Introduction: Raspberry Pi 2 Media Center: Kodi on XBian
Picture of Raspberry Pi 2 Media Center: Kodi on XBian
Author: Timothy Wood
Date: April 2015
Overview
This guide walks through the construction and configuration of a home media center from parts to running system. After following these steps, you will have a running Kodi media server on a Raspberry Pi 2 in an Altoids tin case, ready for you to attach a thumb drive or hard drive with your media. These steps detail the method I used in my build with the hardware and software choices I made, but there are other options that you can choose. I included some notes about alternative choices in the steps where alternatives are available. Although the steps in this guide are specific, you should be able to adapt the general method for some of the alternative choices.
I chose to use the following components and software.
  • Raspberry Pi 2 Altoids tin case
  • Xbian 1.0 Release Candidate 2 operating system
  • Remote control input via IR receiver wired to GPIO
When I built my media center, I did most of my work with the Raspberry Pi 2 plugged into a desktop computer monitor and set of speakers. These steps could have been done while plugged into an HDMI capable television.
About This Project
Difficulty: Moderate
Total time: 5 hours (rough guess). 2 to 3 hours if you do not set up a remote control (Step 6).
This project requires prior experience with
  • Dremel to cut metal
  • Linux command line and configuration files (for Step 6 only)
List of steps
Step 1: Gather Parts
Step 2: (Optional) Work around “Xenon death flash” bug
Step 3: Make a case from an Altoids tin
Step 4: Download XBian onto a MicroSD card
Step 5: Install XBian on the Raspberry Pi 2
Step 6: (Optional) Install and configure infrared remote control capability
Step 7: Updates and next steps
The instructions in Step 6 enable the media center to accept commands from any remote control you have or purchase. I bought a remote control at a thrift store. If you have a television that supports HDMI CEC (Consumer Electronics Control), you do not need to perform Step 6. Instead, you can control the media center with your television's remote control without any additional configuration required.
Software
Kodi – A free and open source media server and entertainment center. Formerly XBMC. http://kodi.tv/about/
LIRC – Linux Infrared Remote Control. A software package that decodes digital infrared signals of most commercial remote controls. Included by default as part of XBian. http://www.lirc.org/
XBian – A GNU/Linux based operating system for the Raspberry Pi, Raspberry Pi 2, and other small computing devices that runs the Kodi software. http://www.xbian.org/what-is-xbian/
Step 1: Step 1: Gather Parts
Picture of Step 1: Gather Parts
Before beginning this project, be sure you have all the parts and tools needed.
Parts
  • Raspberry Pi 2 model B
  • Empty Altoids tin
  • MicroSD card (at least 2 GB)
  • AC to microUSB power adapter for the Raspberry Pi 2(output 5 volts, 1 to 2 amps)
  • Ethernet cable
  • HDMI cable
  • Television with HDMI input or computer monitor with HDMI input and speakers
  • Remote control
  • Three female to female jumper wires, about 20cm long
  • Vishay Semiconductor TSOP 38238 IR receiver
Tools
  • Duct tape or electrical tape
  • Mounting putty (optional)
  • Scissors or pocket knife
  • Permanent marker
  • Dremel with metal cutting bit
  • Metal file
  • Computer which supports MicroSD cards and has SSH client software (Step 6 only)
  • USB keyboard USB mouse (optional)
  • Hot glue (optional)
Alternatives
Instead of using the Raspberry Pi 2, you can build a media center using an earlier version of Raspberry Pi. Prior to this project, I completed a similar one using a Raspberry Pi model B rev. 2. The advantage of the Raspberry Pi 2 is that it has a faster processor and more memory, which should make the media center load and respond faster.
In addition to XBian, there are several other operating systems to run Kodi on the Raspberry Pi. See Step 4 for a list of other current software distributions.
Step 2: Step 2: (Optional) Work Around “Xenon Death Flash” Bug
Picture of Step 2: (Optional) Work Around “Xenon Death Flash” Bug
The Raspberry Pi 2 has a peculiar bug which causes it to power down when exposed to intense flashes of light of certain wavelengths, such as those of laser pointers and xenon flash bulbs. Although this will not damage the Pi, a running system could experience data corruption. This only occurs under particular conditions, so if you do not expect to take flash photos of the board with a traditional xenon flash bulb, you do not have to do anything about the bug. The easiest workaround is to cover the affected part, device U16, with opaque tape or glue. For more information, see http://www.raspberrypi.org/xenon-death-flash-a-fr...
