Samurai Costume
Samurai Costume
A samurai costume I made using Sintra (PVC foam board). This costume did take about 3 weeks of construction to complete, and could be even more time consuming for some.
I had an interest in making this after running across the website sengokudaimyo.com. There is an armor manual on that website that shows traditional methods of real samurai armor construction. I did not follow every step because it probably would have taken more like a year to make. I did a few variations based on how real samurai armor is made. What is great about samurai armor is the variation in lacing color and decoration that you can do.
Through making this, I did not take as many pictures as I should have to make an Instructable, so there may be some pictures that dont look that great because the paint may be between coats or something like that. Feel free to ask any questions though, or to visit the Samurai Armor page.
Some items you will need to make a suit of samurai armor are:
4'x8' sheet of Sintra ~$40
3-4 cans of Rustoleum plastic paint ~$4.00 each
1 folkart paint for details ~$3.00
1 Mod Podge hard coat ~$5.00
Hot Glue gun
1 Pkg of glue sticks
A bunch of shoe laces
Decorative lacing
a box cutter or carpet knife
A drill and 1/8" drill bit
So the most expensive part is the sheet of Sintra that you will have to find from a plastic distributor found locally. Don't buy it from a sign store because they will mark it up a lot. Can sand the sintra if you want prior to the painting, but I found that with a few coats of the paint, it came pretty smooth.
I broke each step down by armor piece and the traditional Japanese name for the piece.
Things that should be noted about sintra. It is a thermoplastic, which means it has a low melting point so you can heat it, shape it, cool it, and it will hold that final shape. Some people have used their oven to heat it and some use near boiling or boiling water. I chose to use water because it heats it faster and I could get more pieces contoured faster because the sink was close to run a trickle of cold water over it to keep its shape. You may want to use some gloves that will keep some of the steam and heat away from your fingers. Also when cutting the sintra, be sure to score it a few times and take your time cutting it. it is easy to skew off your line and end up having to re cut or sand the error down after cutting. If you are going to cut on the floor (since it is a big sheet) be sure to use a piece of plywood under the sintra and sit or kneel out of the way of your cut. I cut myself twice on this project and I am lucky i didn't need stitches!
Diclaimer : Please read the directions on some of these paints and chemicals, and make sure you are using proper safety equipment for them. THIS IS NOT A KID PROJECT, parental help and or supervision is mandatory in my opinion. There is a lot of cutting, painting, and using hot things, like glue guns and hot water.
So on to the first piece......
Step 1The Do (chest and back armor)
The Do has 4 parts to it, the abdominal section, the chest section, the lower back section, and the upper back section. All the strips( I will refer to the strips as lames though, as it distinguishes a piece form a section) for each section were made 2.5" wide, but the lengths are different for some sections. Before starting to cut, you need to make some measurements. The main measurement you need is the widest point on your waist. There are variations and more measurements to take, but I found it to be a little to complicated to make a "V" contour to the piece. Besides, my waist is not so small ! Ok, so measuring your waist. Once you have that add .5" to 1" to it to allow for under clothing, divide it by 2 so that the lower 2 sections(abdominal and lower back) equal the waist size plus our added inch.
Abdominal section: Once you have the needed length for this section, you have to cut it with one side straight, and the other side curved. This makes more of a rounded appearance for the abdominal section that most breastplates have. One way to do this is to use a poster board template the same dimension of the abdominal lames. Find the center point on the poster board piece and use a flexible ruler or something else to make a subtle curve out to the end of one side of the lame. You only want to take of about .5" on the outer end. Trace the curve on to your template and cut it out. Now you have a template that is half the length of the lame and you can just flip it to get both sides the same. I added a pic below to illustrate this, but its in MSpaint ! Also, you want to drill a series of holes along the sides of the abdominal section to add a 2" x 10" panel of sintra to overlap the lower back section. This is for velcro so the Do can be removed easily enough. Just try and make sure the holes on the abdominal section and the 2x10 panel match up in spacing. You can just send a lace through these 2 parts to attach it.
Chest section The chest section is done in the same way that the abdominal section is, only that the top 3 lames are only 12" across. The bottom lame of the chest section is made 2" longer to make a transition curve from the chest section to the abdominal section. It seems small, but it will give you room to move and it fits on me well at 6' tall. The top lame of the chest section was cut using a glass to trace the round parts and a straight edge to connect them. This adds a more decorative look to it and the curved sections left were bent forward for a better look. That is where your shoulder pieces will attach.
Lower and upper back sections These are fairly easier to make then the abdominal and chest section. The lower back section is 4 lames at 2.5" wide and half of the circumference that you calculated earlier. The upper back section I made 4 lames at 2.5" wide and 14" long. The upper back section should be wider then your chest section. Again, the lowest lame of the upper back section was made 2" longer at each end to make a transition cut to the lower section.
So that was the front and back Do construction, however, there is more. You have to shape the plastic to contour to your body.Try and do this forming before you drill the holes. With the holes i found it to be a weak spot and it wont form a smooth curve. You can flatten these pieces out to drill and it will spring back. It actually goes pretty fast once you get the hang of it. I used a big pot of near boiling water to heat up the sintra. I just ran the piece end from end through the water until I felt it getting loose. You may want to practice on a scrap piece, oh, and don't burn yourself.
Traditional samurai armor was contoured and laced (or riveted) together. It is best to consult the website on my intro page if you want to follow it to the "T". It is a lot more work and I could not justify it for this costume. The holes for the lacing also follow a certain pattern. I recommend cutting your lames, sanding if you want, shaping the sintra, then drilling the holes for the lacing. There are templates for the holes that can be printed out here. the best way to add the holes is find the center point (which all ready should be marked from your cutting) and measure out equal distances to the sides. I think I went every 3" for mine from the center of the lame.
For drilling these holes, I found it best to drill all the holes for an abdominal lame and then use that for the template. You can use this lame for drilling all of lames of the Do, just be sure to line up the center lines of the lames so your lacing matches up. You can stack 3-5 lames to drill at once as long as you have clamps to hold it in place while drilling.
After drilling, its time to paint ! I put around 3 coats of paint on all the armor sections but depending on how you spray, you will be able to tell when it looks uniform in color and has a semi-gloss look to it. Once paint is dry, you can tack all the lames together using the glue gun and see how it looks. Samurai armor usually had an overlap of the lames but I felt the sintra was to thick for that look, so I put them together edge to edge. It still turned out well, just need glue to hold them together instead of the lacing doing it.
Lacing If you used the lacing templates from that website, you might have had to modify the height of the pattern to fit your lame width. That's fine, just use the picture below to see how the lacing goes in. You can refer to the samurai armor website again if you have any problems.
This is the biggest and hardest part of this costume!
70 comments
1-40 of 70next »
Dec 26, 2011. 7:24 AMArmourFanatics says:
Hi, nice work on the armour. Me and a buddy are wanting to make our own armour sets and we were wondering if there was any possible way that you could maybe make a simple guide for using the method that you used. It would be upsetting if we tried to read through your whole guide and make our own changes just to end up making a mistake. If you think you could make it how long would it take you to type up, possibly? Please. :D
Oct 12, 2011. 6:53 PMTakeda8 says:
Great tutorial and i'm on it..
However sintra is hard to find over here so I have to make it of either thick leather or wood :S
Leather is very expensive and with wood it will take a very long time to finish
Jul 14, 2009. 11:35 PMJonnyboy0121 says:
Awesome job, this is some fantastic looking samurai armor! I'm thinking of making a set out of the same materials. But I have a few questions regarding the durability of the sintra... because I've never had the experience of handling pvc foam board myself. Would it stand up to say... a beating from foam weapons and possibly a few falls to the ground? Also, what thickness sheet did you use? I would assume either the 3mm or 6mm based on the price you said you paid but I'm curious to know. Thanks in advance!
Aug 17, 2011. 7:06 PMLord Jon Bigglesworth says:
If you really wanted to,you could use bamboo, which is what original Samurai armor was made out of. The brackets that hold in palm fronds would suit the purpose of a mock battle, and they are already pretty much formed for you, all you would have to do is attach them to your body somehow, maybe with strips of fabric. I'm trying to make armor out of those, once I'm done I'll post it.
Aug 3, 2010. 3:25 PMjdezwaan says:
PVC piping! Use a heat gun to mold it and it's very strong, it could probably stand up to a knife thrust let alone mock battles
Feb 8, 2010. 7:16 PMGameMasterNick says:
Lammelar plates are a great choice.  sengokudaimyo.com recommends Noble Plastics, Inc. which makes plates for the SCA.  The effingham line are made explicitly for Japanese SCA battles.
http://www.plasticlamellar.com/information.htm
Jun 24, 2011. 2:10 PMPlo Koon says:
It looks like a cross between a samurai warrior and Iron Man.
May 9, 2011. 8:52 PMnbohn says:
do you have to use shintra or can you use cardboard?
Nov 27, 2010. 11:00 AMjudo_shane22 says:
Using the same website and some of your ideas (menpo specifically) I made this out of a black 55 gallon plastic garbage can and black shoelaces
Dec 17, 2010. 11:12 AMerykthebat says:
Did you use a viking helmet as the basis?
Dec 29, 2010. 10:16 AMjudo_shane22 says:
yeah....and drilled holes in it and laced in the other pieces (after cutting the strips i threw them in the oven at its lowest temp for a few min so it will be more pliable and will hold its new shape better
Nov 6, 2010. 1:40 PMarveyda says:
Just wanted to toss out to the author that I used this set of instructions to build a suit out of aluminum flashing. I took apart a square flotation cushion and used the 1/4 foam pieces to add some structure and padding behind the chest and back and under the shoulder pieces. Looked great, was relatively lightweight, and was a blast to make. Thanks!
Sep 29, 2010. 7:18 AMtater252 says:
yeah how many pieces did you use?
Sep 3, 2010. 8:56 PMDon,t try this at home says:
If i wanted to make this out of steel how thick should the steel be and do i do anything driffernt???
Sep 6, 2010. 7:40 PMpunkhead58 says:
Aluminum would probably be preferable to steel since it is lighter, easier to work with, and cheaper. Thin gauge (16 or so) would be best. It's relatively easy to cut and bend. (But it's also very sharp!)
The only different materials that you need are tin snips instead of scissors; epoxy and rivets instead of hot glue; and spray paint that is meant for metal.
As far as assembling it, I don't think that you would have to do anything different.
Sep 7, 2010. 3:25 AMDon,t try this at home says:
sorry i missplled that * want* lol
Sep 7, 2010. 3:24 AMDon,t try this at home says:
I ant it to be able to take a hit from a sword thats why i said steel lol i can just see one of my friends say lets try it out
Sep 3, 2010. 10:09 PMDon,t try this at home says:
O ya almost forgot shouldent there be more armor on the legs
Sep 4, 2010. 12:02 PMThe Jamalam says:
I know this is slightly off topic, but I think I just remembered why the original pokemon Kabuto is named so - he is pretty much a helmet :)
Mar 8, 2010. 11:49 AMsebacoraje says:
Tanks dude I'm going to make one of metal plates of hard plastic tanks
Aug 3, 2010. 3:22 PMjdezwaan says:
I'm going to try this out of PVC:extremly durable and easy to work with using a heat gun and normal woodworking tools
Jul 25, 2010. 6:52 AMjjthejet29 says:
Thanks this really did help me in so may ways.
Nov 9, 2009. 6:11 PMdachandepredator says:
How many peices of shintra did you use?
Nov 3, 2009. 5:49 PMyour dog says:
You totally look like kensei from the show heroes!
Nov 2, 2009. 1:51 AMstunami says:
I made an instructable for my armor that I made. Your instructable was what originally peaked my interest for me to make mine. I gave you credit in my instructable for the inspiration.
Unfortunately, I wasn't able to make a helmet, or the leg/ arm pieces, but next year I will. I also resorted to cardboard because I'm out of work at the moment and didn't want to buy sintra. Once I get a job though I'll be working on a super authentic version.
Let me know what you think!
Sep 24, 2009. 3:35 PMtechdechman says:
this is bomb
Sep 5, 2009. 9:15 PMstunami says:
Is the second picture new?
Aug 16, 2009. 3:51 PManonygrazer says:
You captured the essense so well with such average stuff. Absolutely fantastic.
Aug 10, 2009. 8:27 PMJayvetron says:
Thanks, the armor looks Awesome! Gave me great ideas!
Jun 9, 2009. 8:52 AMMobiusdiablo says:
I'm having a real hard time trying to find some sintra. The only place where I can find it is online, and the cost for it is roughly $600. Is there anyway to get sintra for a cheaper price?
Jul 5, 2009. 6:08 PMkentw says:
Finally found a sheet of sintra for a reasonable price, plus they ship it:
http://www.rjsign.com/Merchant2/merchant.mv?Store_Code=RSS&Screen=CTGY&Category_Code=PVC
$25 bucks for a 48in by 96in (4x8ft) piece of sintra. Plus they ship it to you!
Enjoy.
Jun 15, 2009. 10:27 AMMobiusdiablo says:
okay thanks. I think there's a major plastic making factory a few towns over, so i might try there.
Jun 20, 2009. 5:52 PMDraxis says:
Very neat, I am making a Samurai-Roman-is body armor thing (and hopefully helmet) out of aluminum sheet metal, and this -ible has been a big help in my planing and is a great example- thanks!
May 23, 2009. 1:22 AMstunami says:
I'm going to make this for my costume this year. But I'm also going to make one for my wife, who's Japanese. I'm wondering how I should mod it for this. Any ideas? Were there ever women samurai?
Apr 8, 2009. 7:24 AMAcide Nitrique says:
Juste one question ...
4' x 8' Sheet Of Sintra ...
What is the unit do you use ? Centimeter ? Inch ? Foot ?
( Sorry for the bad english ' )
Apr 9, 2009. 5:05 AMAcide Nitrique says:
1 foot = 12 inches = 30,48 cm (exactly) — 1 m ≈ 3,280 84 feet
4x30.48 = 121.92 cm
8x30.48 = 243.84 cm
121.92cm x 243.84cm =°
Apr 8, 2009. 8:44 AMbluesquirrel says:
Typically people use the apostrophe ( the ' symbol) when they mean the measurement unit of feet. It's an odd, and confusing method, but we use it a lot in the US (Not sure of Atrohpius' nationality, but I know mine) instead of just spelling out the word. My own nation's writing methods confuse even me at times :/
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:Atrophius
