Soda Can Hydrogen Generator for Alternative Energy
Make Hydrogen On Demand from Activated Aluminum and Water.
THIS INVENTION IS NOW PATENT PENDING. It can be reproduced for non-commercial use. Anybody interested in commercializing this invention please contact the author.
I use a drop of liquid metal that I bought from eBay and aluminum from a soda can to produce hydrogen from water.
This reaction solves the problem of hydrogen storage for the hydrogen economy. Energy dense activated aluminum acts as the storage medium, liberating hydrogen on demand when exposed to water.
After the exhaustion of the reaction, the resultant aluminum oxide (alumina) is shipped to a power generator plant that reduces it back to aluminum. Since alumina is a suspension in water it can be delivered via pipelines to the power station.
Liquid metal is available here:
http://www.google.com/products?q=Coollaboratory+Liquid+Pro&hl=en&aq=f
It is usually listed on the internet as
Coollaboratory LiquidPro Fluessigmetall Waermeleitpaste
My other Instructables:
MAKE A HIGH VOLTAGE SUPPLY IN 5 MINUTES
Hack The Spy Ear and Learn to Reverse Engineer a Circuit
Super Easy E-mail Encryption Using Gmail, Firefox and Windows
Make a Voltage Controlled Resistor and Use It
Make a Ball Mill in 5 Minutes
Make a Rechargeable Dual Voltage Power Supply for Electronic Projects
Step 1Prepare the Aluminum
Cut the soda can into strips.
Sand the plastic off a strip.
The finished strip should be clean and shiny.
Proceed swiftly to step 2.
192 comments
1-40 of 192next »
Oct 24, 2010. 8:43 AMameenkhan says:
i need to know where i can find it liquid metal
Oct 1, 2010. 2:26 AMLefrançois says:
For the manufacture of "liquid Metal", is here (toner powder + vegetable oil):
http://www.dailymotion.com/video/xbz1r9_fabriquer-simplement-du-metal-liqui_tech
Mar 4, 2010. 8:18 AMankit_mait_07 says:
Hi
I have a small question.
Are there any rechargeable/refillable Hydrogen fuel cells having same power specification and size specs as a AA battery?
regards
bored_guy
Oct 1, 2010. 2:48 AMLefrançois says:
oui ici:
(bottom of page)
http://www.horizonfuelcell.com/hobby_rc.htm
Mar 6, 2009. 8:05 AMTheGoodLife says:
Wouldn't it be cheaper to sail the ship once. During the journey, the ship lays a grid interconnector to the US or UK. Iceland can then distribute its excess power at a lower cost than shipping it.
Aug 31, 2010. 8:37 AMwilecoyote22 says:
you have your numbers backwards. 80% of the power would reach the UK/US while 20% (approximate) would be lost to natural resistance in the cable. All of this means nothing though. We are forgeting that charging the batteries will be wasteful as well. No battery has zero resistance. If electric rates are really so cheap then why not just lay a superconducting cable like are used in the US for extreme distance? Sure they are expensive but nothing compared to building and operating a ship at sea. Besides, cables don't sink or crash
Sep 8, 2010. 7:31 AMwilecoyote22 says:
Ok I admit that I dont "Know" of a superconductive power cable in commercial use exactly. I am assuming since they were doing demonstrations as early as 2007 over several hundred miles that they probably are being used commercially today. http://thefraserdomain.typepad.com/energy/2007/05/next_generation.html
Aug 21, 2010. 7:51 PMJimmy Proton says:
another way to make large amounts of hydrogen and oxygen is to put steel into acid in a bottle with a balloon on the top or something
Aug 15, 2010. 2:45 PMDRY HHO says:
While the idea is interesting the resources from Iceland is not. Currently there are major conflicts over Alcoa trying to industrialize Iceland. We now that industrialization didn't work. The only thing it did was add to how we pollute and destroy the environment. There 200 years too late for industrializing Iceland. Iceland is a place of natural beauty that should not be harvested for profit. Aluminum has great uses for these types of designs... we just need to be aware of where we get it from. These ideas are to protect the earth not pollute it in another fashion.
Dry hho
Jun 26, 2010. 7:28 PMalter baron says:
It's sad how academics always rush to patent such simple discoveries, especially when the discovery holds a great deal of promise for the future. Patents on processes such as this one do not help to stimulate innovation; rather, the drive to innovate is extinguished because the very roots of that innovation are owned by individuals. Until we can emancipate ourselves from the profit-motive, we may never see a truly green society.
Jun 28, 2010. 2:03 PMthefunktopus says:
Regarding the icelandic scheme 1) the US does not have a national grid as such, grids are independent of state so electricity cannot be transferred between them and 2)would it not be better to invest in electricity transimission lines between iceland and the uk. If a high enoughvoltage could be created, it may be viable.
