3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rain Tarp Design
Rain Tarp Design
Stay dry camping.
This is the best rain tarp design I have found in my years of camping.
Step 1Tarp Design
Tarp Design
The main concept of this tarp design is to have a tight support rope under the tarp between opposite corners. The tarp needs to be attached to the center support rope but it should not be pulling on the tarp when the center support rope is pulled tight. This is done by tying a 1 foot loops in the rope where the tarp corners will be. The loops are tied through the corner grommets and adjusted for tension. The center support rope should be tied tight at 10 - 12 feet above the ground to give you plenty of head room. The other two hanging corners can then be tied with ropes and pulled out. The corner ropes should be lower than the center rope and tied with little tension.
28 comments
Aug 19, 2011. 5:44 AMowenlavery says:
I gave this instructable over this weekend a chance and it worked out great. I have one question though. When attaching the tarp to the two "loops" what knots are you utilizing and are they tensioning?
Mar 9, 2010. 1:10 PMswizzle says:
If water running down the main line is a problem then just tie to short pieces of jute twine, para cord or whatever around the main line just under the tarp. Leave a little bit hanging. The water will run down the main line and hit the knot and drip off there. Swiz
Aug 13, 2009. 11:41 AMredsuit09 says:
this really is a great design... i have been trying to figure out a way to hang a tarp above me when i go backpacking with hammocks
Jun 25, 2009. 6:34 PMabadfart says:
this would be great for cooking
May 16, 2009. 10:09 AMYerboogieman says:
Northwest Profile #60 Blue tarp camper.
May 3, 2009. 8:35 AMespdp2 says:
You'd be surprised how dry you can stay, even in a downpour. My light fighter buddies still use this method in the Army. Not perfect, but you can't carry perfect on your back anyways. We weathered many storms, and only got soaked because water was running on the ground. This is the also hot ticket for a hammock cover. Good sleeping.
Sep 14, 2007. 9:38 AMshmacky26 says:
There's no way you could stay dry under there, especially in a hard rain. Water would run down the rope from both sides and then drip at the lowest point, which in this case is dead in the middle of the inside of the test. This would be an ideal set up it the ropes sloped away from the tent and there was some sort of peak in the middle.
Dec 18, 2008. 11:43 AMden8246 says:
shmacky26: Your right about rain running down the center rope. The loop knot just outside the tarp on the center line act as a water stop(not 100% but a lot). Gravity lets most of the rain drip off the rope outside the tarp. Shock cord at all corners helps a lot. But camping in a thunderstorm is for extremist...
Sep 5, 2008. 6:10 AMlwooly says:
Thanks a million...single mom of two had no problems putting this up. I just scratched the design on paper before we left for camping. I did have to climb 2 trees though!!!!
Jul 23, 2008. 7:44 PMreiver says:
We tried your design this past weekend, and it worked great! It was very fast and simple to set up, which worked out well because we were only 30 minutes ahead of the rain.
Sep 2, 2008. 12:23 PMstone3408 says:
Yup the best way to put up a tarp shelter by far. I have one set up on my property for when it rains. It has been dry for almost a year now.
Aug 23, 2007. 7:54 AMFunkLiberationFront says:
Awesome, I want to try this with the instant hammock. It would be cool if we could get a "Camping" tag for Instructables.
Jan 12, 2008. 2:49 PMHAL 9000 says:
I have been sifting through camping instructables and adding them to my group, the Happy Campers Club. Check it out if you like, but i agree there should be a Camping tag...
The instant hammock, by the way, is an awesome idea. I have one in my bedroom. If you like it check out my Hammocking instructable, How To Backpack Better With A Hammock. Aslo, feel free to join the group, the more the merrier!
Sep 14, 2007. 9:39 AMshmacky26 says:
Inside of the "tent", not test.
Jun 8, 2007. 1:17 PMDog_Man says:
I got lost in step 1. I don't understand about the loops. Does the rope that runs between the two trees in the drawing run all the way under the tarp or is it two ropes tied to the gormets? Also, if it is really windy would bungy cords between the gormets and ropes help prevent rips and blowing down?
Jun 9, 2007. 10:01 AMDog_Man says:
Thanks Jaaaaayyyyy. I was thinking of the shock cords on the other 2 ropes. As a former scoutmaster, we found they helped on tents.
Jun 8, 2007. 9:46 AMsleeping_gecko says:
This is great!
Jun 6, 2007. 12:12 AMdchall8 says:
Now if you hang your Instant Hammock from the same trees at the same location, you have a nice rainproof place to sleep. You might want to lower the height of both the hammock and rain fly if you don't trust yourself in a hammock.
I see you use my favorite pink polyester rope. I have easily used 1,000 feet of that in the past 20 years. It is great because it never stretches like ALL nylon rope does.
I'm having trouble understanding step 5. Can you add pictures or diagrams?
Can you use a larger PVC pipe (1.25 inch) and a regular connector instead of the heavy metal and welding up a connector?
Jun 6, 2007. 10:38 AMhowboutitbru says:
in step 5 he is attaching the rope to a stick then throwing the stick over branch, a branch whihc is about the height we wants the rope then ties off the rope
Jun 6, 2007. 10:39 AMhowboutitbru says:
dont correct me on spelling it pisses me off
Jun 6, 2007. 8:54 PMRobotrix says:
this is what my dad came up with too. We do it with a huge tarp and it's our kitchen shelter. Best way to make a roof and easy to add walls too!
Jun 6, 2007. 2:26 AMthematthatter says:
we hang rocks off of ours if it starts to puddle.
Jun 5, 2007. 10:53 PMStepsoftheSun says:
Awesome... a well-written (and well-modeled) useful idea.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:jaaaaayyyyy
