Remove these ads by
Signing UpStep 1: Gather your materials
*****UPDATE ON GLUEUP****
straight acetone works better for glue up of plexiglass, not to mention MUCH MUCH CHEAPER THAN CA adhesive...
just make sure you clamp it good.
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I just noticed the red neck contest entry. Is a perspex lettuce Knife not rather high end on the being sophisticated scale to be considered red neck?....... Deliverance would have been a whole different film if those rednecks had been carrying plexi-glass lettuce knives.... lol
Still voted though
The fountain of knowledge that is the interments once more providith the answer.
It certainly would make the turning more interesting if i could make perspex blocks. it would turn very well on the little metal lathe.
I recon you would get away with turning blacks laminated with CA glue on a pen mandrel as the mandrel would keep the blank in compression while turning. I picked a pen mandrel up on eBay last year for about 12-13 GBP inc postage, checking now the same thing is up to about 15 GBP now, Never used it to turn a pen yet but I have made a pipe and a few hollow spindles from laminated blocks. One of those tools you may not use that much but cheap enough to get as it expands your capabilities if you think outside the box.
I appreciate that video, i don't like the dry time, but i could make one hell of a nice segmented bow with this info... The place i got the scraps from has literally tons of scrap pieces of all different colors and thicknesses...
I will add, rubber band clamping gave a great bond, but i did get a few bubbles. When i clamped a block in the vice, no bubbles. So you still need to clamp, but it is in fact a much better, safer, easier to clean up, not to mention cheaper alternative to ca adhesive... Thanks again...
