HANDPOWERED SERVO TORCH
7,352
51
16
Published
Introduction: HANDPOWERED SERVO TORCH
About: Sciency Guy who is always trying to make some innovative projects,check out what i made in my instructable,Follow me if you think i will help you in making projects! Have a Good Day
In this instuctable ill show how to make handpowered led torch from servo motor
The basic principle behind this project is servo acting as a generator when given mechanical rotation which is similar to bicycle dynamo
Step 1: Materials Required
servo motor
small cube with lid
led
super glue
Step 2: Fixing the Led
make a hole on the cube so as to hold the led and passage of wire
Step 3: Servo Connections to Led
servo is connected to led by the 2 terminals present in both ledand servo motor
connect the led to servo and just give a check by rotating the motor shaft clockwise and anticlockwise
Step 4: Gluing Up
using super glue base of servo is attached to back side of cube
Step 5: Torch Is Ready Just Give a Little Rotation and Its Ready for Action
Step 6: Full Video of Making the Torch
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    16 Comments
    sorry nice try bit no.1 you kill the led verry soon.
    2 its a flash not a constand light
    3 to smal to handle
    i would put 1 item on it : Z -- you see here the letter Z, thats our paperclip bend it almost like that but with a Vertical LINE not scuare. put a piese of tubing on the side you turn the led on and you can CONTINU have light. (but place a resistor of 500 Ohm and see how bright it is then go lower in Ohm`s by 100ohm every time (not lower then 200\300ohms
    ya ill try to improve it....
    and dont get me wrong friend,
    its amazing in its simplicity and looks,but the name was what me akted to respond.
    as i say ,nice
    (related subjects) if we integrate rectifier , capacitor , modulated LED drive¹ with current control² ((then it's not sure if it's all worth it ... unless we succeed to find the working configuration for particular combination of hardware -- servo , LED , ...))
    ¹ https://www.instructables.com/id/555-Timer/step7/5...
    (the PPM drive is likely easier to fine tune for MOS-FET and vice versa than PWM -- about¹)
    ² http://forum.allaboutcircuits.com/threads/can-som...
    (there are not too many good precision high current limiting circuits -- about² -- though all above may need modifications to fit in to new needs)
    anyways nyc video.......
    New York City viideeoo nana nan naa nan naa naa naa naa naaa . . . Sempre assim, Em cima, em cima Em cima, em cima Sempre assim, Em baixo, em baciu Em baixo, em baciu
    (todays mood , muhahaa)
    very good initiative for servo generator use
    (i guess i have some floppy drives lying around F;i)
    When your Led will burn (soon), add a resistor to the new one, it will last much longer !
    ya sure ill try it out
    anyway thanks for ur suggestion..
    Let me collect these materials. Then i will do next things.
    I will try it again later. Thanks for such nice tutorial.
    Add a capacitor and a single pole, double throw (SPDT) switch and toggle between charging the cap and using it as a temporary battery.
    Ya surely ill try to modify it
    Ya sure sir I will try do it on my next instructable
