Introduction: Receiving and Sending Data Between Attiny85 (Arduino IDE 1.06) UPDATED Nov 2015
Picture of Receiving and Sending Data Between Attiny85 (Arduino IDE 1.06) UPDATED Nov 2015
I have struggled a lot with sending RF data between two Attiny85 chips, so I thought it might be helpful if I just explain how I did it. There are a number of such projects being described on the internet, but yet, it didn’t prove to be such a straightforward project, which i found to be mostly due to not using the right libraries and cores.
BOM
Transmitter:
Attiny85 - 0.82 euro/10
10k resistor
433 MHz transmittermodule - 1 euro per set
mini breadboard - 58 cts/piece
Receiver:
Attiny85
10k resistor
433 MHz Receiver module
mini breadboard
Optional: 2 wire LCD
There are two main libraries used to send and receive data on an Arduino platform: VirtualWire and Manchester code.
As Virtualwire is a bit older, no longer supported, and supposedly can only send characters (though there is a way around that) I decided to use Manchester code.
To make a long story short, it didn’t work. I had the MANCHESTER.h and MANCHESTER.cpp file and ran into a lot of trouble, until I discovered that was the wrong/old library, you need the Manchester.h and Manchester.cpp file from here. When I used that I got my transmitter to work, I could send data to an Arduino, that was already a big relief.
However....... whatever I did, I did not get my receiver to work. In testing something on an Attiny it is very frustrating to just stare at an LED that is supposed to light, but doesnt, without knowing what and why and how.
So i decided to add an LCD to the Attiny, so at least I could see what was happening..
However, the LCD on my attiny gave me other problems... and when I solved those, that proved to be the solution for my receive problem as well: I was using the wrong core. I was using the 'tiny core' rather than the 'attiny core'
The latter is the one from Highlowtech.
Also, I programmed the Attiny's with 8MHz internal oscillator by first 'burning the bootloader'
NOTE: it is generally agreed that the 'tiny core' works with the Manchester code and the attiny core does not, so it is possible that I mixed up the two. However, I had a line added to the Attiny core that I forgot about that will make it work with the Manchester code. Open up the "variants/tiny8/pins_arduino.h" file and add the line"#define __AVR_Attinyx5__" (See the picture)
NOTE2: Obviously it also works for the IDE 1.6.x but if you use the tiny core that does not come with a JSON file and as the core file folder structure for 1.6.x is different from 1.0.6 You need to do the install yourself. This website can help you with that. The attiny core comes with a json link that will do the install via the boards manager, but then you have to add the Attiny5__ definition as described above
Step 1: Receiving and Sending Data Between Attiny85: the Transmitter
Picture of Receiving and Sending Data Between Attiny85: the Transmitter
The built of the transmitter is easy:
Plug the attiny chip into your breadboard,
Connect a 433 MHz Transmitter module with its data in to pin PB0 (that is pin 5 on the chip).
Connect Vcc and Ground of the transmitter module to Vcc (pin 8) and ground (pin 4) of the Attiny
Insert a 10 k resistor between pin 1 (Reset) and pin 8 (Vcc)
Connect Vcc and ground to 5 Volt
Take a 17 cm stiff wire and attach that to the antenna hole of the transmitter.
use the following program:
#include <Manchester.h>
Manchester Transmitter example In this example transmitter will send one 16 bit number
per transmission.
Try different speeds using these constants, your maximum
possible speed will depend on various factors like transmitter
type, distance, microcontroller speed, ...
MAN_300 0 MAN_600 1 MAN_1200 2 MAN_2400 3 MAN_4800 4 MAN_9600 5 MAN_19200 6 MAN_38400 7
#define TX_PIN 0 //pin where your transmitter is connected
uint16_t transmit_data = 2761;
void setup() { man.setupTransmit(TX_PIN, MAN_1200); }
void loop() { man.transmit(transmit_data); delay(200); }
Just a word on the 2716 that I am sending. The program is not mine, I found it as such and since it worked and I was very happy to see the '2716' appear in my Arduino after days of fruitless trying, I decided to leave it there as a tribute. (it might have found it here)
Step 2: Receiving and Sending Data Between Attiny85: the Receiver
Picture of Receiving and Sending Data Between Attiny85: the Receiver
Building the receiver is easy:
Put the programmed attiny chip in your breadboard.