Mar 7, 2010. 9:01 AMgateon says:
Or, you could just use the works to make hydrogen.
Aug 20, 2007. 2:50 AMDrStoooopid says:
You let it set long enough for the liquid metal to penetrate the aluminium, thus accounting for the violent reaction, as there wasn't a way for their any oxidation to occur, because the liquid metal thoroughly "wetted" the aluminium. You should be able to recover your gallium from that dried up mess on top there, just like normal.
Jan 12, 2010. 5:42 PMKryptonite says:
How so?
Aug 20, 2007. 10:28 PMDrStoooopid says:
that's what true wetting is...the liquid metal soaks into the other metal. That's supposed to happen. It didn't happen before because you didn't let it sit long enough before.
Aug 29, 2007. 2:14 AMAustringer says:
The terminology is different, but ask a jeweler about eutectic melting. If you have a drop of a low melting alloy (lead, tin, antimony, etc.) on a piece of sliver or gold and heat it up enough to melt the low melting alloy, it will tend to pull the high melting alloy into solution. This tends to eat big pits (at least at the jewelry scale) into whatever it is that you are working on and cause no end of cursing.
May 8, 2010. 8:27 PMmerseyless says:
just hypothesising here but the mercury might have removed the unreactive aluminium oxide and revealed the aluminium, which does react with water, dont know if it would have reacted that vigorusly though...
Jan 12, 2010. 5:35 PMKryptonite says:
Is this "liquid metal" Galinstan?
Dec 30, 2009. 10:09 AMfireblast_1212 says:
(removed by author or community request)
Apr 27, 2009. 4:54 PMHunter4000695 says:
I hait to burst your bubl but Iceland can't supply all the world with power. It's not possible.
Jun 6, 2009. 10:34 AMmacrumpton says:
Oh, It's not possible! Why didn't I see that? Seriously if you are going to say something is impossible, at least have some kind of concept behind your assertion, and ideally have some links and figures showing how you have come to this conclusion.
Jun 12, 2009. 2:21 PMHunter4000695 says:
In 2005 we as a world yoosd 5*1020j.
Let me give a agsampl of that 1j is a nuf energy to rase 1kg 1m.we could of
raisd 1kg 500000000000000000000m
if it wus in mile it would be 3.106855961e+17mi from erth.
And you think that one countrie could do this?
not taking in to the risk of puting all your eggs in one baskit.
Dec 26, 2009. 3:38 PMlofty says:
Gravitational potential energy = mgh in a linear gravitational field
At low altitudes, the earth's gravitational field can be modelled by an approximate field strength of 9.81 n/kg
Anyway it would take 9.81J of energy to raise 1kg to a height of 1m
But since you are talking about raising it high enough, you would have to consider the earth's field as a radial field, gets a bit more complicated but here goes.
Work done = mass * (change in gravitational potential)
Gravitational potential = -GM/r
therefore work need to raise 1kg up to 500000000000000000000m
r = radius of earth = 6378100m
G = gravitational constant = 6.67^-11
M = mass of earth = 5.97 * 10^24
Work = 1 * (-GM/(r + 5*10^20) + GM/r)
Work needed = 62MJ (Mega joules)
i.e 62,000,000J
Now i'm sure a power station is able to output that amount of energy very easily as most are in the order of hundreds of mega watts, therefore, it would take less than a second to output the energy needed to raise this 1kg to the height you said, not 5*10^20 J as you said
Go learn some physics, learn how to spell.
Dec 29, 2009. 9:34 AMHunter4000695 says:
well I made a mistake it's not 1j is a nef energy to raise 1kg 1m
it's, 1 joule is the amount of energy required to exert a force of 1N through a distance of 1 meter. It has bin a fue years sins my high school physics class, but I don't remember having to add gravity to this problem. I thank it includes it
crekt me if this is false.
Jun 14, 2009. 12:34 AMDerin says:
try to use a spell checker please
Jun 15, 2009. 2:25 PMHunter4000695 says:
I have dyslexia, so it is hard to spell. And yes I yoos spell check but the ikon is gon on the reply butten!!! :0
Dec 24, 2009. 9:39 AMrimar2000 says:
I'm dyslexic too, and besides I speak Spanish, not English. But I proofread iteratively until the result is understandable (at least I think that).
You have more obligation to make you understand, than we interpret what you write. It's BASIC!
Dec 25, 2009. 8:44 AMHunter4000695 says:
If you have dyslexia then you understand the frustration in writing a simple coming. I don't have a lot of time to waist on this.
1-40 of 192next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
121
Author:Biotele(Biotele)
Make a better Instructable, and the world will beat a path to your website.
