Replace broken DC power jack on your laptop computer (UPDATED).
 by teatimest
OK, I had my kids running around my room and kept tripping on my laptop's power cable. Then DC power jack was damaged. I had to always keep pressing the jack in order to charge my laptop. I reached my limit. I was almost throwing my computer out of my window, but it cost about $1700 three years ago. I decided to fix it. If you don't want to spend $400 by asking professional, you have option to do it yourself. My cost was about $12 ($7 DC jack, $5 desoldering braid).
This instructable does not require advanced soldering/desoldering skill. I had never desolder anything before, but was able to somehow desolder the jack.
[UPDATE]
The problem kept coming back. So I did permanent fix using modem port in my latest instructable.
1-40 of 52Next »
powerjack00 says: Oct 18, 2012. 1:07 AM
Thanks for sharing, this information is very useful, but if you need to notebook power jack is better to come in to find out.
http://www.power-jack.net
jbrennan5 says: Dec 4, 2011. 4:37 AM
I love
"Relish your victory now."
Just do.
bpleduc says: Dec 26, 2010. 1:03 PM
We've been fixing these for quite awhile. Not too hard to do at all. If you do need help get in touch with us at www.synernex.com Good Luck!
barbaratu says: Oct 24, 2010. 10:11 PM
nice post,thanks for sharing.
http://www.laptopbatteriesinc.com.au/laptop-battery/dell/dell-studio-1537-battery
zack247 says: Jul 26, 2010. 12:50 PM
good job! this would work to put on a different kind of ac jack too, right? nice instructable, will keep this in mind. :) i see you use avg...
joechav says: Jun 26, 2010. 8:19 PM
Some laptops can be tricky to work on and require a fair amount of knowledge to disassemble. Once opened it is important that you have a soldering iron with enough wattage to melt the solder but being careful not to break the traces. You should practice on dead piece of electronics before doing this on your laptop. We can fix most dc jacks for $79.00. DC Jack repair
nacydeng says: Jun 24, 2010. 2:19 AM
It is the best way to buy a new one from http://www.feevoo.com, especially the Compaq 239704-001 AC Adapter(Input: AC100-240V (worldwide use) Output: DC18.5V 3.5A Power: 65W )
svaughan says: Mar 17, 2009. 6:44 PM
De-solder with a solder wick or solder sucker! Best way to de-solder with cheap tools is to clip off most of the part you want to de-solder. Just leave part of the pins so you can get them out of the hole. The larger area you have to heat up the harder it is to solder and de-solder. So if you fix a lot of parts the best thing to do is buy the best tools you can.
ineedhelpnow says: Feb 16, 2009. 8:28 PM
My kids tripped on the DC power cord to my Gateway laptop. It still worked but I had to move the power cord sometimes to make it work. I took it in to have the jack replaced, they said it was no problem. I would cost about $160 b/c they would have to open it up and mess with the mother board. Said it would take two days. The guy took the complete history of the computer. When it was time to pick it up, it was not ready, didn't have part. No big deal. Next day, he called and said that when he took the computer apart he noticed that the heat strip had been damaged b/c and he had to use expensive silver to fix the problem but that it was fixed. The computer is only 1 and half years old, hardly ever used. It's my 13 year old sons. He uses it only for homework. Today the man called and said he fixed the power jack but b/c we had used it with a loose jack the thing blew up when he plugged it in. He told me to come pick it up, it is useless now. He said I still owed him for the silver. When I took it in it was working. He never mentioned that it might blow up when he fixed it. Does this sound right?
teatimest (author) in reply to ineedhelpnowFeb 17, 2009. 10:48 AM
Oh my... 1. The silver thermal grease is like $10 and you can use it forever. 2. Since he mentioned the thermal paste, he might have fried the CPU. If you have short at the plug... I don't think it will damage the computer itself. It might kill the power adapter unit, though. Anyhow, it seems that he broke the computer, and you have to negotiate with the guy.