Connect a 10 k resistor between pin 1 and pin 8
Put your 433 MHz Receiver module in the breadboard
Connect the datapin (usually either one of the two middle pins) to pin PB1 (physical pin6) on the attiny.
Connect the Vcc and Ground of the transmitter module to Vcc (pin 8) and Ground (pin4) of the Attiny
Connect the LCD interface to pin PB0 (pin 5) (Clock) and pin PB2 (pin 7) (Data/Enable)
Connect Vcc and ground of the LCD to Vcc and Ground.
Attach a 17 cm (1/4 lambda for 433 MHz) to the Receiver module.
Use the following program in your chip:
#include <LiquidCrystal_SR.h>
LiquidCrystal_SR lcd(0,2,TWO_WIRE);
  Manchester Receiver for Attiny
  In this example receiver will receive one 16 bit number per<br>  transmittion to switch a relay on or off. <br>  try different speeds using these constants, your maximum possible<br>  speed will depend on various factors like transmitter type, <br>  distance,  microcontroller speed, ...<br><br>  MAN_300 0
  MAN_600 1
  MAN_1200 2
  MAN_2400 3
  MAN_4800 4
  MAN_9600 5
  MAN_19200 6
  MAN_38400 7
#define RX_PIN 1 //= pin 6
uint8_t moo = 1;
void setup()
lcd.begin(16,2);
lcd.home();
lcd.print("Receive");
lcd.setCursor(0,1);
  man.setupReceive(RX_PIN, MAN_1200);
  man.beginReceive();
void loop() {
  if (man.receiveComplete()) {
    uint16_t m = man.getMessage();
    man.beginReceive(); //start listening for next message right<br>                        //after you retrieve the message
   moo = ++moo % 2;
    lcd.print(m);
The LCD is ofcourse optional. You can use an LED that gets the variable 'moo' send to its pin and thus will flash on complete receival of the signal, but I just wanted to make sure that what I got was what I sent
Step 3: Receiving and Sending Data Between Attiny85: Results
Picture of Receiving and Sending Data Between Attiny85: Results
The results are good, no garbage is being received, but the reach is about 4-5 meters, with the antennas. The antenna on the receiver only makes a small difference. The one on the Transmitter makes a big difference.
Still, this is surprising as the transmitter module is capable of switching remote switches at greater distances even on different floors.
With regard to the length of the Antennas:
as f * λ= c (frequency * wavelength = lightspeed)
λ=c/f
λ= 299,792,458 /433,920,000
The wavelength is 0.690893386 meters.
Antenna would be λ/4= 0.172723346 meters (17.3 cm)
That is about 6.80013 inches.
If you would be using 315 MHz modules, the antenna would be: 0.238 m or 23.8 cm
You can also use the wavelength calculator.
Supposedly the transmitter module can take 12 Volts and still be steered by a 5 Volt microcontroller pin and will have a further reach then. Increasing the voltage on the receiver of course makes no difference
Once you have established The link between two attiny's, linking one of them with an arduino should not be a problem. I use mine to send data to an Arduino ( e,g. temperature, or the status of a tripwire), or to receive data from an Arduino to steer a servo or an RGB LED.
If you want to trigger a relay, you would do it like this:
void loop() {<br>  if (man.receiveComplete()) {
    man.beginReceive(); //start listening for next message right after you retrieve the message
    moo = ++moo % 2;
    lcd.print(m);
    if (m==2761){digitalWrite(Relay,HIGH);}
    if (m==0000){digitalWrite(Relay,LOW);}
Ofcourse you need to define the Relay pin in the 'setup'
Step 4: Sending and Receiving Sensor Data With Attiny85/45: DHT11 and LDR Through Manchester Code
Picture of Sending and Receiving  Sensor Data With Attiny85/45: DHT11 and LDR Through Manchester Code
Sending a stationary number of course is fun at first, but isn’t much use. Below is a more practical example of sending 1 stationary value and 3 variable values through the ether.
