the cloverleaf knot around the two strands.
montys survival straps says: Aug 14, 2011. 9:53 AM
this is a great design im going to sell this on my website!
kalmahot says: Apr 5, 2010. 12:00 PM
 muy bueno, practico, ahora se como utilizar mis cordones viejos, bueno, mejor compro nuevos y coloridos =).....
triumphman in reply to kalmahotAug 8, 2011. 5:08 PM
when in Rome speak Roman, que pasa ?
triumphman in reply to kalmahotAug 8, 2011. 5:07 PM
No habla espanol ! English por favor !
hcohen says: Aug 3, 2011. 9:40 PM
is it possible to make it without the clip and out of the same color
i no its kinda stupid just wondering..
Stormdrane (author) in reply to hcohenAug 3, 2011. 11:47 PM
Yes, you can use one color with a single length of cord and tie the lanyard without the clip. You would need to tie it directly to something or use an attachment other than the clip, because if you hold the snake knot section and pulled on the wrist loop, there'd be nothing to keep the loop ends where the clip is from pulling down into the snake knot section.
rgonzalez13 says: Jul 13, 2011. 6:25 AM
This is my first band! I followed the steps (mostly the pictures to be honest). See the results!. Thanks for sharing all of your instructions.
Watch: Nabucco Chronograph by Raymond Weil (Stainless Steel Version)
Ianoath says: May 25, 2011. 3:40 PM
I really like the looks of this lanyard, but I notice you refer to it as a wrist lanyard and you give the length of paracord to use for this, if i were to make a lanyard following this same design to wear around my neck, how much cord should I use?
Stormdrane (author) in reply to IanoathMay 26, 2011. 5:04 AM
For a neck lanyard, just add about 2 feet more to the amount used in the tutorial. So if done in one color, you 'd use about 6.5 feet of paracord, or if done in two colors, you'd use 5 feet for the primary color and 1.5 feet for the secondary color.
If you want it to be a safety/break-away lanyard, you can add one of the connectors linked to in the tutorial. You'd make the lanyard first, then cut the cord at the center of the neck loop and add the connector there.
jielder says: Jan 27, 2011. 9:45 PM
Thanks for the Instructable, just made two of them to use as snowboard leashes...
DonB! says: Jan 25, 2011. 8:09 AM
I saw a keychain on the internet, simply used as a photo, and loved it, but wondered where that particular knot pattern could be found.
I should have obviously turned to you, stormdrane, and all of your great tutorials. You really have a creative knack for color, weave patterns, etc.
Thanks for sharing it all with us.
the gizmoman says: Dec 23, 2010. 1:44 PM
You and tying it all together (YouTube) have some amazing knots and tutorials keep up the good work (are you on YouTube under stormdrane?)
Stormdrane (author) in reply to the gizmomanDec 23, 2010. 3:27 PM
Yep, that'd be me. :)
the gizmoman in reply to StormdraneDec 25, 2010. 7:21 AM
I love trying to tie different and unique knots. I got intrested in tying knots through the boyscouts (I'm an eaglescout by the way) I saw your blog and you got some amazing pieces of art ( rope art that is. )
DrSteve says: Aug 18, 2009. 6:35 PM
Where does one purchase the hardware for these types of projects (swivel clip, key ring, snap hook, cell phone lariat, carabiner)? Thanks.
Vijster1 in reply to DrSteveNov 12, 2010. 4:18 PM
rings, clips, and hooks can be found at a hobby store
jaberwok32 in reply to DrSteveSep 5, 2009. 9:54 AM
WALMART!
DrSteve in reply to jaberwok32Sep 5, 2009. 11:39 AM
Really....comon....where? I need like 200
devangelista in reply to DrSteveAug 14, 2010. 5:18 PM
You can get like 300 feet of it at the us calve store for 20 bucks. http://www.uscav.com/Productinfo.aspx?productID=5444&TabID=548
DrSteve in reply to DrSteveAug 19, 2009. 12:31 PM
Thanks. This is great. I am about to start making about 200 monkey fist keychains and Boy Scout woggle neckerchief slides (Turks Head knot). I was having problems finding ball bearings and the hardware! YOU ROCK! How about a place for beads and ball bearings!?
Stormdrane (author) in reply to DrSteveAug 19, 2009. 1:37 PM
For beads, check local craft stores. Since beads need a hole large enough for cord to fit through, seeing them in person lets you see if they'll work with the cord you have. Buying online is guess work if they don't list the inner diameter of the bead's hole, where 4mm is about the smallest you'll get a loop of gutted paracord pulled through.
Stormdrane (author) in reply to DrSteveAug 19, 2009. 1:33 PM
For ball bearings, I've used this ebay seller(ToolSupply). They also carry wooden balls.
You can check your local machine shops and auto repair shops for ball bearings too. Just look them up and give them a call to see if they have any.
Stormdrane (author) in reply to DrSteveAug 18, 2009. 7:46 PM
There are multiple sources for them, here are a few: cdwplus.com enchantedbeads.com lighthound.com tadgear.com countycomm.com supplycaptain.com photonlight.com ebay.com You may find some at your local hardware store, walmart, home depot, lowes, michaels craft store, and hobby lobby...
moosesyfer104 says: Aug 2, 2010. 3:35 PM
im a ninja.......................... with paracord
1-40 of 107Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
