Portable 12V Air Conditioner --Cheap and easy!
 by CameronSS
Contest WinnerFeatured
This project is my dad's $10 solution to a $500 solution to a $25,000 problem. As I have previously mentioned around the site, my Dad owns an electric 1979 Ford Courier pickup, and is cool enough to let me drive it around. We absolutely love it, and wouldn't trade it for a Tesla Roadster, but one of the few problems with electric cars is heating and cooling. In a gas car, heat is provided by the 80% of the gas that is wasted as heat, and air conditioning is provided by a crankshaft-driven compressor system. Many EVs use hair dryer elements and fans for heat, and some, ours included, feature a powerful gasoline-burning heater.
(Update from 4-22-08: I'd forgotten that I mentioned the gas heater on here. Last fall the gas tank and heater were removed, and a ceramic heater was built in. It works great, although not quite as fast, and doesn't use gas.)
However, air conditioning is trickier because the shaft of an electric motor doesn't always spin. Some have used a compressor driven by the motor shaft anyway, while others have turned a compressor using a separate motor. Finally, my dad came up with part of the concept for this system. It pumps ice water through an evaporator core, which has fans that blow air through it. It is very simple, but we found what we were looking for at Sporty's Pilot Shop. They sell air conditioners built into ice chests for prices ranging from $475 for a basic model to $625 for a 24V, dual fan model.There is also an ArcticAir unit for $4750 with a full compressor unit. However, we like our $10 version better. I saw the ArcticAir display at EAA AirVenture Oshkosh this summer, and our unit is more compact and puts out cooler air. All you need is materials, basic construction/assembly and wiring skills, and a bag of ice. Let's go!
Update, 5-12-08: 100,003 views! Yay! I'm no Kipkay, but I'm still proud.
Step 1: Background and How it Works
This project is very similar to the ArcticAir Package Unit. In fact, I attached two pictures of it I took at AirVenture this past summer. It looks almost identical to ours, and we built this without ever seeing a picture of the inside! The basic concept is to use a boating bilge pump to circulate iced water through a heater core, then use 12V fans to blow air through that core, which cools the air and pulls out water through condensation.
Advantages: Very compact and portable, lightweight without the ice, no environmentally not-so-friendly chlorofluorocarbons, hydrogenated chlorofluorocarbons, or hydrofluorocarbons, very quiet, and operates off 12VDC, AKA a cigarette lighter. The only disadvantage is that it the ice will melt after 30-60 minutes of operation, depending on the size of your cooler. However, it was built for an EV, so we are only ever out for an hour or two maximum, and the ice lasts longer when it's not running. The third image on this step shows the operation. Have I convinced you to build one yet?
1-40 of 548Next »
awawawaw says: May 15, 2008. 12:51 PM
Woohoo! I just bought my ice chest to start mine and have the fan mounted so far. My first one will be cooling my 86 Accord for the 95+ days in Sac, CA. The second will be a gift for my father-in-law for his almost completely restored 1969 Nova. Target has a really nice cooler that has a "compartment" in the top for cell phones, keys, etc. This compartment works perfect for a 4.5" muffin fan. When mine is complete, it will still look like an off the shelf cooler. Go to target.com and search for "Igloo Ice Cube 14-qt. Cooler ". Hopefully mine will be completed in a week or so. (wish I had it today.... 101 forecast!!!)
awawawaw in reply to awawawawMay 19, 2008. 12:09 PM
Just went to check something on my ice chest and it looks like Target.com doesn't have it anymore. The one that comes up as the Igloo Ice Cube is 17" cubed. Mine is only about 12" cubed. It looks the same though........ I put all my parts together and ran a test. With 4 cups of ice and about a gallon of water, the air coming out was 58 degrees. As soon as I finish modifying the heater core (soldering on elbows) I'll post pictures and maybe an instructable.
CameronSS (author) in reply to awawawawMay 19, 2008. 2:14 PM
Picture! Picture!
awawawaw in reply to CameronSSMay 19, 2008. 11:14 PM
Still prototyping, but here is an idea. Ford Escort Heater Core: new at Kragens for $40, shown with the ends cut short and elbows soldered on Attwood T-500 Bilge Pump: $17 at Walmart ComAir Muffin Fan, 12V, 102CFM, Free from the garage Igloo Ice Cube 14qt ice chest: $15 at Target Heater hose: free (going to change to vinyl tubing for flexibility) Rocker switches: free from garage, one for pump, one for fan AC Adapter for Testing, 12V, 4.5Amp: from the workbench So I am into this for $72 so far, but I am buying most items new . Hoping to finish by the weekend.............