LDR=A1 RF433=D0 DHT11=D4 LED=D3 */ // libraries #include <dht11.h> #include <Manchester.h> dht11 DHT11; #define DHT11PIN 4 #define TX_PIN 0 //pin where your transmitter is connected //variables float h=0; float t=0; int transmit_data = 2761; int transmit_t = 0; int transmit_h = 0; int light=0;
void setup() {
void loop() {
 int chk = DHT11.read(DHT11PIN);
 h=DHT11.humidity;
 t=DHT11.temperature;
 transmit_h=100*h;
 transmit_t=100*t;
  delay(200);
  man.transmit(transmit_h);
  delay(200);
  man.transmit(transmit_t);
 light= analogRead(A1);
 man.transmit(light);
It takes 3194 bytes so I could compile it in an Attiny45.
The transmitter is connected to D0 (pin 5). The DHT11 sensor is
connected to D4 (pin 3) and an LDR connected to A1 (pin 7), with the other end connected to either ground or Vcc and a corresponding pull up or pull down resistor, depending on your preference,
Variables h and t are floats that can have decimals. As I am only interested in 2 decimal accuracy, I multiply by 100 and turn them into integers. I then send a station identifier '2716', followed by 3 values: Humidity, temperature, light. The receiving station then can identify where it came from and process the incoming signals (starting by dividing them by 100 again)
georgek52 (author)2017-11-07
Hello,
Since I managed to make LCD work I started working with the RF. I encounter the following issue. When I use the provided code the receiver display nothing. Although it work if I change the code in loop to:
void loop()
Serial.println(m);
Probably something is wrong with this function:
Any ideas?
georgek52 (author)2017-10-27
Hi guys,
I have spend the last 4 days trying to make this work but it doesnt. I realy need some help at this point
. The transmiter part seems to work. I attached a led on PIN0 and it lights up every time it sends data.
I am using arduino IDE 1.8.1, Attiny board manager 1.0.2, and I setup the internal core speed to 8mhz for both Attiny85 (receiver, transmiter). I upload the code using two arduino nano with "arduino as ISP"
Although the receiver refuse to work. I even build a homeade oscilloscope to check the data pins.
The receiver seems to stop for some time when the trasmiter send the signal. So I guess it receives the data but Attiny refuse to turn on the led.
===============Transmiter======================
void setup() {
pinMode(1, OUTPUT);
digitalWrite(1, LOW); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(1, HIGH); // turn the LED off by making the voltage LOW
void loop() {
===================Receiver==================
uint8_t moo = 1;
void setup()
pinMode(0, OUTPUT);
digitalWrite(0, LOW); // turn the LED on (HIGH is the voltage level)
digitalWrite(0, HIGH); // turn the LED off by making the voltage LOW
man.beginReceive();
}void loop() {
moo = ++moo % 2;
diy_bloke (author)georgek522017-10-28
Sorry to hear you have problems. Just a question, why all the delays? Did you try without?
Did you add the modification in the library I suggested?
georgek52 (author)diy_bloke2017-10-28
The delays are for the led to blink. Can you please help me out to set up te I2C screen? I can't find a fit library
If you can't chat that's ok, I will continue here :) in your code you include
This on is not included in broHogan lib. What did you used?
no it says:
//#include <LiquidCrystal_SR.h>
//LiquidCrystal_SR lcd(3,4,TWO_WIRE);//resp pin 2 en 3
These are thus commented out.
look further down where the I2C is included
Ok, i am missing something here, in you code above you don't include
LiquidCrystal_I2C.h
but also I understand that some encoding issue translated // to <br>
The code below is what I see in your instructables. So what I have to cange/add?
#include <Manchester.h><br>#include <LiquidCrystal_SR.h>
MAN_300 0
MAN_600 1
MAN_1200 2
MAN_2400 3
MAN_4800 4
MAN_9600 5
MAN_19200 6
MAN_38400 7
uint8_t moo = 1;
void setup()
lcd.begin(16,2);
lcd.home();
lcd.setCursor(0,1);
man.beginReceive();
}<br>void loop() {
moo = ++moo % 2;
lcd.print(m);
georgek52 (author)georgek522017-10-28
Also do you use pull ups 4.7k resistors at your sda and scl pins?