Parts and tools
  • Raspberry Pi 2
  • Electrical tape, duct tape, or mounting putty
Instructions
  1. Identify device U16 on the Raspberry Pi 2 board. It has a shiny surface, and it is located between the HDMI port and the Raspberry Pi logo.
  2. Cut a small piece of tape and place it over device U16, or cover it completely with a small blob of putty. The tape or putty should completely cover both the top and sides of device U16.
Note that I have not tested my Raspberry Pi with this tape as pictured because I do not expect anyone to take photos with traditional cameras while the media center is running. It may actually take a larger piece of tape to cover the device properly.
Step 3: Step 3: Make a Case From an Altoids Tin
Picture of Step 3: Make a Case From an Altoids Tin
Alternatives
Instead of using an Altoids tin case, you can purchase or 3D print a plastic case, or not use any case at all. Using a case will protect the Raspberry Pi. The Pi must always rest on a surface that is non-conductive to prevent damage from a short-circuit.
Parts and tools
  • Empty Altoids tin
  • Permanent marker
  • Dremel with metal cutting tip
  • Duct tape
Instructions
  1. Clean the Altoids tin.
  2. Carefully hold the Raspberry Pi 2 board up to the case to see where openings need to be made. Hold the board and the case so the audio, HDMI, and MicroUSB ports will be on the side of the tin with the hinges.
  3. With the permanent marker, mark the areas of the tin to be cut away. The following areas must be removed (identified as if the side with the hinges is away from you).
    1. The whole left side and a thin edge from both the base and the lid, starting just ahead of the middle of the curved corners. This will provide an opening for the left two corners of the board, the Ethernet port, and the USB ports.
    2. A small strip of metal across the lower part of the right side, and a corresponding portion of the base. The opening should begin just before the beginnings of the curved corners of the tin. This will accommodate the right two corners of the board and the microSD card once it is inserted.
    3. A rectangular section from the back side of the tin around the audio port.
    4. A rectangular section from the back side of the tin around the HDMI port.
    5. A small rectangular section from the back side that extends the strip taken from the right side (corners and microSD strip) far enough to provide an opening for the microUSB connector.
  4. Double check that all the marked areas will fit the board in one position by carefully holding it up to the Altoids tin again and inspecting the marked areas.
  5. Using a Dremel, carefully cut out the marked sections of the tin, then remove any metal shavings and file the edges (they will be sharp).
  6. Carefully fit the Raspberry Pi into the case to verify that it fits correctly. Insert the side with the HDMI port into the case first, then gently press the rest of the board into place. Repeat the cutting and filing until the board fits easily but stays secure.
  7. Remove the Raspberry Pi, then wrap the base of the case with duct tape for insulation.
Step 4: Step 4: Download XBian Onto a MicroSD Card
Picture of Step 4: Download XBian Onto a MicroSD Card
XBian is a lightweight but complete Debian GNU/Linux distribution designed to run Kodi media center software. It is designed to provide lots of utilities and customizations and make “bleeding edge” features available, while still while still running fast. At the time of writing, it is in release candidate stage of development.
Alternatives
OSMC (Open Source Media Center. Successor to the now end-of-life Raspbmc which supports Raspberry Pi 2 hardware. A very simple Linux system with the minimum of software required to run Kodi. Also in release candidate stage at time of writing.) OpenELEC (Open Embedded Linux Entertainment Center. A minimal Linux system with only software required to run Kodi, designed to run fast. Latest stable release supports the Raspberry Pi 2.) Raspbmc (Now end-of-life. A complete Linux distribution designed to run Kodi and provide useful features.)
Parts and tools
  • MicroSD card
Instructions
  1. Download the XBian installer from http://www.xbian.org/getxbian/ . There is a version for Windows, Mac OSX, and Linux.
  2. Extract the archive and run the installer. On Linux systems, the XBian installer requires the libQt5widgets library to be installed. If you receive the error, “error while loading shared libraries: libQt5Widgets.so.5: cannot open shared object file: No such file or directory” the necessary package is not installed on your computer. On Fedora, install in a terminal with sudo yum install qt5-qtbase-gui .
