Introduction: Pocket 256 Bit Logic Analyzer
This is a pocket size 256 Bit eight input digital analyzer for checking digital circuit functions that I built for my own use at home. It cost less than twenty dollars to build and it enables me to test switching circuit functions at slow clock speeds as well as I can check 256 bit counter outputs. This analyzer works well and is cheap to build.
Step 1: 555 Timer
Parts
- 1 555 timer
- 1 LED
- 1 2N3904 transistor
- 1 switch
- 1 50 k& pot
- 2 1 k& ¼ watt resistors
- 1 150 & resistor
- 1 33 uF 6 Volt capacitor
- 1 47 uF 6 Volt capacitor
- 1 proto board
- 1 8 pin IC socket
- 1 pot knob
- 4 feet or mounting posts
- Wire
Step 2: Operating the Analyzer
This analyzer works very simply, when hooked up to 5 volts power the green LEDs light up indicating high or the binary 1.
When the inputs are connected to a circuit or ground the green LEDs turn off and the red LEDs light up indicating low or the binary 0.
As the circuit the analyzer is conected to runs the LEDs switch from red to green indicating 0 or 1 on the input as shown on input #1 here in image #3.
Step 3: The Analyzer Circuit
- 1 red LED
- 1 green LED
- 2 150 & ¼ watt
- 2 18 k& ¼ watt
- 2 2N3906 transistors
- 1 inverter
However 8 inputs multiply the circuit 8 times that is:
- 8 red LED
- 8 green LED
- 16 150 & ¼ watt
- 16 18 k& ¼ watt
- 16 2N3906 transistors
- 2 DM74LS04 hex inverters
- 2 14 pin IC sockets
- 1 proto board
- 1 10 pin connector I used a 14 pin IC socket
- Wire
I looks more complcated then it is.
Step 4: The Analyzer in Operation
Make It Glow
Hack It! Contest
Instructables Design Competition