That depends on the LCD/LCDinterface you are using, often they have pullup resistors. If not you have to add pull up resisters
Ok, now I understand what I was missing. Let's start over then. I used the following:
core: http://highlowtech.org/?p=1695
Attiny85_BMP180_BroHogan.zip
TinyWireM
In TinyWireM I edited the clock speeds as it is set to 1mhz. Specifically I edited USI_TWI_Master.cpp and USI_TWI_Master.h
#define F_CPU 1000000UL -> #define F_CPU 8000000UL
and
#define SYS_CLK 1000.0 -> #define SYS_CLK 8000.0
For the bootloader I selected Attiny85, 8Mhz
See the attached image
I tested many other libs and I concluded that the resistores are nedeed. Without the resistors the screen does not light up
I took a part from Hogans lib and this is it:
//The connection for Attiny & BMP180 are SDA pin 5 ,SCL pin 7 for I2C
// | \-- Clock Pin
// \---- Data/Enable Pin
#include "LiquidCrystal_I2C.h"
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#include <TinyWireM.h>
void setup() {
// Now set up the LCD
//lcd.begin(16,2); // initialize the lcd
lcd.init();
lcd.home (); // go home
lcd.print("Weatherstation");
lcd.setCursor ( 0, 1 ); // go to position
lcd.print("BMP180");
delay(2000);
void loop() {
lcd.home();
lcd.print(" Press ");
lcd.print(" Hum ");
I uploaded the compiler error in pastebin
https://pastebin.com/59AtLvZ5
diy_bloke (author)georgek522017-10-29
I am a bit puzzled, I never felt the need to alter any frequencies in the TinyWireM library. What is more, my USI_TWI files dont even have the definitions you say you have changed. Are you sure you use the right library?
Ofcourse the resistors are needed, nobody is disputing that, in fact, I was telling you they were needed.
To
avoid talking about two different things again: ALL I2C lines need pull
up but as I said, the i2C to LCD adapter may already have pullups in
which case you do not need to add extra, but if it doesnt ofcourse you
need to add pullups yourself
Why would you be using 'part of the broHogan library' If you start using "parts" of a library you can expect problems
Judging from the compilation errors, It seems you are calling the library more than once.
To make sure I downloaded the link myself again and just compiled it. As you see, compiles without any problems.
I think that what might be happening is that somehow your system picks up on two libraries, so pls check if you are indeed using:
and not
#include <LiquidCrystal_I2C.h>
if that is the case it should be OK, but in practice it isnt always. Check if your main LCD library (the one in your libraries folder) is perhaps called "LiquidCrystal_I2C.h" too. The Arduino IDE should be able to differentiate but it doesnt always. I suggest you temporarily rename those library files and try again.
georgek52 (author)diy_bloke2017-10-29
I apologize again for the reminder. Now, what I meant was that i'm using part of Hogans example. Sorry for that.
Indeed there was two libraries in different folders. Now I managed to compile it and upload the code. But again the screen is not printing anything.
The example mention:
I connected the pins to the corresponding Attiny pins which are pin 7 = 2 and pin 5 = 0 with two 4.7k resistors.
Also, regarding the TinyWireM lib there are two out there, in one of them you can specify the speeds, in the other one there is this comment:
*Notes:
* - T4_TWI and T2_TWI delays are modified to work with 1MHz default clock
* and now use hard code values. They would need to change
* for other clock rates. Refer to the Apps Note.
So, since you are using the one with that the speed is not configurable, I used the same now. I download it from Arduino's IDE Library manager
Well apparently we are advancing.
With regard to 'not showing anything' are you using the right I2C address? Is the contrast potentiometer set right?
I used a scanner to get the address with the use of an arduino and it reported 0x27. Just to be on the safe side I also tried 0x20 which is also common. Now regarding the potentiometer I don't really know how much contrast is required so I tried a few settings without luck.
I read somewhere that in some I2C adapters the pins of the chip are inverted. I don't know if that's the case.