ineedhelpnow in reply to teatimestFeb 17, 2009. 2:44 PM
Thank you for your very helpful reply. Since I first posted this I have spoken with several experts that agree with what you have said. They all have said that if the laptop was working when I brought it in for a simple jack replacement, then it would not have blown up b/c we used it with a loose cord. Thanks again.
teatimest (author) in reply to ineedhelpnowFeb 17, 2009. 3:53 PM
No problem! I hope you get compensated for the laptop.
safebat says: Jan 9, 2009. 6:32 AM
my instructor taught me to do the thorough diagrams too and multiples as you dig down into the layers. His way was to use your small screwdriver to punch the holes out on your diagram and stick the exact screw into its hole. Some screws look the same and have different lengths and can cause contact problems if driven into wrong location. Thanks, I'm in the middle of repairing one of these in a Dell myself.
teatimest (author) in reply to safebatJan 9, 2009. 7:15 AM
You are welcome. Good luck on your repair!
jagg74 says: Oct 21, 2008. 10:41 PM
Finally, Thank you! I have been looking everywhere to find out how to do this THANK YOU SO MUCH YOU JUST SAVED ME OVER $100!!!!!! btw, Gateway MX6453's are cheap b/c the dc power plug has a nasty habit of breaking. Don't buy one. I wonder if I can find some magsafe components....
Laptop Freak says: Dec 26, 2007. 10:21 PM
This laptop power jack replacement guide will explain how to unsolder the jack in more details.
teatimest (author) in reply to Laptop FreakSep 3, 2008. 10:08 PM
Great resource! I added that to my instructable page. Thanks.
tresho says: Jan 11, 2008. 3:45 PM
Some laptops DC power jacks are quite difficult to de-solder. Glad you got lucky here.
teatimest (author) in reply to treshoSep 3, 2008. 10:08 PM
I've never tried others, so I guess I was...
tresho says: Jan 11, 2008. 4:33 PM
In addition to making paper notes, taking your own series of digital photos while going through the disassembly process as the author has done in illustrating this instructable is very useful. Once you have created a series of digital images, do the other owners of your laptop a favor by posting your images somewhere on the internet.
teatimest (author) in reply to treshoSep 3, 2008. 10:07 PM
Yes, my pictures were taken for that purpose initially.
tresho says: Jan 11, 2008. 4:29 PM
An alternative prying tool for removing plate connectors & other plastic covers from a laptop is a guitar pick. These are made of hard plastic with smooth tips, strong enough to pry up plastic panels and less likely than screwdriver tips to mar their edges.
teatimest (author) in reply to treshoSep 3, 2008. 10:04 PM
Yes, a guitar pick will do better job than credit card or screwdriver. I just not have any around. I wish I could play guitar, though.
mstng says: Sep 2, 2008. 1:08 PM
Nice instructions... About the screws..I used a piece of paper and wrote down the pages from the instruction manual and taped the screws in place. My sheet of paper now has about 10 areas with different page numbers and scotch taped screws next to the page numbers. made it simple to keep track...
teatimest (author) in reply to mstngSep 3, 2008. 10:01 PM
That is great idea. The documentation is the key, right?
dchall8 says: Jul 19, 2008. 5:10 PM
This is not a hard thing to do, but if you are squeamish about lots of small screws, maybe you should let a friend do it. My plug cost me $25 but doing it myself saved me $200. I following the instructions at laptoprepair101.com on my HP 7000. Every layer of guts got its own numbered cup for the screws. Then I stacked the cups on top of each other as I went along. To put it back together I just used the screws in the top cup and removed it when it was empty. I agree that desoldering the plug was the hardest part. It took as long to disassemble as it took to desolder.
teatimest (author) in reply to dchall8Sep 3, 2008. 10:00 PM
Ya, the desoldering part is hardest and.... it comes back again and again. I already did that several times. Now I have to find a way to prevent trapping on the power cord.
