Playing Card Construction Set Using Cardboard Connectors
 by engineerable
Featured
Have you ever wanted to build a house of cards that wouldn't fall down?  This instructable will show you how to make connectors for regular playing cards, which will allow you to quickly build huge towers, and whatever else you can imagine.
The idea comes from the desire to build more stable, and creative structures using playing cards, using Tinker Toy style connector hubs. After seeing that Skallops had already done something similar, I was inspired to take it a step further and start making different connectors. The half round connectors are nice, but mix that with full round connectors, and you have an even better construction set.
Instead of wood, the connectors are cut out of cardboard from old cardboard boxes. This makes them light weight, free and disposable if they get messed up.
Step 1: Design the connectors
You can use any CAD or vector drawing softwhare to design the card connectors.
  1. Start with a Circle that is 35mm in diameter.
  2. Draw lines radiating from the center at 15 degree (or 30 degrees if you want a stronger connector with fewer angles)
  3. If the lines are spaced at 15 degrees, they should alternate between long (9mm) and short (4-5mm).  You only want a single line, because 1 pass of the laser creates the perfect amount of kerf to hold a playing card.
  4. If the lines are spaced at 30 degrees, they can all be long (9mm).
  5. Add a radius where the line intersects with the OD of the circle.  This creates a lead in for the cards, and will make them easier to slide into the slots.
Chrystalkay says: Jun 6, 2012. 1:13 PM
I was thinking of the perfect way to make a toy for kids for the yard. This idea is ideal! I will ise thin plywood for the 'cards' and thicker plywood for the spokes. Then they can build thier own play space! Any toy that uses imagination is great!
Small metal plates with metal or wood spokes, brightly painted would be an ideal indoor toy for growups too for the desk top or dresser as a changable organizer.
Thanks for posting this.
msraynsford says: Jun 3, 2012. 1:59 PM
Seeing this instructable in the weekly round up reminded me that I wanted to cut some of these for myself. Thanks for bringing these back round into public view again.
http://msraynsford.blogspot.co.uk/2012/06/skallops.html
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