What the guy writes about the pins and he also provided a library with a fix.:
Where did you get that board?
There are some Chinese ebay boards using the PCF8574T with the pins swapped and so you can't use the original library for it.
I have one of this Chinese board and my address is 0x20.
Here is the library for the Chinese version.
Remember, you must remove from the libraries folder the older one and insert this new one.
Post results
https://forum.arduino.cc/index.php?topic=219717.0
what LCD do you have? Did it come with an i2C module attached? Did you try it on an Arduino?
georgek52 (author)diy_bloke2017-10-30
Hello,
This is my I2C adapter
https://www.ebay.com/itm/1602LCD-Display-IIC-I2C-T...
And this is my LCD
https://www.ebay.com/itm/NEW-DC-5V-HD44780-1602-LC...
Back in 2015 I made it work with an arduino UNO but I don'r remember much. I believe that I located in my computer the code that made it work for arduino.
Two possibilities here, either my TinyWireM lib is not correct or in the code bellow I changed the lcd address, but I don't recall doing the last part.
LiquidCrystal_I2Clcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin); <-- seems the same to me with the original example
At this point, can you please share with me the exact TinyWireM (version and all) that you are using. Or just zip your lib and send it to me. Also please let me know the version of Arduino IDE that you used to compile the code with (I don't think that it matters but just to be on the safe side).
This is the code I used back then
** Example Arduino sketch for SainSmart I2C LCD Screen 16x2
** based on https://bitbucket.org/celem/sainsmart-i2c-lcd/src...
** by
** Edward Comer
** LICENSE: GNU General Public License, version 3 (GPL-3.0)
** This example uses F Malpartida's NewLiquidCrystal library. Obtain from:
** https://bitbucket.org/fmalpartida/new-liquidcryst...
** Modified - Ian Brennan ianbren at hotmail.com 23-10-2012 to support Tutorial posted to Arduino.cc
** Written for and tested with Arduino 1.0
** NOTE: Tested on Arduino Uno whose I2C pins are A4==SDA, A5==SCL
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR 0x27 // <<----- Add your address here. Find it from I2C Scanner
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int n = 1;
void setup()
lcd.begin (16,2); // <<----- My LCD was 16x2
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.print("SainSmartI2C16x2");
void loop()
// Backlight on/off every 3 seconds
lcd.setCursor (0,1); // go to start of 2nd line
lcd.print(n++,DEC);
diy_bloke (author)georgek522017-10-31
if you are now using that same module and LCD then you know it is working.
The program+library that I sent you works with this configuration
addr, en,rw,rs,d4,d5,d6,d7,bl,blpol *
0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE)
That is the same that you are using
the TinywireM version I am using is version 1.0.0
georgek52 (author)georgek522017-10-30
If you wonder how is that guy remember what he did 2 years ago, I don't :P !
I located a picture I send to my friend with the lcd working and the print in the lcd produced from the code that I found in my computer from back then
So I'm positive that the screen is working somehow
Hello again.
I tried to connect the lcd to arduino with the sketch and the lib I described above and it works.
Also another comment, I think that I used the pull ups wrong. Now my pull up resistors are connected between the pins and the 5v supply. When I connected back the screen to pins 5 and 7 of the Attiny as described in Hogans lib the screen start flickering
When I reverse the pins the flickering stops. But again nothing shows up on the screen.
The only thing I can think is that this part of the code I used for arduino is setting the I2C pins correctly
Hello and sorry for spamming!!!! IT WORKS!!!
The question is how, I used the following library by fmalpartida, yes this is the one I mentioned above and used it 2 year ago for arduino. Surprisingly someone made a commit in this library at 2016 for attiny support.
This is the repo:
https://bitbucket.org/celem/sainsmart-i2c-lcd/over...
and you have to download the whole repo from here:
https://bitbucket.org/fmalpartida/new-liquidcrysta...
This one includes the commit for attiny!
The following is just a guess based on what I read all over the internet.
A lot of Chinese I2C adapters have PCF8574T with the pins swapped. So my guess is that this lib is setting up the pins correctly.
Thanks a lot for your help and time bloke, but the challenge just begins. Now I have to go back and see what is going on with the RF receiver. At least now I have an interface to see what is going on.
