iImage Information
An bed made from iron pipe. The design is simple yet sturdy. Not too pricy, simple to make, easy to adjust/disassemble, this bed will give your room an industrial feel.
Step 1Acquire Materials
Here are the required materials
- 1 1/2" schedule 40 iron pipe: Available at plumbing/hardware stores. Rather heavy. You can buy 10' lengths and then cut it yourself. Note that 1 1/2" pipe is not actually 1 1/2" in diameter. Its really closer to 1 7/8"!
- Hacksaw/pipecutter/chopsaw: For cutting the pipe down
- Couplers: You can buy these from mcmaster carr, they are used to build railings. They are sometimes called "speed rail" or "speedrail". Search the online mcmaster.com for "speedrail" and order the couplers you want. I got mine for free and they were all of the "4 outlet crossover" kind so I used only those but theres more suitable configurations.
- Allen wrench: for opening & closing the couplers
- Plastic pipe-end covers: get these at the place with the pipe, they protect your floor
- 1x8 wood panels for making the slats, and 2x4's for holding the slats together
I'm going to make one of these soon and want to know if I can get the smaller lighter pipes. I was thinking about splitting the long beams and dropping a support down on both sides also.
Will the rather small feet, and the (I'm assuming) weight of the bed (plus occupants) cause any damage to floors? I'm getting an apartment in Chicago, which tend to have poorly built wooden floors.
If not, you can put some tennis balls over the plastic caps. Or glue some fleece or heavy cloth onto the caps.
If you decide to follow my last suggestion - softer material like some 3mm or 6mm plastic or hardpaper should be a good idea. Then leave the plastic caps off and briefly use a hole cutter to cut a groove into the sheet into which the pipe will lock and thus stay centered.
And if the floors are really bad (i.e. made of hardpaper with a thin veneer), expect to replace them after a couple of years of normal use anyway.
what i meant is, if you could find a bed for less than $100, that would be really awesome, and i'm sure i wouldn't be the only one who would love to know where!
again, sorry! i really didn't mean it that way
Actually, Walmart and quite a few other places sell bed frames for that cheap. Even Ikea has one or two. You'd be surprised! I still like this idea though. It looks very "green". :)
http://en.wikipedia.org/wiki/Pipe_(material)