  3. On page one of the installer, select “Raspberry Pi 2.” On page two, select “XBian Stable rpi2” and select your microSD card device.
  4. Click install. Confirm that it is OK to erase the microSD card. The installer will ask to download Xbian. Approve, then wait for the process to finish.
  5. When the process is complete, close the installer by clicking the X in the title bar.
Step 5: Step 5: Install XBian on the Raspberry Pi 2
Picture of Step 5: Install XBian on the Raspberry Pi 2
Parts and tools
  • Raspberry Pi 2
  • MicroSD card with XBian downloaded
  • AC to MicroUSB power adapter
  • Ethernet cable
  • HDMI cable
  • USB keyboard
  • USB mouse (optional)
Instructions
  1. Plug the Raspberry Pi into a television or computer monitor, and attach the keyboard and mouse. Plug in the Ethernet cable and attach the Raspberry Pi to a working internet connection.
  2. Plug in the AC to MicroUSB power adapter.
  3. XBian will not take long to boot up. Once it does, follow the steps in the XBian Wizard to set it up. Use the keyboard and mouse to interact with the Raspberry Pi.
    1. Click Next. Click Manage network and verify the selected setting is correct.
    2. Click Next. Enter your MPEG-2 or VC-1 codec licenses if you purchased them. Otherwise, move on.
    3. Click Next. There is no need to restore anything from backup. Click Next.
    4. Click Manage update. Choose your preference for installing updates. Close the window and click Next.
    5. On the screen for installing additional packages, just click Next to complete the process.
  4. Enable audio output through the analog audio jack if needed.
    1. From the main menu, select System, then Settings, then System, then Audio output.
    2. Set Audio output device to “HDMI and Analogue”
  5. Turn off the Kodi news ticker at the bottom of the screen if desired.
    1. From the main menu, select System, then Settings, then Appearance, then Skin.
    2. Disable the option, “Show RSS news feeds.”
Step 6: Step 6: (Optional) Install and Configure Infrared Remote Control Capability
Picture of Step 6: (Optional) Install and Configure Infrared Remote Control Capability
This is the most complicated step. In this step, you will attach an IR receiver to the Raspberry Pi and configure LIRC and Kodi to accept commands from a remote control.
If your television supports HDMI CEC (Consumer Electronics Control), you can interact with your media center using your television remote control and skip this entire step. If your television supports HDMI CEC, but you wish to use a separate remote control for this media center anyway, follow these instructions.
Important. The Raspberry Pi 2 GPIO pins are not 5 volt tolerant even though the IR receiver is. Do not use the 5 volt power pins in this step or you will burn out the GPIO pin. Use the 3.3 volt power supply pin to power the IR receiver connected to the Raspberry Pi.
Parts and tools
  • Computer with SSH client
  • Duct tape, electrical tape, or hot glue
  • Remote control
  • USB keyboard or mouse
Instructions
Hardware
  1. Make sure the Raspberry Pi is unplugged from its power supply.
  2. Choose three jumper wires to attach the IR receiver to the Raspberry Pi. I used green for data, black for ground, and red for supply voltage. Use https://www.sparkfun.com/datasheets/Sensors/Infra... to identify the pins of the IR receiver. Attach the jumper wires to the pins of the receiver.
  3. Optional. Secure the jumper wires together at the base of the IR receiver by wrapping them with tape.
  4. Review https://www.sparkfun.com/datasheets/Sensors/Infra... to identify pins in the Raspberry Pi 2 GPIO header. Carefully attach Attach the OUT wire (green in my photo) to pin number 12 on the Pi, which is GPIO 18. Attach the GND wire (black in my photo) to pin number 14, which is GND. Attach the supply voltage wire (red in my photo) to pin number 01, which is 3.3v DC power.
  5. Attach the IR receiver to the underside of the lid with tape or glue. I always keep the lid of the case open while the Raspberry Pi is running to allow heat to escape, and I have not tested the Pi in this case with the lid closed. If you wish to run your media server with the lid closed, you can attach the IR receiver to the front of the case and run the wires out of the case past the USB ports.