George indeed you are missing something, in the published code in this instructable, I am using an LCD that is driven by a Shiftregister, hence the code is that for a shiftregister.
However, you asked if I could help you with code for an I2C LCD, so that is what I sent you in the link
diy_bloke (author)diy_bloke2017-10-28
and wherever it happens to say "<br>", you have to remove that and put it in the next line.
Yes I tried the broHogan lib but it fails to compile no matter what I tried. I know that it sounds stupid but do you have skype, messenger or something to chat?
so what error messages do you get
Hello,
any ideas about the compiling issue?
I understand you are eager to get it to work but there is really no reason to 'remind' or 'push' me.
I answer all questions when I see them. A 'reminder' will not get to me any earlier than that I open instructables to see if there are questions. On the odd chance that I overlook a question and havent answered in a week, while answering other questions, yes a reminder may help, but really not necessary to remind me a few hours after the initial question
Sorry for that, I just send the reminder because the comment section is a mess.
no problem, but extra messages just make it more colluded.
And indeed you are right, the comment section does get very unclear after a while
Did my compiling advice help?
Hello,
yes it compiled, but now the screen is not working. I have left a comment above with pictures and stuff
I also tried this by tdoyle308:
I figured it out using IDE 1.6.5...
Used the arduino-tiny 1.5 cores from here: https://code.google.com/p/arduino-tiny/
Added that tinyfolder to C:\Users\(username)\Documents\Arduino\hardware\tiny
Had to rename C:\Users\(username)\Documents\Arduino\hardware\tiny\avr\Prospective Boards.txt to Boards.txt.
georgek52 (author)georgek522017-10-27
The green waves in the picture are the data
from the transmiter. I also tried to use an rf remote and when I press
the button the readings of the receiever stop for a second. I guees the
code gets through the if statement.
Sam1ive made it! (author)2017-01-28
Hi guys! help please, can't send the code for the button with the Attiny 13. what did I do wrong, the code compiles but no action happens(( how can I improve? is it possible to feed from the batteries with sleep mode attiny to last longer worked?
Here is the code for the Arduino and it works great:
#include <RCSwitch.h>
int button = 12;
RCSwitch mySwitch = RCSwitch();
void setup() {
Serial.begin(9600);
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(10);
pinMode(button, INPUT);
void loop() {
if(digitalRead(button) == HIGH){mySwitch.send(11235377, 24);}
delay(500);
And this is the code for Attiny 13, the code is loaded but no action, help to fix the problem
#include <avr/io.h>
#include <util/delay.h>
int button = 3;
int main( void ) {
// Transmitter is connected to Arduino Pin #0 (PB0)
mySwitch.enableTransmit(0);
void loop() {
if(digitalRead(button) == LOW){mySwitch.send(11235377, 24);}
_delay_ms(500);
diy_bloke (author)Sam1ive2017-02-09
I apologize for my late reaction but somehow in the new comment format of instructables it is more difficult to keep track of new comments.
Anyway.... first, your question is a bit outside the realm of this instructable as i discuss data transmit between two attiny 85's using the manchester code, whereas you are having a problem with the attiny13 and the RCSwitch library and that might be exactly where yr problem lies. As i understand the 13 works on a 4.8 or 9.6MHz frequency and depending on yr core and proper programming, the timing might be a bit off and your receiver may just not recognize the signal as it is a bit off. I think for confirmation of this or for more help you better go to the RCSwitch github and raise the issue there, maybe they know a solution
?Here is the code for the Arduino and it works great:
?#include <RCSwitch.h>
int button = 12;
void setup() {
Serial.begin(9600);
void loop() {
delay(500);
?And this is the code for Attiny 13, the code is loaded but no action, help to fix the problem
#include <avr/io.h>
int button = 3;
int main( void ) {
void loop() {
_delay_ms(500);
SergeG13 (author)2016-10-20
Hello again.
I think, I solve the problem!
After a lot of different experiments I change the Clock to "External 8 MHz" (before that I use Internal 1 MHz). It works with External 16 MHz but slower.
