3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Lathe
Pocket Lathe
Sometimes building small items requires small tools. This pocket lathe is 8 inches wide, 3 inches deep and 4.5 inches tall. Yes it does fit completely in my jacket pocket and cargo pants pocket.
Please note that there are some ideas for improvement posted at the end of this Instructable.
This started as a desire to make a miniature chess set
Step 1Order parts
Order parts
I disassembled an inkjet printer to get the motor that drives the print head. This motor has enough power for turning pine and other light woods. It is too weak for working with aluminum or copper.
The bearings and support blocks are from vxb.com
The gears are from sdp-si.com
I used some scrap pieces of ¼ inch hard board to make a base stand.
You will need 2 of the ¾ inch shaft supports part number WH12A
You will need 2 skateboard wheel bearings 608ZZ type
You will need drive gears or belt system. This is completely dependent upon your motor selection.
I used nylon bevel gears for a reduction in the motor speed 1:2 (24/48).
23 comments
Mar 9, 2012. 4:07 AMabstracted says:
it could work on light metals if u use a dremel as your cutting tools. i have used weak drills as metal lathes and a dremel...nice job btw
Jan 23, 2012. 5:10 PMa918bmxr says:
just a suggestion...
try adding a detachable tool rest to make turning things a whole lot easier.
Dec 5, 2011. 7:50 AMprofpat says:
i like it! very tiny and good for hobbyist!
Dec 4, 2011. 7:39 AMg_badhri says:
Simply super Work. thanks for sharing this your valuable idea. Thanks ;_)
Nov 30, 2011. 2:00 PMkristian2858 says:
i give you 6+++ for your work nice
Nov 29, 2011. 3:28 PMMatthewEnderle says:
Did you put a weight in the housing? It looks like it bounces around a tad bit. Even cheaper would be to cut the top of a mouse pad off and glue the bottom to the device, and then it would be quieter too because of less vibration resonating. Or better yet do both! I like it though. I might make a mini lathe too but i'll use an old drill motor from a 120vac 60hz motor!
Nov 29, 2011. 8:39 AMdimdiode says:
This is way cool, I really like it.
If it were me though, I think I'd take the lazy way out and buy a large diameter, self-centering chuck, like for an electric drill. I realise it may weigh too much for your rig, and it may limit the diameter of the material to be turned, but the benefit of self-centering may be enough of an incentive. I don't know, maybe it wouldn't work.
I guess I need to find out by making one of these myself ;)
Nice project, well done.
Nov 28, 2011. 5:48 PMItscrafty says:
Wow, the professionalism looks amazing on this, this looks like something i would go to menards to buy, great job on the looks alone. I cant believe how small this is and it has a nice amount of power, great job i give you 5/5.
Nov 28, 2011. 4:45 PMelectrowizard says:
Hahahaha,what an amazing little project!! I did notice one thing tho in your video, your lath seems to wiggle,as if it were unbalanced, I was wondering if this was just the video, but, what an awesome thing.
Nov 29, 2011. 5:48 AMrsmith6322 says:
Very nice work. I own a large lathe that I use for wood turning and something smaller for pens and such would be nice to have. You've given me some food for thought. We'll see what happens.
Nov 29, 2011. 3:46 AMpheenix42 says:
Oddly enough, your headstock and tailstock pieces look just like a sensor bracket that my paper folder at work uses!
Nov 1, 2011. 6:51 PMMatrix-technician says:
Wonderful project! My father has been a machinist for over 23 years and taught me the trade of metalworking. I can see this coming in handy on multipule occasions. I have been building balsa aircraft for a number of years and had to use either full size or benchtop lathes to mill some pieces, this would make it much easier to manufacture parts. Keep up the good work!
Nov 16, 2011. 8:48 PMMatrix-technician says:
Hi again! I would like to make a correction on my last comment. I phoned my father th eother day and it turns out he has been a machinist for over 33 years. (oops!) I try not to post misleading or incorrect info, but it happens sometimes to all of us.
Oct 31, 2011. 5:58 AMCementTruck says:
Impressive! I really like this build. Your 4 jaw chuck is inspired.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
194
Author:Random_Canadian
I seem to keep breaking things....
