Purgatory Burgers
58,694
381
69
Published
Introduction: Purgatory Burgers
About: I like to divert stuff from its intended use. Most of my crafting is based on re-use and recycling due to my urge to use resources consciously (and my small wallet). As I like to consume ideas rather than pr...
This is a recipe for burgers and buns that look like roasted on hellfire...
I got the inspiration for this recipe when I stumbled across an article about a Japanese food trend: Black hot dogs and burgers. The pictures were stunning and I was very intrigued to try to replicate the buns and burgers. The article mentioned the use of bamboo charcoal for the black food. I couldn't find bamboo charcoal here - but came up with an similar solution and I'm pretty happy with the results.
I think these black burgers fit not only for Halloween - I bet you could find use for them at the first of April as well...
Step 1: The Magic Ingredient
I couldn't find bamboo charcoal and had no desire to use artificial food color.
So I decided to experiment with medicinal charcoal a.k.a. activated charcoal.
Medicinal charcoal is traditionally used to treat diarrhea and poisonings. In the European Union it is also used as food colorant (known as additive E153). You can buy activated charcoal at the pharmacy.
So far I made the black burgers two times, I used two different products: charcoal tablets and charcoal powder. I bought both at local pharmacies. The recipe worked with both, but I recommend the powdered charcoal, it's easier to handle and also cheaper (50 grams where about six or seven Euros). The tablets also gave the burgers a slightly sandy mouth feel (The tablets consist of charcoal, bentonite and cornstarch, I think the bentonite caused the sandyness...)
When I bought the charcoal I asked the pharmacists about side effects and they told me to keep in mind, that medicinal charcoal could interfere with other medication and cause constipation.
Which means: If you or your guests takes medication you probably should skip the purgatory burgers (or talk to a pharmacist/doctor first)
People with digestive problems probably should as well rather stick to burgers from heaven...
(If you follow the recipe you consume 1,25 grams charcoal in one burger.
- to treat poisoning with charcoal you have to consume 0,5 to 1 gram per kilo of your bodyweight (for example a 150 pound person would have to consume between 35 and 70 grams of charcoal...
- for treating diarrhea the daily dose is 1,5 to 4 grams)
I never had any trouble after eating purgatory burgers (but I never had more than two at a time).
If you are concerned about the effects of charcoal consumption you should ask your pharmacist about it.
These wikipedia articles may give you some information as well: Activated charcoal and Charcoal biscuit
IMPORTANT: Please handle the charcoal powder with care. The charcoal powder/dust shouldn't be inhaled!
ALTERNATIVES: Instructables member hughw99 suggested the use of squid ink instead of charcoal. You may not add additional salt when using squid ink, since it is already salty as he mentions.
Step 2: Bun Ingredients
The amounts I'm giving here are for just four burgers. You can of course double or triple the amounts if you need more...
To make the burger buns you'll need:
For the dough:
- one and a half and a quarter cup (250 grams) Flour
- one teaspoon dry Yeast
- half a cup (125 ml) of warm Water (not warmer than a hot shower - if the water is hot enough to burn you it will burn your yeast as well)
- one and a half tablespoons of Sugar
- half a teaspoon Salt
- one teaspoon Medicinal Charcoal (2,5 grams) (this equals 10 tablets of the brand I used)
- two tablespoon of Apple juice (or Water)
For the bun topping:
- Black Sesame Seeds
To brush the buns after baking:
- one tablespoon of melted Butter
Step 3: Dough Preparation I
Put the flour into a bowl.
Mix the warm water, sugar, yeast and salt.
Add the liquid to the flour and let it just sit like this until the next step is performed.
Step 4: Dough Preparation II
I dissolved the charcoal in a tablespoon of Apple juice (I like the taste, you could use water as well). If you use charcoal tablets you should smash them in a mortal before you dissolve them.
Add the charcoal slurry to the flour in the bowl and mix everything.
Knead the dough for about five minutes (you could use a machine or do it by hand)
Cover the bowl and let the dough rest at a warm spot. Depending on the temperature it takes about an hour for the dough to double in size. (The dough NEEDS to double in size.)
Step 5: Bun Shaping
When the dough has doubled in size you can continue with the bun preparation process.
Take the dough and knead it again.
Divide it in four parts.
Shape them into buns and place those on a baking sheet, covered with parchment paper.
Wet the buns surface with water and sprinkle some black sesame seeds on top.
Cover them with a clean tea towel and let the buns rest for about 45 minutes.
Step 6: Bake and Add Glow
Bake the buns in the preheated oven:
375° F / 190°C for 15 to 20 minutes
You might want to check on them after about 15 minutes. Since they are black it is kind of hard to tell when they are done...
Edit: Instructables member t.rohner made a great suggestion in the comments: Take a part of the uncolored dough to make a white control bun. Bake it together with it's black siblings. On white bun you will easily recognize the browning process and therefore find the right moment to turn off the oven!
Brush the hot buns immediately with some melted butter and let them cool down completely.
Step 7: Black Bean Burger Patties Ingredients
You probably could use the charcoal to colorize real meat - but I've never tried this myself.
I made black bean burger patties for my black buns. I added charcoal to the mashed beans because black bean burgers naturally just have a brown color.
I used dried black beans since I couldn't find canned ones.
You need:
- half a cup of dried black beans
- one teaspoon activated charcoal
- one teaspoon of olive oil to fry the onions and about one tablespoon for frying the patties.