TheBigCahuna says: Jun 9, 2008. 4:06 AM
Desktop computers don't have all the problems that are built into laptops. If you don't need portability, don't buy a laptop. Parts are more expensive. Repairs are more expensive and laptops require more of them. Laptops all have flaws built into them. That's the price of portability. If you absolutely need portability you have no choice. I went though college (Masters) by taking notes on paper and then typing them up on a desktop at home. It was more work, but it was also a review of the notes while the subject was fresh.
teatimest (author) in reply to TheBigCahunaSep 3, 2008. 9:58 PM
I am taking classes and now I don't take notes any more. I just record them and listen to them while commuting.
f8l_0e says: Jun 5, 2008. 10:05 AM
For the external screws, I remove the screw from its mating surface, but leave it in the hole. I then cover the hole with tape. No need for labeling and it really speeds things up.
teatimest (author) in reply to f8l_0eJun 5, 2008. 12:08 PM
That is brilliant idea. I might try next time.
lbreevesii says: Mar 31, 2008. 5:21 PM
While it wasn't a hard swap, I was appalled to see the internal design of those little HP's that wal-mart sold for 399 a few years back. The center pin of the plug was TINY and therefore HIGHLY prone to breaking. HP knew this and designed it that way for a reason, so they could make money on repairs. They went so far as to put that crappy jack on its own small pcb with a much more hefty DC style jack that plugged the other side of the PCB into the actual motherboard. DISGUSTING and underhanded.
teatimest (author) in reply to lbreevesiiApr 11, 2008. 5:43 PM
ummm, hope they improved it.
headjerk says: Feb 11, 2008. 2:55 PM
I mentioned here that I had to fix two Fujitsu laptops because of the "poor design" of the AC plug. After I got them fixed I went looking for a CRD (Cable Restraint Device). I couldn't find one so I made one. My wife thought it worked so well I should make them and sell them. So I did. (SHAMELESS PLUG ALERT)
It's called a Jerkstopper. It works. The Kit comes with three different CRDs (USB, RJ11 and RJ45). Yea I know the name is "suggestive" or "funky" or "stupid" or Weird" but the device does work and stops the problem of the damage from daily tugging or pulling on the cable. www.jerkstopper.com
teatimest (author) in reply to headjerkFeb 14, 2008. 1:07 AM
You are right. The most effective way of dealing with this problem is prevention. Your hook might be good solution to that.
tresho says: Jan 11, 2008. 3:42 PM
I have recently repaired the identical problem on my Toshiba M35X-S149. It had already had its power jack and/or motherboard replaced twice by professionals, but the previous 2 repairs did not last long. Since my machine was out of warranty, I did it myself.
I decided not to even attempt to resolder it, since the previous attempts only lasted a few months. I removed the old power jack and replaced with loose 18 gauge wires that I brought out the back of the case, to which I then attached a really sturdy chassis-mount power plug.
What took the longest was taking the laptop to pieces and then reassembling it, just a long series of screws, clips and panels to take off in order.
By far the most difficult part of the process was unsoldering the broken power jack. Anyone attempting to replace a laptop power jack will most likely run into the same problem. It's hard to heat the power jack sufficiently to melt the solder where the jack is attached to the circuit board.
Just adding solder to a weak solder joint as shown in this instructable is worth a try for the first go-around, but be warned, the design itself is flawed. Power jacks should not be soldered directly to motherboards, but that's what most manufacturers do. This repair is likely to fail again. However, it is worth a try.
teatimest (author) in reply to treshoJan 18, 2008. 5:51 PM
Yes. The design is intrinsically flawed. I agree that.
tresho says: Jan 11, 2008. 4:26 PM
An alternate way of sorting the screws as you remove them is to use a series of zip-lock bags, each labeled with Sharpie or similar type pen. That way, when you accidentally brush/sneeze/blow away the screws/cups/bags onto the floor, they won't roll all over the place & get lost. Don't ask me how I learned this.
teatimest (author) in reply to treshoJan 18, 2008. 5:49 PM
I will try that next time... I hope there would not be next time, though.
tresho says: Jan 11, 2008. 4:30 PM
A guitar pick is a good tool for releasing catches like the one shown.
1-40 of 52Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