  6. Attach the display, keyboard or mouse, network cable, and power to the Raspberry Pi and wait for XBian to boot up.
Software
Run the Linux commands for this step (shown in bold) as root. Switch to a root prompt with sudo -i or by prefacing every command with sudo
  1. Navigate to System, System info, Summary and note the IP address.
  2. On your computer, open your SSH client and connect to the IP address. The username is xbian and the password is raspberry
  3. Press Alt+E or Esc to exit the xbian-config menu.
  4. Optional: install vim or nano. apt-get install vim
  5. Retrieve a list of commands that Kodi recognizes from the remote keymap file. cat /usr/local/share/kodi/system/keymaps/remote.xml Copy and paste the contents of the section somewhere you can refer to it later.
  6. Copy the output of the command irrecord --list-namespace and paste it somewhere you can refer to it later.
  7. Make a list of key names from the irrecord namespace that match necessary (not all) Kodi commands. You will train the Raspberry Pi to recognize these buttons on your remote control. The key names I used are as follows, but this may not be a comprehensive list suitable for all Kodi features.
    1. KEY_0 (the numbers 0 through 9 on the remote)
    2. KEY_1
    3. KEY_2
    4. KEY_3
    5. KEY_4
    6. KEY_5
    7. KEY_6
    8. KEY_7
    9. KEY_8
    10. KEY_9
    11. KEY_BACK
    12. KEY_CHANNELDOWN
    13. KEY_CHANNELUP
    14. KEY_DOWN (down navigation buttons)
    15. KEY_FASTFORWARD
    16. KEY_HOME (will return you to Kodi's main menu)
    17. KEY_INFO
    18. KEY_LEFT (left navigation button)
    19. KEY_MENU (returns to the previously used Kodi menu)
    20. KEY_MUTE
    21. KEY_NEXT (next chapter)
    22. KEY_PAUSE
    23. KEY_PLAY (whether you use separate play and pause buttons or a combined playpause depends on your remote)
    24. KEY_PLAYPAUSE
    25. KEY_POWER
    26. KEY_PREVIOUS (previous chapter)
    27. KEY_REWIND
    28. KEY_RIGHT (right navigation button)
    29. KEY_SELECT (selection button in the center of navigation arrows on most remotes)
    30. KEY_STOP KEY_UP (up navigation button)
    31. KEY_VOLUMEDOWN
    32. KEY_VOLUMEUP
  8. Edit the file /etc/modules so the LIRC kernel module is loaded at startup. Add a line to the file that says (without quotes) “lirc_rpi”
  9. Stop the LIRC service. service lirc stop
  10. Create the configuration file for your remote control. irrecord /home/xbian/remote.conf Follow the instructions on the screen. When prompted for a key to program, enter the name of one of the keys you listed in instruction 7 above, then press the corresponding key on your remote as instructed. Repeat until you have programmed all the keys you need, and press Enter to end the program.
  11. Open the file, remote.conf you just created. Find the line “name /home/xbian/remote.conf” and replace “/home/xbian/remote.conf” with a simple, easy to remember name for your remote control.
  12. Create a backup of the system's lircd.conf file. mv /etc/lirc/lircd.conf /etc/lirc/lircd.conf.original Copy the new file, remote.conf, you just made to /etc/lirc as the new lircd.conf file. cp /home/xbian/remote.conf /etc/lirc/lircd.conf
  13. Create a new Kodi LIRCmap file. Save it as /home/xbian/.kodi/userdata/Lircmap.xml (See http://forum.kodi.tv/showthread.php?tid=45972 for more information about the Lircmap file)
    1. Copy and paste the contents of my Lircmap.xml file below or the contents of the format from http://forum.kodi.tv/showthread.php?tid=45972 section 1.1
    2. Delete lines for unused commands
    3. Insert entries copied from the section of remote.conf you copied in instruction 11 above.
    4. Replace the text between the tags with the appropriate KEY_ name
    5. Replace the device name (remote device="") with the name you gave your remote in lircd.conf in instruction 11 above.
  14. Reboot the Pi and test that the remote control is working. I encountered the following two issues with my remote control and found solutions online.
    1. If it takes two button presses on the remote to get Kodi to respond, repeat this procedure, but in instruction 16, force recording in raw mode with irrecord –force /home/xbian/remote.conf Then run the command irrecord -a /home/xbian/remote.conf
    2. If you press a button on the remote and Kodi acts like it was pressed twice, there is a setting that needs to be changed. Edit /etc/lirc/hardware/lirc_rpi.conf and comment out the line that contains LIRCD_ARGS="-u"
Lircmap.xml
The contents of my Lircmap.xml file have been included as an image at the beginning of Step 6 instead of pasted here because Instructables.com attempts to interpret the XML code instead of displaying the text.