Thank you for you lesson again!!!
diy_bloke (author)SergeG132016-10-21
That is exactly why I asked you what speed you burned the bootlaoder as I suspected that might be the problem :-)
I am happy you got it towork
I apologize for my offensive and stupid, but I've done all of your lesson. The transmitter works, which is signaled by the LED. But receiver does not want to operate (LED is silent). To test the receivers radio module I attached LED on its pins. LED blinks in time with the transmitter LED.
Then the microcontroller does not want to process the received signal. I downloaded your Manchester library, add a line but the situation has not changed.
Please help me, what else should pay attention to make the receiver works?
diy_bloke (author)SergeG132016-10-20
you are not offebsive or stupid. Anyway so you have a setup in which neither the virtualwire nor the manchester library seems to work. hmm... at what speed did you burn the bootloader?
SergeG13 (author)diy_bloke2016-10-21
I solved the problem!
Please read my post below.
This solution is correct for the VirtualWire library too!
SergeG13 (author)2016-10-19
I decided to try Manchester library and your tutorial.
I don't need LCD. I took LED light to inform about connection.
SergeG13 (author)2016-10-18
It's realy cool!
In my project i made a transceiver atTiny85+FS1000A.
There is 2 buttons on transceiver and I must send them.
I use VirtualWire library.
The receiver consist of atTiny85 and XY-MK-5V.
And the receiver doesn't want to work :((
Do you know, maybe there is some secret?
I lost hope that someone can help me with this trouble
diy_bloke (author)SergeG132016-10-18
Serge I never used Virtual Wire so I am not sure if i can help you. So do i understand the transmitter works but the reciver doesnt?
send me yr code here
SergeG13 made it! (author)diy_bloke2016-10-18
Here is the sketch (on arduino it works):
#include <VirtualWire.h>
int led = 4; //LED for information
int radar = 2;// i tried pb0, pb1, pb2 - no results
void setup() {
vw_set_rx_pin(radar);
vw_set_ptt_inverted(true);
vw_setup(1000);
vw_rx_start();
pinMode(led, OUTPUT);
digitalWrite(led, HIGH);
delay (100);// check the LED
void loop()
digitalWrite(led, LOW);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
vw_wait_rx();
if (vw_get_message(buf, &buflen)) // Non-blocking
if (buf[0] == 'g'){
if (buf[1] == 't'){
digitalWrite(led, HIGH);//if we have the signal, than turn on LED
delay(1000);
Thijxx (author)2016-09-23
Great stuff, the communication works very good. The LiquidCrystal seems to be a much harder nut to crack, I'm using TinyWireM and a LiquidCrystal library with Tiny85 support but still I get nothing more than a flashing backlight :( Ant more information on your display setup is welcome!
diy_bloke (author)Thijxx2016-09-23
I am happy the communication works.
Which LiquidCrystalLibrary do you use?
Thijxx (author)diy_bloke2016-09-24
This one: http://playground.arduino.cc/Code/USIi2c
diy_bloke (author)Thijxx2016-09-24
ok just to make sure we are on the same page. are you trying the LCD with an I2C connection or with a shiftregister? My solution with a shiftregister works with the Malpartida library, the I2C indeed with the BroHogan library that you linked to.
Anyway just make sure about the following:
right address for I2C (some modules have 0x27 others 0x20
right contrast
and then look here
https://www.instructables.com/id/Using-an-I2C-LCD-o...
Thanks, I've followed the link, then followed all the steps, it's not clear what core the guy uses but I tried it with multiple cores and still get the same result. Black boxes on one line. Attached it to the Nano directly and then it works fine, must be something about the Tiny I do wrong..
"The guy" is me and i think i used the standard attiny25/45/85 core that is in the IDE. perhaps a dumb question but have you maybe switched sda and scl?
About This Instructable
43,832views
168favorites
License:
Bio: I am a physician by trade. After a career in the pharmeceutical world I decided to take it a bit slower and do things I ... More »
More by diy_bloke:Working With the Funduino W5100 Ethernet Module.Uploading Data to ThingSpeak With MQTTAdding an MCP23017 I/O Extender to Arduino or ESP8266
Add instructable to:
