Repair your macintosh power cord
Tired of Mighty Apple charging you beaucoup $$$ for those badly designed power adapters which break all the time? Repair it yourself!
Step 1Slide back the sheath
slide back the sheath
My sheath was cracked already, so it was easy to slide back.
Assuming yours is intact, I think a good swift twist/tug with a pair of pliers should snap it loose.
62 comments
1-40 of 62next »
Oct 27, 2011. 11:58 PMbydto says:
http://strelok-inform.ru/
Aug 23, 2011. 6:29 AMpowsolec says:
It's nice information,but sometimes it is good way to replance a newPower cord
from a quality power supply cord
manufacturer
Aug 21, 2007. 8:00 PMmcircosta says:
The sheath can be easily removed by inserting a thin blade between the clear ring and white sheath. Gently press on the blade while rotating the sheath. This will separate these two components slightly. Once this is done, use your teeth to pull on the clear ring and push on the sheath ( charger tip poiting toward your throat. This will result in a full removal.
Aug 23, 2011. 1:16 AMmaximilien says:
Thanks, better than distorting the metal power sheath with pliers like I did. Still works but tight fit in mac.
Feb 23, 2009. 10:07 PMgrantaccess says:
Thanks for the tip - it helped a lot.
Aug 4, 2011. 12:55 AMpower cord says:
if's a good information and you can see the power cord,power supply cordmanufacturer.
May 22, 2011. 7:34 PMdar1bak says:
Good stuff, geo. My iBook is charging again as we speak. To avoid messing with the tiny circuit board, I carved away the lumpy part of the strain relief and found a small steel band, inside which was some healthy wire already soldered to the board. I cut, stripped and tinned everything, soldered and taped, and it's fine.
What I did notice was something that may have contributed to why these are flimsy -- the braid wasn't tinned in the original hookup, not even twisted, and the nylon was still flopping about in there. Can't possibly have been a good connection.
Mar 21, 2011. 8:27 PMjsuhajda says:
Great instructions. Something similar happened to my powerbook G4 adapter. When I went to remove the outer white insulation to get to the two wires inside, i found one wire in grey insulation, and the other wire in a braided mesh around a green nylon string.
Any suggestions on how to connect this braided wire with the end connected to the plug?
Jun 16, 2009. 6:52 AMmsjarmer says:
This was great. This page came up when I was looking for a place to buy a new power cord. Not only did it save me money but time as well. I didn't want to wait a week to get a new power cord, thats to long to be with out a computer. Good old powerbook G4, still going strong after 6 years.
Aug 10, 2010. 12:24 AMkingtiger says:
ditto, my powerbook g4 is still going strong... it's just the power adapters that keep crapping out on me. Too bad I don't have a soldering iron handy otherwise I would totally do this. I have too many of these power bricks lying around. As of right now I've got my powerbook at a weird angle just to get the plug to charge my laptop.
Apr 30, 2010. 5:39 PMRevJesseJ says:
 Confirmed!
Thank you for saving me $75!!
Jan 5, 2010. 9:58 PMpowercord says:
it's good info
Jul 27, 2009. 11:34 PMwvjolliffe says:
Enhanced strain relief; finish up by adding a small piece of nylon wire tie or similar material between the shrink tube and the outer jacket of the power cable power cable where it exits the plug housing. This will add a little "spine" to your strain relief. YMMV.
Jul 15, 2009. 9:34 PMyakcf says:
Well, this was certainly a fun, albeit necessary, project. Thank you so much for the instructions - made this much easier than me just making crap up and hoping for the best, lol.
May 12, 2009. 11:14 PMMusiker says:
To take the plug apart you need to hold the metal part. and twist and pull the plastic part - Mine came of quite easily. I fixated the metal tip in a vice using some O-rings (3mm) that just fitted inside the tip so the outer metal shield did not get squashed when is fasten it.
May 10, 2009. 8:21 PMrussell62 says:
Great ideas - thankyou. - however I have 2 mac laptop power supplies with a problem where the small cord enters the power unit. Does anyone have an easy fix for this? I haven't tried to take one apart yet.
Mar 12, 2009. 10:02 AMDavid Levine says:
So... is the function of the round metal sleeve over the power tip only a safety measure - to keep you from plugging he power supply into the headphone socket, for instance?
Apr 20, 2009. 4:54 PMBjorno says:
The sleeve has nothing to do with the actual power. It is just for extra damage protection and to prevent the plug from shorting. Since the actual power connector is similar to the 1/8" headphone jack, if there was no sleeve anytime the plug touched something it would short.
Mar 15, 2009. 8:12 AMHelloid says:
I have between 4 of these bulky paperweights sitting around. I should at least sacrifice one of the to try the fix. If that doesn't work, it would be nice to have a place to send them where other people can make use of them. The one I am using on the laptop I am typing this with, needs to be tweaked every 15 minutes or so. I usually turn the plug until it lights green again. That cannot be good for the wires. I will be happy when I have a fix or get another computer.
Mar 12, 2009. 10:04 AMDavid Levine says:
Does polarity matter -- if you went with a standard 2.5 mm stereo jack?
Feb 23, 2009. 10:06 PMgrantaccess says:
Thanks for the instructable. Took the guesswork out of repairing my sister's power connector.
Feb 22, 2009. 12:45 PMBonnie Char says:
Thank you for your advice. Yay for not having to shell out $79.00 for a new power brick!