Step 7: Step 7: Updates and Next Steps
Updates
Update the software installed on the Raspberry Pi 2 to obtain fixes for bugs, patches for security holes, and new features. To update, boot up XBian, then go to System, Settings, XBian, Update. Due to a bug in the version of XBian I downloaded, the entries in the XBian menu did not appear, but after installing updates, this issue was resolved. Update is the fourth from the top. Once you select Update, select Check for updates. The update process for the first time takes about half an hour on a good internet connection.
Add media
You can add music and video files you own to your media center by loading them on your MicroSD card (if it is large enough), placing them on a USB thumb drive, or by placing them on a USB hard drive. For a list of file formats supported by Kodi, see http://kodi.wiki/view/Features_and_supported_form... . Playing MPEG-2 (a common format which is also used for DVDs) or VC-1 video (used for some Blu-ray discs) on the Raspberry Pi 2 requires purchased licenses. See http://kodi.wiki/view/Features_and_supported_form... for details.
In order to use a USB hard drive with the Raspberry Pi, it must have a separate power source. This is because hard drives require a lot of extra power for their motors, and the Raspberry Pi cannot supply it. Either user a hard drive that includes its own AC power adapter, or use the drive with a powered USB hub. A powered USB hub has an AC power supply of its own in addition to the USB cable that connects it to a computer (in this case, the Raspberry Pi). Plug the USB cable of the external hard drive into the powered USB hub, then plug the USB cable of the powered hub into the Raspberry Pi.
superbuilderlego (author)2017-03-21
do I download raspberry pi or linux version?
MichaelB208 (author)2017-02-19
Its PEOPLE LIKE YOU that help others get a better understanding of project's for the Raspberry Pi. It takes a lot of work just to do what you did, then for people like me to receive the knowledge to get my project off the ground and working. So from me to you. Thank You Kindly for your Intel. Michael Bong
mohd aziziA (author)2016-06-13
hello,
is this solution work for latest pi3?
TiroNite (author)2016-03-06
so wait the Pi is to replace having a computer hooked up to the tv right?
nmasseria (author)2015-05-14
Does Kodi come standard with the add ons to stream movies still in theaters?
caperjack (author)nmasseria2015-07-27
Hello ,I use the raspberry Pi install form tvaddons and it comes pre configured with lost of addons .
http://www.tvaddons.ag/install-kodi/
caperjack (author)caperjack2015-07-27
I built my media Center into an old Backgammon case .
rpotts2 (author)nmasseria2015-05-16
No. you'd have better luck running thru all the xbmc/kodi videos in youtube
jesterod. (author)2015-04-19
very nice but i am wondering why xbian and not openelec
mmmelroy (author)jesterod.2015-04-20
can confirm, OPENelec or OSMC are much better options if all you want is a standalone media player. xbian is more targeted towards those that want an all in one unit that does everything poorly, as compared to one thing great.
if using one of the afore mentioned OS's, the setup time goes from an estimated 5hrs, to about 1. most of that being copy of disk image to SD card and subsequent update once the PI boots for the first time.
rikardo1979 (author)mmmelroy2015-05-26
actually the setup time of XBian is only few minutes :)
You flash your SD card, plug all cables into your RPi, boot up, do a basic screen and sound setup from within Kodi GUI and you ready ;)
musicalTim (author)jesterod.2015-04-20
As I understand, OpenELEC and OSMC are both very minimal distributions, and since I knew I'd be in the command line setting up LIRC, XBian seemed more like a traditional Linux distribution to work with.
@mmelroy, I did try OSMC since I've used Raspbmc before, but when I started my build in March, OSMC was in Alpha 4 stage and LIRC support hadn't been included yet. I agree XBian is more "all in one," which I wanted in case I wanted to try some other things as well. If all you want is a standalone media player, OpenELEC or OSMC should be just fine, and may even be faster.
hlantz (author)2015-04-30
To hopefully save others some headaches here - when you install XBian, make sure you select "XBian Stable rpi2" (or "Xbian Stable rpi" if you're on older hardware) from the installer dropdown. The preselected option is "XBian Latest rpi(2)", and at least as of last week, the "Latest" version did not create a functioning boot partition, so the RPi would not boot.