- one onion, diced
- one (or more) cloves of garlic, mashed
- one egg
- two tablespoons of breadcrumbs
- one tablespoon of soysauce
- about one teaspoon each of: ketchup, mustard, hot sauce, powdered paprika and cumin
It seems to me like the charcoal absorbs some saltyness and spicyness - the flavors aren't very intense in these burgers. You might add a little more spiciness to them than you usually would.
Step 8: Black Bean Burger Patties Mixing
Meanwhile you can prepare the bean burger meat:
Take half a cup of black beans and cook them in three cups of water until they are done, maybe almost overcooked.
I used a pressure cooker and it took just 30 min but the time very much depends on the beans, it can take up to an hour... and even longer without an pressure cooker
The half a cup of dried beans resulted about one and a half cup of cooked beans.
I use just one cup of cooked beans for the patties.
I mashed the beans with a fork.
I fried the diced onion and the garlic in some olive oil until they started to brown and added them to the bean mush. Then I mixed in all the spices, the egg and breadcrumbs and the charcoal.
This mixture gave me a nice and shapeable dough which I formed into patties.
Step 9: Black Bean Burger Patties Frying
I fried the patties for about 5 minutes on each side on medium heat.
Step 10: Assembling
I'm pretty sure you know already how to assemble a burger. So just follow your instincts.
I used tomatoes and lettuce and a fair amount of hot sauce - since I think burgers from purgatory need to be hot ;)
Step 11: Further Reading
If this instructable sparked your interest in monochromatic food you should read this instructable to get even more inspiration.
Or you could take a look at the work of the fabulous artist Sophie Calle. Her work "Chromatic Diet" is based on monochromatic meals (the rest of her oeuvre isn't about food but well worth to look into!).
Halloween Food Contest
Second Prize in the
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    69 Comments
    I followed the instructions to the letter. With 1t charcoal, the dough was very light grey, nothing like what the pictures show. I then added 1T charcoal and the buns came out nice and dark, but when I baked them the texture was gritty. It was like eating food with sand in it :( I used activated charcoal that came in the form of a very fine powder (it looked finer than the one in the pic and definitely finer than what you would get by crushing pills). Does anyone have a happy medium that would produce buns that are black, but without the grit?
    I'm sorry to hear your burgers turned out sandy.
    Did you dissolve the charcoal in some liquid before you added it to the flour?
    Other than that I have no clue what could have went wrong...
    I did, but charcoal doesn't truly dissolve in water. Even the grey buns (with 1t charcoal powder) tasted sandy. Incidentally, did your buns turn that black with only 1t???
    You should make your own charcoal, or just grind up like chunked charcoal. They sell it for grilling in the states ie not briquets. You want to avoid the binders which is the cornstarch and bentonite clay. :)
    You can avoid the binders by using the charcoal powder instead of the tablets.
    I don't think grilling charcoal is really a foodgrade product... But you probably could make your own charcoal like in these instructables here or here.
    I don't think it matters. char is char. I think it is called lump charcoal. The easiest way to do it for a small scale, is to get like a pot with a lid, chunk up pieces of wood and bake it in the fireplace. (you need to let the gas escape as the gases can be dangerous, but you don't want to let air in. Plus you will smoke up the kitchen if you do it in the oven. :) ) You also get tarry residue, so use an old pan or container. The best container I have seen for fireplaces is actually a metal drafting or welding rod tube with the slide on top, and holes poked in one end.
    Well, I think it does matter. By "char is char" I think you mean "carbon is carbon" but "all charcoal isn't the same charcoal." Different substances may be charred. For example, I used to use vine charcoal sticks to draw in art class and we were told they were made from willow sticks and grape vine clippings. But I know wisteria is also used to make drawing charcoals and I wouldn't eat wisteria.
    Activated charcoal could have sorbitol in it. That is a sugar alcohol like xylitol. I can't each much of that without it having a laxative effect.
    Maybe try checking a reputable medical site like the Mayo Clinic site before you do anything.
    I found the following link, too. It presents some information about charcoal the carbon and the after products. Please be careful.
    http://motherhood.modernmom.com/can-ashes-charcoal-briquettes-used-fertilizer-13936.html
    Activated charcoal is pure carbon and is heavily processed to remove inpurities. Heavily burnt substances can have dangerous carcinogens like acrylamide. Commercially sold grilling charcoal cab have petroleum substances. So these would be removed in the process of making pure carbon charcoal.
    Oh, goodness, no! Please do not make your own charcoal, or grind up regular charcoal for cooking, and mix it with food. That could be very unhealthy. Even the activated charcoal can be dangerous, as pointed out here in this Insteuctable.
    You can make activated charcoal, which I suppose would be as edible as the kind sold in drug stores. But you would have to be very, very careful to make sure that it is safe.
    I read some place that they use squid ink in these burgers.
    good point :)
    Another warning about charcoal powder: It may be somewhat explosive if spread in air. Have this in mind and take precautions while grinding etc.
    Cool looking burger, no doubt.
    to be far, flour is also explosive if spread in the air ;)
    Indeed. I just felt the need to mention it, because I once had a small mishap while grinding charcoal that I was going to use as colorant in soap. It seems, however, a little more "aggressive" than ordinary flour.
    I'm pretty sure the black coloring from the Japanese burgers are squid ink buns
    That's what I figured, just like gourmet black pasta. Btw, people will say that squid ink is flavorless, but I can taste it, and like the mild zing it adds.
    Thankyou for your e-mail. Referring to the burger from Hell, I read the instructable very quickly. Thankyou for your info.....but, even so, isnot charcoal flavoured buns, toxic? Charcoal is composed of burnt bits of wood pieces, isn't that so?
    Activated charcoal is basically pure carbon. About as non-toxic as it gets.
