3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Perfect Sawhorses: adjustable and knock-down design
* Adjustable
* Strong/Sturdy
* Don't require a lot of space to store (ie. knock-down)
* Economical (approximately $15 per sawhorse)
* You would enjoy, or at least have some ability in, assembling pieces of wood
If you have some or all of the above criteria for a set of sawhorses then these will be perfect for you.
Noteworthy:
* The design was inspired by this plan:
http://www.familyhandyman.com/DIY-Projects/Indoor-Projects/Workshop/DIY-Tips-For-Your-Shop/workshop-organization-tips/Step-By-Step#step1
* The finished weight of the saw horse is about 20 pounds.
Step 1Tools Required
Tools Required
Required:
* Drill
* Drill bits (1/2", 1/4", and smaller)
* Wrenches or Socket set
* Skill saw and/or Miter saw
* Pencil
* Level
* Various clamps
Suggested:
* Sandpaper (80 or 120 grit)
* Protractor
* Vise
33 comments
Mar 29, 2012. 12:42 PMpaulbsa says:
Good design, but it looks like this would be extremely heavy. Great for fixed use in a woodshop, but I would hate to have to continually carry these around to job sites. I wonder if some of the 2X lumber could be replaced with 1X. I agree about using bolts and nuts in place of the wood dowels and pins. You could also use something like a hitch pin from a trailer that would be secure but easily removable.
Feb 5, 2012. 2:08 PMpbates123 says:
Wow Great design Lofty Duck!! I see this is has been here for awhile although I just saw it. I want to make a couple for myself and maybe even a couple for a gift!
I had a couple of thoughts. Not having built a set yet it seems it maybe a bit wobbly once it is extended past the lower brace. If you were to route a dado on the inside of the legs say ~1/2in. wide and deep facing toward the slide on both sides, and on the slide near the bottom maybe an inch up drill a 1/2in. hole and insert a short piece of dowel. It would ride in the dado and help stabilize top assembly.
Also adding a couple of heavy duty hinges would allow the legs to fold up for more compact storage - might have to do a little engineering to make sure that add-on is strong enough - just a thought!
Great design I like it!!
Jan 31, 2012. 1:44 AMskirmishmonkey says:
When making the flat pack picnic bench - see @gareth0123 http://www.instructables.com/id/Flat-pack-for-storage-Plywood-Picnic-Table/
I realised what I have known for a while - I needed some saw horses. Looking at the local tool shops (I live in Malta and everything is quite expensive) I realised it would be cheaper to buy the lumber and make some myself.
This design fit all my needs - adjustable height, sturdy and above all, because space is at a premium, they collapse down so don't take up too much space.
They took less than a day to make. I followed the 'ible to the letter - including the 60 / 30 degree cuts on the legs - although they came out ok, I did mess up a few feet of 4 x 2 on the 60degree angles with the mitre saw. - ended up cutting 10 legs and choosing the best 8. Next time I would go with the 45degree cuts.
Other than that, a great design - already put to good use. Here is some pics of my horses. Thanks loftyduck for the design and a clear, easy to follow 'ible.
Jan 12, 2012. 4:44 PMbobbybrus says:
This is by far the best saw horse design I have seen. First it uses standard dimensional lumber, which is a plus. The miter cuts are not that complex. It seems like it would be plenty stable from side to side motion. Finally, the adjustable work surface makes it so versatile, that it can be used to support additional work surfaces at a variety of heights. This would be especially useful when using various woodworking machines, table saw, miter saw, shaper, etc. I would suggest making a adjustable insert with a dowel ended PVC pipe centered with an axle for a roller end feed when ripping long boards on a table saw. One other note, it is good to use a dowel to adjust the height of the saw horse top, but would it not be more stable to actually put the pin through a hole or holes in the top rail. Maybe this is wrong, but it just seemed like it might be better to do so. Overall, it is an exceptional design, which I plan to use. Well done and thank you.
Jan 5, 2012. 7:24 PMrjlewis74 says:
These are very cool. Being new to carpentry I've decided as these for my first project. Thumbs up
Dec 6, 2011. 12:49 PMLavon93 says:
Very nice. I'm new to woodworking...on a "grander" scale...lol
I would like to make a pair of these for my Father-in-law...Who has every tool know to modern man!!! I think he would appreciate these.
Nov 7, 2011. 12:42 PMUptonb says:
Well, I just made a pair of these today, and I have to say these are absolutely great. Very easy to follow 'ible.
Thank you very much for improving on the handyman version and publishing this project.  They will help me immensely on my projects.  :)
Oct 30, 2011. 12:26 AMsteliart says:
Very nice project with excellent instruxtable, thank you
Oct 14, 2011. 5:49 PMmyles136 says:
Love this idea. I have always needed a 2nd rest for large sheets. I too am opting for a single leg the a Tee base for future casters. I will use 1/2" plywood in place of 1x4's as a gusset on the inverted Tee base. I am also replacing all the horizontal 1x4's with 3-1/2" rips of 3/4" plywood for strength. As to the fender washers, I am confused. A 1-1/4" washer on one side and only the head of a carriage bolt on the other? I will use only four hex bolts at the top with standard washers as the other four bolts are not necessary with a Tee base leg. Your 1/2" wood dowels are sufficient for a normal weight load, in my opinion. Very nice design!
Oct 11, 2011. 8:26 PMSIRJAMES09 says:
I don't understand something...
Why would you use carriage bolts instead of hex head bolts?? Hex head bolts you can tighten down to the maximum, carriage bolts you can not.....
Not saying you're wrong for using them, I just don't understand why...
Oct 13, 2011. 7:36 PMSIRJAMES09 says:
I'm not saying you're wrong & I'm right, I just did not understand is all...
It goes against everything I believe in to tell someone what to do unless their health is in jeopardy.
Oct 11, 2011. 8:34 PMSIRJAMES09 says:
yes, hex head bolts & fender washers would definitely be better than dowel rods...safer too I think. :0)
Oct 11, 2011. 8:28 PMSIRJAMES09 says:
matching & labeling is a good idea.
My father was a cabinet builder for over 20 yrs & he always did that. :)
Oct 9, 2011. 7:00 AMtbird2340 says:
Question.. Why remove the fence and add that jig instead of just using the fence of the saw?
This is the only part I don't understand. Great horses!!
Oct 9, 2011. 10:21 AMshall1028 says:
My guess is the creator of this "instructable" was projecting the excess length beyond where the fence would be.
As long as your boards are cut exactly to length beforehand there is no need to remove the fence when using the fixture to angle them.
Even if they aren't exactly to length as long as you do the cut using the fixture first cutting the other end's angle will be done parallel to the fence so any excess will project beyond the blade without impediment.
Oct 10, 2011. 7:16 AMtbird2340 says:
I'm still confused, unfortunately.. Why can't you just take your miter saw to 60* and make the cut? Why do you need the board there?
Thanks
Oct 10, 2011. 2:05 AMGreenehouse says:
Great Instructable, thanks for putting it together and sharing it. For some reason I wasn't able to download the plans though.
Oct 9, 2011. 6:16 PMLudwig Von Mech says:
This is very very nice. A brilliant idea!
Oct 9, 2011. 11:21 AMTexSon says:
They look great, but if I could offer a recommendation, I would use a bolt instead of the wood dowels to hold the height adjustments. Some a bit heavy or if a something heavy was dropped on one it might break the dowel.
Oct 9, 2011. 10:45 AMDavid Catriel says:
Very nice. I think I'll make myself a pair :)
Oct 9, 2011. 10:40 AMTropics says:
Looks like a terrific idea,but...some of the steps appear to be missing and I am unable to download the PDF. Thanks.
Oct 9, 2011. 7:18 AMtjk1939 says:
Nice job...On my to do list.
Oct 7, 2011. 3:56 PMbobby sissom says:
beautifull,i will so make my twin brother jealous,he has had a home made set of sawhorses that have made me the same for years,muuwaahaha
Oct 6, 2011. 12:48 PMdimtick says:
I really like these. think i'll be building some of these. mine are ok but i've been wanting new ones for a while. I don't have a lot of space so I need something that can easily be stored with minimum space and yet give maximum flexibility. these are perfect.
I think it may be helpful to add a 1x on top of the frame to be sacrificial when making cuts. you can periodically replace the 1x without cutting up the main frame.
I think when I drill the holes I'm going to go around and measure important heights....work table, chop saw, router table, etc. and then lay out the holes so that I can set the height to align with the tools
I do a lot of furniture pieces. I think that in addition to the triangle leg assembly, that i'll make some low legs using a horizontale 2x4 with casters for working with large pieces.
nice job.
Oct 6, 2011. 8:54 AMmikeasaurus says:
Nice build, I could use a few of these for some of my projects.
Any thoughts to using steel bolts instead of the wooden dowels for the height adjustment? It seems like that would be the weakest part when the sawhorse is carrying a load.
Oct 6, 2011. 12:55 PMdimtick says:
if your worried about the top frame coming out when you lift it, add a 1x stop board to the bottom of the frame. if you look at the inspiration design the pull out frame has a 1x across the bottom which prevents it from being pulled all the way out. may also add a little stability when the frame is at full height.
Oct 6, 2011. 12:19 PMzazenergy says:
Very nice documentation and work!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:loftyduck
the humble handyman