rbfe4ch47 says: Aug 29, 2008. 9:37 PM
hey there cameronss, love the idea. in fact had to go out and build one myself. i made a couple of modifications to it. i put a vented drain cap on the top and put the fans so they blow on the heater core. the warm air then is blown over the cold heater core thru the chest and out the vent. i also added a little on/off switch to it. i fly on helicopters and it gets mighty hot sometimes, this was the perfect little idea to cool off with. thanks for the idea.
metaljoe0 in reply to rbfe4ch47Nov 11, 2008. 4:52 PM
in chinook helicopters we have a system that cools water, then pumps it through little tubes in a vest that we wear to cool you down. it works well in an aviation application where you will be sitting not moving for a very long time with lots of ambient air blowing all around.
CameronSS (author) in reply to rbfe4ch47Nov 13, 2008. 8:34 PM
Don't let the FAA see it, they'd probably yell at you for it not being TSO'ed. ;-)
I'm glad to see that another person built one, and even more so because it's in the application that KoolerAire was trying to gyp $500 for.
My air conditioner is in a helicopter! Yay!
03CR250 in reply to rbfe4ch47Jan 9, 2009. 7:12 AM
I was wondering about doing the same thing you are would it be better to blow into the heater core or is that just a theory cause id like to know i want to build a good one for my shop. also i considered using dry ice on those extra hot days to keep the water even cooler. we have a fridge in the shop so ice could keep coming and keep it cool all day. i might need 3 or 4 of these though its like 800 square feet. let me know what you think.
rbfe4ch47 in reply to 03CR250Jan 9, 2009. 9:56 PM
it is actually better to blow into the heater core. the fans are more efficient for blowing. i made another one for a guy that worked better when i used a flexible pipe for a dryer. i added another fan to that so that two fans would blow on the heater fan and the added fan would suck that air thru the dryer vent. the dryer vent allows the person to be able to direct the air to whereever you would like. if interested, i could send you some pics of this one. the are a blast to make and if you have a dremel, that will make life easy. thanks for the comment.
CameronSS (author) in reply to 03CR250Jan 12, 2009. 6:23 AM
You cannot cool your shop using ice that is frozen inside the shop. Ice is water that has had enough heat energy removed for it to solidify. If it is frozen in a freezer, all of the heat energy that is removed (and then some) is dispersed from the coils on the back of the freezer. Since all of the heat is being dispersed back into the shop air, you won't cool anything. Since your shop is stationary, you might as well just get a cheap window unit. It will blow cold air, but all the removed heat will be blown outside, and you won't have to replace ice and water.
xvitox in reply to 03CR250Apr 27, 2009. 5:17 AM
ummm dry ice= bad idea for anything like this...it wont work and if you seal up the area, as in to keep it cool inside, you fill the room with CO_2_ which brings about a very drowsy feeling. I know cuz that happened when I purchased Dry Ice one day and got stuck in traffic...and me and my girlfriend had the windows up. And it felt really good but we started getting sleepy.
ewind says: Oct 3, 2012. 8:57 PM
First of all, this is a fantastic instructable and I'm grateful that you shared it with us. Thank you.
I was wondering if I could pick your brain, get your opinion and what not. I'd like to use this concept, but marry it with the solar ice maker idea. And try to make it into a self-contained air conditioning system that could replace the AC unit for a 28' - 30' class C motorhome. Basically, it seems to me that I would need to scale down the solar ice maker and scale up your design to make it work. Would a 100watt solar panel be enough to run the mechanical parts in your design, do you think?
Could this design work with a larger heat element? Do you think it could cool a motorhome of that size (which is a relatively small space, usually about 95 - 150 sq. ft. of space)? The way I'm thinking is whatever melt ice is coming out of the heat element can be routed back to the ice maker, so it's essentially on this continuous loop with minimal amounts of water lost.
Anyway, sorry for the questions. This is a really exciting tutorial, though. Thanks again for posting it!
CameronSS (author) in reply to ewindOct 3, 2012. 11:37 PM
Between the bilge pump and the fans, they're rated for about 3A total. At 12V that's 36W, so if the solar panel is actually putting out 100W, that should work. Keep in mind that solar panels are often quite optimistic, and that output drops dramatically with clouds.
The basic design could be scaled to any size. I won't presume to make an estimate on how well it would work to cool a motorhome, but it could at least blow cold air on your comfiest chair.
I'm not familiar with solar ice makers. With the amount of solar panels you're talking total, I wonder how hard it would be to find a high-efficiency traditional air conditioner that you could run off those panels instead.
Electronic Goldmine says: Jul 23, 2012. 12:03 PM
Here's a heat sink assembly that may help the project:
Super Cooler! Peltier Heat Sink & Fan
http://www.goldmine-elec-products.com/prodinfo.asp?number=G19056
bryan3141 says: Jan 31, 2011. 10:26 PM
I'm thinking to myself: "self...why not just run the tubes through the top of the cooler and put the heat exchanger and fans in their own enclosure, thus eliminating the open icewater in the jostling car." I think I may follow that advice. I'm thinking 3 holes through the top of the cooler: cold water supply to the exchanger, used water output to the cooler and condensation return to the cooler...or, if I have a clean enough heat exchanger, maybe I'll run the consdensation collector into a drinking bottle...fresh cold water on a hot day is always a nice thing.
OGM in reply to bryan3141Jul 22, 2012. 8:22 AM
I made one of these a couple years ago for my plane. Unable to leave the lid open, obvious reasons, I reversed the fans. I bought a transmission cooler and filled the void space in the lid with foam. Other than that it is the same. I love the remote idea, it is genius. As the cooler sits way in the back, not great for the pilot and co-pilot. cars could place it in the trunk.
kharmsengine says: Sep 25, 2007. 3:19 AM
thats not exactly true, that screwdrivers dont do anything, someone i know was using a flatblade in a wreckless manner and managed to stab himself almost completely though his palm
sqeeek in reply to kharmsengineJan 28, 2011. 9:46 AM
Yeah, but the point is that it's easier with a drill. If you miss with a drill, you make a hole in yourself. Sure you can hurt yourself with a screwdriver, but you can just as easily hurt yourself with a fork, a pair of headphones, a pile of pebbles, or a kitten.
flamekiller in reply to sqeeekJul 21, 2012. 12:55 AM
The point should be this: use the right tool for the job. Sure, at a given pressure or striking force, a spinning drill bit is going to do more damage to your hand than a screwdriver (possibly debatable if, say, both strike at 35 newtons, but the screwdriver blade presents a much smaller surface area ...). However, if you are attempting to drill a hole with a screwdriver, you're much more likely to slip and gouge your hand in the first place.
It's kind of like knives: what's safer to work with, a dull blade, or a sharp one?
mysss in reply to sqeeekJul 31, 2011. 3:32 PM
In fact, it's much easier to hurt yourself with a properly used kitten than a properly used screwdriver.
cheetahflyer says: Jul 10, 2012. 8:02 PM
I made some modifications to mine including:
1) Installed cooling fans and connections inside the lid between the heater core and the top of the lid to keep it neat
2) Two large fans blow over the heater core into the ice chest
3) Added a small fan to blow the cold air out
4) Added a 4" corrugated plastic hose to direct air
Used it for the first time today in our 4 seat airplane. It worked pretty well, even in the 90 degree heat. Dropping the humidity in the cockpit made a huge difference!
I only filled the ice chest half way with ice, water, and a couple frozen water bottles. Next time will will fill it up higher...
explosivemaker says: Jul 5, 2012. 11:53 PM
Yes. It does hurt when you drill into your hand.
Don't use your hand as a clamp.
cardmarc says: Jun 27, 2012. 8:56 AM
I made basically the same thing but used a 48 qt cooler with drain, and I installed a duct louver with adjustable lever for air intake control. But I got a cheap 4" Attword 12v bilge pump blower and connected it with 4" hose dryer tubing to the outlet of the radiator. 5 amp total draw. In any case, thanks for the lessons.
I put this cooler together for a total of less than $150 .
I had the 12V 230 cfm 4” bilge blower fan (~$30 now, Attwood 1741), a junk car 5”X7”X ~ 2” cabin heater core (~$15???), 4” dryer hose/clamps, wire, connectors, misc parts and pieces.
I purchased a 12V 500 gph bilge pump (Wal-Mart Attwood 4606-7, $18.66), some ¾” hose, a few clamps, a 4” dryer adaptor, some fuses, the intake HVAC diffuser with control lever (Home Depot aircraft supply), a 12 V on off switch, & the 48 qt cooler box with drain (Walmart, $25). Total about~$86 incl tax
It took about 5-6 hours to put together. Worse thing was cutting the insulated cooler to fit the parts in. I used construction adhesive and SS wire/screws for most of it. Total cost<$150+ my time as an educational endeavor.
On a 104F TX day (today here), it cooled the air to 65F until the pittance of water/ice from the refrigerator test ran out. (I didn’t purchase a couple of ice bags-will test that next-you put about a qt or so of water in to get the pump/exchanger to work).
