Put a 19in Tv and Game Console in Your Car
426,766
687
64
Published
Introduction: Put a 19in Tv and Game Console in Your Car
About: I'm 15 and have been working with electronics for about five years. I have been helping my dad fix thing's and make stuff for as long as I can remember. I'm am always learning something from my dad. I hope t...
My family is planing a trip to yellow stone and it will be about 36 hours of driving round trip. So I made a mount for a 19in tv and a away to power the tv and my Xbox.
Step 1: Mounting the Tv
To mount the tv we got a metal bar laying in the yard.the bar must be about 7in extra from the out side of each handle that you use for getting in and out of the car.
Step 2: Flattening the Bars Ends
When flattening the ends we used a sledge hammer, make sure you take your time and do it even. Get it as flat as you can it will be hard to bend if you don't.
Step 3: Bend the Bar
Bend the bar around something about the same diameter as the handles in your car, we used a 2in aluminum pipe.
Step 4: Test Fit
We put some foam so the handle didn't get cut and messed up. Than you should be able to bend it over the handles with your hands.
Step 5: Look at the Screw Pattern
My TVs screws were 3in by 3in apart.
Step 6: Something to Screw the Tv on To
For the part the tv hooks to we used some square tubing from a chair that was missing parts.
Step 7: Getting the Part Off the Chair
Grind the heads off the pens and the part should just slide off.
Step 8: Hooking the Square Tube to the Main Bar
Put the extra from the main bar on the square tube mark it and than cut it with your grinder.
Step 9: Drilling a Hole in the Square Tube
Drill a hole in the square tube but not you metal bar yet, and snap it on so you can make sure it fits .
Step 10: Drill the Holes Your Tv Will Screw in to
Have someone hold the tv up to. The middle of the bar and how high you want the tv, than you mark the holes that your going to screw the tv to.
Step 11: Screwing the Square Tubes to the Tv
Put a piece of rubber to put in between the tv and square tube. Get 4 bolts and lock washers we went to miners they have a good amount of hardware.you also need to drill holes on the main metal bar and bolt the square tubes to it.
Step 12: Power
Add up the wattage of your tv and what ever you will hook to it, in my case the Xbox is 145 and the tv is 45 so That's 190. You will need a inverter that's higher than that number. If your wattage is more then 80 witch it probably is, you will need to run a plug with big wires like you would for a car stereo amp, this is because a average lighter plug has small wires that can only handle 80watts and your inverter will shut off if you are running more than 80watts.
Step 13: Make a Plug
We used about 12 gauge wire and it runs the inverter just fine, I put a small hole in a rubber plug that go's behind the center console so you open the center console and plug the inverter in.
Step 14: Stop the Tv From Shaking.
When testing the set up the TV shook a little bite,so I cut a piece of PCV and put it under the metal pipe.After that the TV was rock solid.
Step 15: Done
It takes about 15mins to set up and runs movies video games and even Netflix if you have a hot spot on your phone or something.it took me and my dad a weekend to complete we could of finish in a day but we were doing other stuff to.
Step 16: Back From the Trip
Well we got back from the trip,we drove a total of 3000mile which is about 50hours of driving. We probably played games and watched movies about 20hour. There was never a problem while driving, even when driving from the desert at 75mile per hour with the ac on.The only thing you have to think about is if you turn off the car to get gas or some thing,you will need to pause the game and turn off the tv . Otherwise when you start the car some times your xbox will shut off.
Weekend Projects Contest
Second Prize in the
Cars & Motorcycles Contest
Runner Up in the
  • Make it Move Contest
  • Oil Contest
    Oil Contest
  • Casting Contest
    Casting Contest
64 Comments
I'm adding a similar set up for my road trip. 19" tv and PS3. For the day or two use, is the battery connection necessary? If so, what do I do with the end that is not connected to the battery?
Thanks
It's a great idea in theory but it just doesn't seem practical. Previous users have mentioned the Xbox disc movement issue. Another problem that could arise is the TV will be experiencing a lot of vibration the way its attached to the mount. If I were you I would add more rubber in between the TV mount and the bar that holds it up. Great idea though just needs a few modifications!
That's because the power supply only give 300wats. Quite low for Xbox ...
A Xbox doesn't nearly use 300 Watts. Not _nearly_ that much.
Actually it uses just shy of 225 watts... It requires 100 volts to power the Xbox 360 and Xbox one and 300 watts would give off around and 150V AC so yes it uses that much.
Correction. It only requires 12 volts DC. The AC adapter takes 120 volts AC and rectifies it to 12 volts DC. It draws 10.83 amps at full draw. So given that VxA=Watts, this means that it would draw approximately 130 watts at max draw.
Finally someone makes this. Okay how did you calculate the power reqts? Ant idea how it would affect the car battery.
Calculating the power usage is easy. Just multiply the voltage with the amperage (is that a word?). Car batteries are not made for constant power delivery, instead, they are made to deliver a lot of power in short bursts. So it would affect the battery's lifespan, just not so much.
Nicely done, all the negative comments are to be expected, as they did not think of it. All you have to do is look at all the cars that have tv sets in the headrests, custom cars, vans, buses, they all have them. But you have really made it easy for the common person to have. Again Great job, keep up the good work. And just over look the bad comments. Nicely done.
These are not hate comments, there are genuine safety concerns.
Rather than an Xbox which has documented issues with scratching discs when the console is moved, is there not a different console you could use? If I were to do this, I would seriously consider using something like an OUYA or an Android Stick to plug in to the TV HDMI - no scratched discs!
You can download games onto a Playstation's hard disk from the PS Store. Combine that with an SSD and you have a system with absolutely no moving parts except for the fan!
If I'm not mistaken, most all Televisions actually operate on DC current; that's why you find a transformer inside them. A friend lived in a camper that was "off the grid" before it was fashionable, or even thought of by most people. He converted his stereo, reel to reel tape sound system & TV to operate on 12VDC simply by wiring around the transformers to 12VDC instead of 110VAC. (Yes, he did have to charge the batteries, but when AC power went off, it didn't affect his listening or viewing pleasure). check the schematics of your equipment, I bet it can be done even with teh newer products of today.
This is true, and in fact way better for the electronics. Using these crappy converters is not great with such delicate equipment as computers and TVs.
all right so if you just put a internet router with it and put the internet cable in your console. BAM intstant internet
You do realise that a modem needs to be connected to the internet through a cable?