I decided to follow this Instructable since it had a thorough explanation of how to get it to work with an IR remote - something which I never managed to get working on Raspbian. Funnily enough, when I booted this image up, it immediately loaded the CEC driver so I could use my TV remote instead. Nice bonus. :-)
jkhashi made it! (author)2015-04-25
Great job musicalTim, I'm jealous of the snazzy Altoids box! With a c10 micro sd card XBian is way faster than openelec @jesterod.
kabeza (author)2015-04-23
Hi! Awesome job @musicalTim
One question (for everyone)... Did any1 try the PleXBMC Kodi addon? And tried connecting to a plex server...? Would Pi go through 1080p smoothly with these? Thanks
Atamido (author)2015-04-19
Media center USB IR receivers are a simple alternative for receiving IR signals. They typically receive IR as keyboard input which means no extra configuration.
pstaples2 (author)2015-04-16
I have done this.... but any ideas how to put ice films on or BBC iPlayer
Laral (author)pstaples22015-04-19
Very simple. Videos->Add-ons->Get More…
Icefilms and iPlayer add-ons should be available.
crank_girl (author)pstaples22015-04-16
Google tvaddons and follow instructions for configuring kodi. I'm pretty sure that the repository you add has iplayer.
You will need to look up which repository contains it. Ice Films a lot of times can be found in the same repo as the 1channel add-on. Google 1channel repo for xbmc and you should be able to find content that will point you in the right direction.
Laral (author)2015-04-19
Nice detailed Instructable. I was toying with the idea of making one of these but I get the impression that Kodi on XBian is very troublesome from the many forum posts I read, and there is a considerable amount of fussing to get this working. A much better alternative is on the horizon and I'm waiting for the reviews and enough availability to bring the price down. I'm talking about the Intel Compute Stick. It is a 4" x 1.5" x .5" self-contained computer with an HDMI plug. Just plug it into your TV and go, right out of the box. It has a 1.33GHz 64 bit Quad-Core Intel Atom Processor, 32 GB eMMC SSD 'hard drive', 2MB cache, 2GB 1333 MHz DDR3L memory, Intel HD Graphics, Windows 8.1 32-Bit (unfortunately not 64-bit), 802.11b/g/n Wireless LAN, Bluetooth 4.0, a Micro SDXC v3.0 slot, a USB 2.0 port (which, unfortunately, you need to use for charging right now--future versions will eliminate this need), or you can use the 5V/2A wall-wart power supply. It will be $149 for the Windows version or $89 for a dumbed-down Linux version with 1GB of RAM and 8GB of storage. XBMC/Kodi is, by far, best on Windows since that is the majority platform it is developed for. I currently run it on OS X but there are problems that Windows versions do not have. Unfortunately there are some BluRays out there that still use the, obsolete IMO, MS VC1 codec. There is no support for this codec in OS X so they simply won't play. Windows, on the other hand, has built-in support for VC1. Also, Apple AFP, the default network sharing protocol, is not supported by Kodi. You can mount an AFP share in Kodi but it will guaranteed freeze the app in the middle of a movie on that share. You have to use NFS (preferably), or SMB, which is very buggy on OS X. Windows, on the other hand, uses SMB natively so there shouldn't be any problems. These 2 issues alone justify going to Windows IMO so I am looking forward to this stick coming out shortly.
Wild-Bill (author)2015-04-19
Thanks Timothy
I just got my hands on a RPi 2 along with a HiFiBerry with the idea of setting up a music server so it is nice to know some one has passed this way before me. Nice project.
B0jangles (author)2015-04-16
Hey can u use this like a server ie have this running with my hdd full of content connected to the Internet in my office and remotely stream from it either with a PS3 or roku or another pi?
rikardo1979 (author)2015-04-16
Nice one ;)
Check out mine here https://www.instructables.com/id/XBian-XBMCKodi-for-your-small-factor-computer/
tomatoskins (author)2015-04-16
This is a great idea! I'm currently runing Kodi on a Fire TV streaming videos from my server. Love it!
About This Instructable
129,668views
990favorites
More by musicalTim:Raspberry Pi 2 Media Center: Kodi on XBian
Add instructable to:
