3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Salamander Pendant
Salamander Pendant
I made this pendant using the "Dusky Salamander" as a model. It's made from a section of 3/16" steel dowel rod and a paper clip. I had a good time making it. The rod is available at any home improvement store.
Step 1Turn the dowel
Turn the dowel
Chuck the section of dowel into a drill press. The one I’m using is an 8” press laid on it’s side.
Spin the dowel and shave down the desired profile with a file.
Make sure it cools off before you touch it.
66 comments
1-40 of 66next »
Jan 18, 2012. 11:40 AMJeff-of-all-trades says:
Made this as a Christmas gift for the wife and she loved it. Thanks for the Instructable!
Jan 6, 2012. 5:42 PMblack hole says:
I made a Negishi Ryu shuriken using this method. I never would have tried if it weren't for this 'ible.
Jan 7, 2012. 8:45 AMblack hole says:
Thanks!
Aug 27, 2011. 8:01 AMhechao says:
hello, nice work! what kind steel is that, it's really difficult to shave it ... the press should be very strong?
Jan 4, 2012. 2:25 AMtmack0 says:
Excellent 'ible, Im finishing up one now as a gift for a caving friend of mine. I ended up using 3 nails, one large one for the body and two small ones for the legs. I turned it on a hand held power drill using a bastard file and used a cheapo propane plumbing torch to heat it for bending. Looks good so far, thanks for the idea and guide (will add a pic when Im finished)!
Jan 5, 2012. 12:58 AMtmack0 says:
as promised, my version made from nails
thanks again for the instructable!
Aug 28, 2011. 6:07 PMhechao says:
I had a drill press, the speed of motor is 1420 RPM, but I can switch the belt on the gears, so the speed can go to 3100, and the power of it is 250W (the motor is 1/3HP), does it good to do this? I bought a stainless steel rod type 303, is it a good one? Thanks again!
I took a look of all your work, nice! impressive!
Oct 20, 2011. 8:50 AM1307invert says:
Say, how do you keep your pieces from rusting? it seems like, with such a high polish, that the wearer might have to oil it or such to keep it from growing a dusky red skin. am I missing something obvious?
Aug 22, 2011. 9:26 AMLildevil963 says:
very nice also ty for the instructable on polishing it saved many unpolished things from being make fun of :P
Aug 23, 2011. 10:38 PMp.ingenhoff says:
super arbeit!!!
Aug 23, 2011. 7:29 PM42lwood says:
This is very neat and pretty, and extremely cheap compared to most jewelry stores, but I think the Ible could have been worded better.
Aug 19, 2011. 9:25 PMastrong0 says:
how long was the straight piece on the press?
Aug 20, 2011. 11:49 PMastrong0 says:
such high precision instruments you have!!
Aug 19, 2011. 5:40 PMabvnatter says:
That's beautiful. Thanks for posting. My gf really liked that you staged it on the polished rocks.
Aug 19, 2011. 5:35 PMtriumphman says:
What type of solder did you use, silver solder, 50/50, 50/60, like the plumbers use for copper pipe ? Flux type ? Nice job, I can't believe those paper clips made such nice legs! Awesome ! Got to try this ASAP! Thanks for sharing your expertise!
Aug 19, 2011. 7:59 PMastrong0 says:
Yes, i completely agree with you i must also know for i have want to make a salamander from steel dowling!! ah the skills learned from drama class.
Aug 19, 2011. 8:03 PMmitch and sean says:
Drama? 0_0
Aug 19, 2011. 8:13 PMastrong0 says:
ya i was doing the lights for a play at my school and that was one of the lines in it......except for the salamander part. So no i was never in drama. do you not care for drama?
Aug 20, 2011. 10:12 PMmitch and sean says:
No I do care I just didn't think u learn that stuff in drama
Aug 20, 2011. 11:50 PMastrong0 says:
it was more of "by chance" that i heard it.
Aug 18, 2011. 9:56 PMchaitanyak says:
this is one of my favourites in the metal work diys!
Aug 19, 2011. 9:47 AMjanemermaid says:
This is a really gorgeous thing, thanks for posting it! Are you making any more? would you ship me one?
Aug 19, 2011. 8:01 PMastrong0 says:
Also, very well done instructable, clear and easy to understand.
Aug 18, 2011. 10:36 AMcwix09 says:
What kind of torch did you use? I dont have one and I was wondering what cheap alternatives i might be able to use...
Thanks!
Aug 18, 2011. 6:55 PMsaraed says:
WOW!!!
Aug 18, 2011. 6:21 PMpbecker83 says:
Very cool! And you make it look so simple. Great job!
Aug 18, 2011. 5:08 PMbajablue says:
wow... that is so beautiful!
Aug 18, 2011. 4:35 PMGreasetattoo says:
Your a Master, my friend!
GREAT work!
1-40 of 66next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
964
Author:Mrballeng(Visit my shop)
I've opened up shop =). Click "Vist my shop" to check it out. Or write me at info@mrballeng.com