4” Fan draw at 230 cfm=3.5 A at 13.6 V; 500 gph bilge pump=1.5 A. I used a 7.5 A fuse.
ironjudas says: Sep 5, 2011. 1:27 AM
Dry ice cant be put into water it will dissolve in seconds. Btw, do you need to keep supplying it with ice?
pddonovan2011 in reply to ironjudasApr 22, 2012. 11:02 AM
I have an S10! I would put the cooler in the toolbox, immediately behind the cab, and run the tubes into the cab with major insulation on both. Use a small high performance oil cooler in the cab and a cheap one in the cooler as exchanger. Use a small (One quart) plastic container as a surge tank, put a pin hole in the cap and leave two inches for sloshing. Fill with 50/50 Coolant and water, place exchanger on the bottom of the cooler and cover with dry ice! Cooler is outside the cab, cooling radiator is lower than the cooler (easier on the pump, a smaller one could be used and in the cab, making more room for dry ice!) Place the cooler in a box with three inches around it and pour in expanding foam to hyper insulate the cooler! I think this would make a really cold A/C unit!
This is a really great Instructable! It really got my creative juices flowing, thank you so much for that!
In the teardrop, if you are camping next to a stream, you can use two long hoses and a funnel to catch the water flow, divert it to the Teardrop where the pump can take over and pump it up into the teardrop. The teardrop is cooled and then the water is returned to the stream! Call it a "Gone Green A/C Cooler!" Hey, come to think of it, that would supply the Teardrop with a source of water that could quickly be purified using a ceramic filter for consumption!
Redstormx1 says: Mar 11, 2012. 12:25 AM
http://www.instructables.com/id/Home-Made-Freezer-Box-FridgeAir-con-/
hagrawal3 says: Nov 5, 2011. 11:16 AM
hey i have also made an a.c. com. heater and it works great!!!!!
DSCN1632.JPGDSCN1633.JPGDSCN1634.JPGDSCN1635.JPGDSCN1636.JPGDSCN1637.JPGDSCN1638.JPGDSCN1639.JPG
2be994510 says: Oct 23, 2011. 7:42 AM
CameronSS: Nice work! I have read most of the comments and found them interesting. We are in the process of building the unit now with some modifications. If it works well then we will go to a larger system. Best wishes from Thailand
deac02 says: Sep 19, 2011. 11:43 PM
If creating ice is a problem and not green why not build a solar ice maker. Add in a solar charger for the battery and bang, boom it is almost self sufficient. Cool.
twarner1 says: Sep 14, 2011. 1:48 PM
The alternative to having this machine is having the existing AC fixed, which costs not only much more money, but is also more harmful to the ozone. A oil fueled Chlorofluorocarbon machine in essence!
DIY Dave says: Aug 31, 2011. 11:38 AM
Sorry if I missed something, but how do you keep the water from splashing into the fans?
CameronSS (author) in reply to DIY DaveAug 31, 2011. 11:41 AM
The heater core is between the fans and the water. Splashing isn't a concern unless you knock it over.
DIY Dave in reply to CameronSSAug 31, 2011. 1:57 PM
Thanks for the quick reply
showbizkid83 says: Aug 31, 2011. 7:57 AM
Can dry ice be used as a cooling tool.
guitaristjosh83 says: Aug 27, 2011. 10:02 PM
i could probably find the answer to my question if i were to go through and read every single comment... but can you please tell me a quick and easy answer? should the fan(s) blow down through the heater core and into the cooler, forcing air out from under the cooler lid, or should the fans blow upward away from the cooler, sucking cooled air that passes through the heater core? i need to know which works best (not in theory, but in actual use and testing) before i build mine. thanks.
Hunter Wolf says: Jul 31, 2011. 6:16 PM
Question: Would this cool a 10x10x8 (LxWxH) foot room?
CameronSS (author) in reply to Hunter WolfAug 24, 2011. 8:20 AM
Much larger than a car/truck cabin. Much better-insulated than a car/truck cabin. It would become cooler, that much is inevitable. How much and how long would depend on what exactly you built.
asiddiqui attari says: Jul 16, 2011. 10:54 PM
What shall be the size of heater core and whether it should be a 1line heater core or 2 line heater core.
Is there any substitute for heater core?
CameronSS (author) in reply to asiddiqui attariAug 21, 2011. 8:05 PM
As big as it needs to be to fit.
Doesn't matter.
Coil of copper tube? Anything like that.
tazz1781 says: Aug 16, 2007. 5:05 PM
While its a great project, its not all that green. For example, where does the ice come from? A machine that produces heat to make Ice and uses harmfull gases to do so. So, for the continued cost of the ice, whether buying it daily or having your ice box run more so you can provide your own ice, your really not saving any money or the enviroment.
1-40 of 548Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