I decided to take on this project after fixing two dead (logic board issue) G3 ibooks with the amazing 26cent method http://www.fak3r.com/2007/05/29/howto-fix-a-g3-ibook-with-a-bad-logic-board-for-26-cents/ (just open the lower case and tape a quarter and penny to the metal housing outside where the VRAM chip is located !)
Next here is the fix for an adapter that had frayed wire to the power brick: http://theappleblog.com/2005/08/13/powerbook-65w-ac-adaper-repair/
But getting back to your fix --
I would have never dreamed the adaptor plug end could have been repaired, but your post gave me the guts to go for it. (That and my not wanting to shell out $80)
The adapter plug is a tough nut to crack -- literally. It's not like you can even
dream of popping it apart.
For those not fortunate (?) enough to have a pre-cracked plug case like you did-- if you put the connector in a vice, it can be cut off fairly easily with a box cutter. I cut it into two halves by splitting it up each side, which made it really easy to put back on after the repair.
My connector guts were in fine shape and the solder to the plug was fine. The problem had been a worn cord where the wire comes out of the plug -- frayed to the point of sparking, so I really just needed to take the outer plug off; cut the bad length of wife off and re-solder. Be sure to put the shrink tubing on BEFORE soldering the wire. LOL. We used a piece of black electric tape around the plug casing to further enhance the binding effects of the glue gun. I like to think it gives the thing a decorative sushi look. Thank you for the excellent pictures and instructions!
Feb 16, 2009. 11:10 AMDavid Levine says:
Where can you obtain the new plug- the power tip? I live in ireland. Thanks.
Jan 27, 2009. 6:35 PMHippoDan says:
I have to recommend against using glue as a strain relief. I used silicone when I fixed mine about a year ago, but now that it had broken again just past the end of my silicone strain relief, it's proving to be very difficult to get the plug apart again. When you do this repair, just prepare to be doing it again in a year or so, those wires are terribly thin and flimsy. Great Instructable, great pictures, wish I'd seen it before I fixed it the first time.
Jan 24, 2009. 6:21 AMTravholt says:
This was the first time I've ever soldered electronics, and it was a bit scary. The solder points for the wires are extremely close to nearby circuit board components and metal paths! Also, make sure you don't leave tin sticking out to the sides, as that will prevent you from slipping the sheath back on.
Jan 24, 2009. 6:18 AMTravholt says:
My strain relief was broken, and the outer wire was exposed and beginning to break. Now I'm left with a better strain relief than before, and have saved almost a hundred bucks to boot. (Although I bought a cheap soldering iron, but that's an investment!)
Jan 24, 2009. 6:14 AMTravholt says:
I did as mcircosta did, but after using the thin edge, I repeated with the back side of the blade, then with the back edge of a kitchen knife (which gets wider closer to the handle). Then I could get hold with my fingers and wriggle it off gently.
Jan 24, 2009. 6:07 AMTravholt says:
I didn't have heat shrink tubing, so I left that wire end exposed (but tinned) until I had soldered the wires back on and was ready to replace the cap, at which time I put hot glue around both wires. I think this has the added benefit of added strain relief too.
Oct 9, 2008. 9:11 AMMr_Ruckus says:
I always wondered... what is that nylon bristle stuff for in head phones anyway. Antistatic Insulation?
Jan 9, 2009. 12:26 PMDerin says:
It gives strength to the cord.
Jan 9, 2009. 11:12 AMfallingstarvideo says:
with mine, white top, I had to use and Xacto knife to place between the clear circle and the white outer sleeve. this with safety glasses, I was able to twist slightly the xacto blade not breaking it but I have broken it before. back to the white sleeve, I then used 2 very slim jewlers flat screwdrivers to pry each side up slightly.
Oct 22, 2008. 10:51 PMmage says:
overpriced Apple cables, dosent cease to surprise me that this would happen XC
Feb 19, 2008. 7:10 AMgabriahl says:
I WISH I'D SEEN THIS 2 WEEKS AGO MY CHORD GOT SO MANGLED IT STARTED FIRE. IN CHEAPSKATE DESPERATION I TOOK IT APART AND JUST SEPARATED THE WIRES SAME AS YOU BUT LEFT BUT LEFT THE ONES CONNECTED TO THE CIRCUIT BOARD SPLICED THE WIRES TOGETHER WRAPPED BOTH WIRES IN ELECTRICAL TAPE SEPARATELY THEN WRAPPED THOSE TOGETHER WITH MORE ELECTRICAL TAPE THEN WRAPPED THE WHOLE THING IN FOIL TAPE TO GIVE IT A HARD SHELL. NO SOLDERING. BUT WORKED. WISH I'D SEEN YOURS THOUGH WOULD HAVE SAVED ME SOME GUESTIMATING
Oct 22, 2008. 10:50 PMmage says:
lol, guestimating. i think that is a word is Bush's vocabulary
Aug 30, 2008. 4:39 AMDerin says:
Aug 14, 2008. 12:06 AMjonboytang says:
caps enuf? :P
Aug 26, 2006. 12:24 PMVon Klaus says:
not going to help be but my mom has this old powerbook from 95 the cable is not broken but you have to hold the cable into the computer to recharge. any help?
Jul 16, 2008. 6:38 PMcdawg14 says:
duct tape
Jun 20, 2008. 12:25 PMbrc3001 says:
Alot of times you can find computer power cordcomputer power cord manufacturers that have these replacement items for cheap with same day shipping.
Apr 7, 2008. 4:26 PMendolith says:
I repaired a plug on a different laptop cord yesterday, and used lots of heat shrink tubing for the strain relief. Hot glue inside would probably have been a good idea, though. Wish I'd thought of it.
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:geo
