3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Plasma Bulb with Clock Gear
Hi,
I am a Steampunker from Germany and today I try to create my first Intructables instruction.
I hope you understand all otherwise ask and I will give my best to answer.
Today I will show you how you build a rotating Plasma Stream in a bulb.
You can already watch a video of this machine.
More pictures and stuff you will find on my German Website Steampunk Design under "Werkstatt" and "Werkstatt / Plasma Wirbler".
Step 1Find the right camera
First of all you buy a disposable camera from Fujifilm or other one from the picture.
If you buy other models you will find inside an AAA cell instead of the right AA cell.
In this case the soldering points for the power output are on an other place.
After removing the paper you will find a plastic camera without any screws.
84 comments
1-40 of 84next »
Apr 19, 2012. 5:42 AMezarate says:
that is insane!
Feb 22, 2012. 6:54 PMpro5200 says:
so how to discharge the electrical load ?
Feb 22, 2012. 7:32 PMpro5200 says:
Hi,
I am a little confused to connect the wires, can you provide with schematic drawings ?
Dec 8, 2011. 2:55 PMtoasterburn says:
This has to be one of my favorite things on instructables.
Nov 14, 2011. 3:52 AMpositr_n says:
you can find a 2 pack of the right fujifilm cameras for under $10 at Walmart. I followed the pictures and this instructable worked out great. The transistor got a bit hot for me. Try holding an old CFL up to the neon bulb :D
Oct 9, 2011. 6:50 PMcberry3 says:
i love these light projects and i really want to try one but the only thing stopping me is the lack of a good explanation of the wiring. "you need to hook up six wires here" doesnt really help me too much especially where as i'm not all that good with electronics yet. maybe some more steps or a seperate ible on the subject?
Sep 21, 2011. 9:33 PMhalzark says:
You have this device working on a DC power supply. Will it also work on the 2 AA batteries? If so should I solder the batteries in parallel as Junophor did to increase the current and not the voltage?
Great project and pictures!
Oct 2, 2011. 9:17 PMApprenticeWizard says:
Power notes: duplicated with a Fujifilm Quicksnap DCF (disposable camera flash) in USA and a GE flicker flame bulb (PC 81167, Desc 3CAC/FF/CD1). Bench supply indicated only about 100-150mA drawn at 1.5VDC. Found that at 2.4VDC, current draw about the same. However, the transistor (D2687) went from an operating temp of 45C to ~125C. Did not go higher voltage than that. An alkaline battery can run 1.7V OC new, so 2 batteries could kill the transistor.
Note Kodak-brand flash units (so far) do not work - output voltage is only 325V, which may have something to do with it.
Anyone have specs on the transistor? I have only come vague indications that it may be related to a chroma-type transistor.
For what its worth.
Sep 22, 2011. 6:29 PMhalzark says:
I was thinking about mounting this to a costume, as a mechanical heart. (I can't attach the suit to the wall for the power supply! LOL) I have a separate power source for the turning platform (I'm using a revolving police light style base) but I want to use just the two AA batteries to power the plasma lamp and the three "sparking arms." Will this work?
Sep 23, 2011. 10:04 PMhalzark says:
thank you for the suggestions! Again, Great Looking Project!
Sep 25, 2011. 12:10 PMthethomas98 says:
Bridging the capacitor with a srewdriver will drain it, but it also could cause it to burst. I would instead use a resistor to bridge the cap. You can pick them up relatively cheap from a radio shack or electronics hobby store. I would bridge the capacitor with a resistor until you get no voltage readings with a meter between the two legs of the cap.
Sep 15, 2011. 9:21 AMgskaggs says:
Very cool.. Love it! Thanks for sharing.
Aug 27, 2011. 3:35 PMrstaron says:
Hello - Very nice instructable. One questions - what brand(s) of cameras are you using? Can't identify the one in the photo.......thanx.
Richard
Sep 7, 2011. 9:37 PMduggerpato says:
click on the "i" at the top left of the picture and it will take you to a page that lets you enlarge the photo. then if you use windows and firefox, just push "ctrl" and "+" and it will zoom in even more.
I believe you won't recognize them unless you know german though :)
Sep 8, 2011. 5:30 AMrstaron says:
Much thanks!
Sep 1, 2011. 9:49 AMbeehard44 says:
any chance this can create a resonance cascade?
lol nice 'ible
Aug 26, 2011. 2:47 AMbulletBird says:
This is really cool, but how does this have anything to do with clocks?
Aug 31, 2011. 2:48 AMSMarshall14 says:
it said clock gear i think its more of a time keeping device (it goes round at a steady rate)
Aug 27, 2011. 3:40 PMrstaron says:
My bad - I went too fast - it is a very, very interesting instructable and I will be using it in my class when teaching electricity.
Richard
Aug 26, 2011. 7:08 PMsunshiine says:
Super Instructable! You did an awesome job! Thanks for sharing.
Aug 25, 2011. 9:08 AMarpruss says:
Is it safe to bridge the capacitor with a screwdriver? I would think that it would be better to use a slower discharge method. Last time I was discharging a camera flash capacitor, I hooked up a multimeter set to measure voltage, and watched as the voltage went to about 10, and then bridged it for the last little bit. Took a couple of minutes, but it felt safer.
Aug 23, 2011. 3:41 PMundefinedmonkey says:
Excellent tutorial! I put a bulb & driver circuit together this weekend with very little difficulty (beware the capacitor.)
Thanks for posting this! What an awesome project.
Aug 22, 2011. 1:44 PMPKM says:
I think you're fast becoming one of my favourite makers- I love steampunk, high voltage, camera flashes and unusual lighting. With all the new uses you've shown I'm going to have to get some disposable cameras and get experimenting again.
Aug 18, 2011. 3:55 PMlhall1 says:
I too have ben shocked, on my thumb it was numb for 3 hours after words
Aug 17, 2011. 1:35 PMtheawesomeninja says:
I have no idea what this is but it looks @#$#$ AWESOME!!!!!
Aug 17, 2011. 8:24 AMshowup says:
Very nice
Aug 15, 2011. 11:18 AMfightthemachine says:
Beautiful work, I'm inspired to build a plasma bulb of my own, but I had a quick question... Would using 2 of the same circuit taken from the cameras make the light and sparks more intense? My idea is to have a single bulb powered by 2 circuits and then add as many moving arms around it to find a nice glow/balance, but as I would like to use 6 arms, I would think doubling the input to the bulb would be needed? Any thoughts on this, or perhaps you have tried it? Thanks alot!
Aug 15, 2011. 10:12 AMjonnyboy323 says:
Just one question, what kind of clock is the gear set and french hammer from? I thought hammers were only in alarm clocks, but I am no Horologist :) A picture would be awesome!
Oh an of course, I LOVE THIS PROJECT!!!! Your work is awesome!
Aug 13, 2011. 10:15 PMspark light says:
I really like this. it kind of reminds me of the excursion funnels in portal 2.
Aug 12, 2011. 2:40 PMLuftmechaniker Fritz says:
Great work dear Admiral,
as you might consider i would like to share some of your Plasma for my ray gun ;-))
Aug 6, 2011. 8:00 AMbertus52x11 says:
Nice one!
Steampunk from Germany? Mmm.., that's new to me, but very cool!
Aug 8, 2011. 3:28 AMHoratius.Steam says:
Hie bertus52x11,
yes its a bit new! But there is a rapid growing community in Germany, if you like have a look at:
www.clockworkers.de
http://salon.clockworker.de/
www.steampunk-design.de
www.steampunk-design.com
And of course, there are a lot of events, even the "makers fair" coming under licence in Spring 2011 to Germany as well.
Greetings from Germany (Hamburg)
JnEn aka Horatius Steam :-)
Aug 11, 2011. 11:53 AMBrittLiv says:
Makers Fair in Germany? How exciting is that, can you tell me more about it?
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
150
Author:Admiral Aaron Ravensdale(Steampunk Design)
My Website is NOW in English available!!!
