Remove these ads by
Signing UpStep 1A dull bit and a sharp bit
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
I should not complain, father being a carpenter, drilled, into me what a drill was.
you and i are same age , different backgrounds. Good Work.
Ron
That reminds me of something my mother drilled into us. She was a registered nurse. My brothers and I were the only kids in our one-room elementary school who could tie a tourniquet. Further, if at age 5 or so, multiple people needed one, we were to write TQ on their foreheads in lipstick so we would know to come back and release the tourniquet periodically so that the tissue beyond the tie point would not die. I do not know where we were to find tourniquets or lipstick, and I do not know that anyone would ask a 5 year old to handle such things, but we were trained and ready.
http://www.gadgetbuilder.com/DrillSharp.html#Inexpensive
Raising the contact point well above the grinder shaft avoids this problem.
Thanks!
Just wondered why in step 12 the tip appears to be dragged across the grinder face before starting the wheel and then swung back. Would it be better to swing to the left, start the wheel and then swing to the right?
If a bit is going to be drilling hard material, you will want the end to be more flat so it won't dig in and dull fast, and you will ALWAYS want to center punch your mark to prevent a drill from 'walking'. The 59° angle used on most sharpeners is a standard angle for mild steel - for softer materials make the point more like a pencil but be careful of how much more pointed you make it, it could try to screw itself into the wood, plastic or whatever you're drilling. I guess my point is to go in small steps until you know what works for you!
Try starting with a large bit if you aren't familiar with the procedure and remember that if the steel gets hot enough to turn black at the cutting edge, you have just removed the carbon from the edge and it will dull VERY soon. You must grind the metal slowly and dip in water or some other coolant frequently so as to prevent that. Get a new bit to look at after you have tried your hand on a big one and see what the difference is, there should be very little. When thinning the web, remember that the thinner the web, yes, the easier it will penetrate the work, but also the easier it can grab and split the drill down the center making the drill bit trash immediately. If the sides (lands) are worn on the drill bit, it WILL grab and break off many times when you need it most - inspect drills before using them to keep from ruining your project... After grinding, hold the bit up with a bright background behind it and with the cutting edges going left and right from your body - you need to make sure that both the tips are the same height and that the point is in the center before you attempt to thin the web if it is needed. If there is a pilot hole with a greater diameter than the thickness of the web, no thinning will be required.
Whne grinding by hand, always hold the cutting lip level against the wheel at the center height of the wheel and rotate the drill upwards to make the relief. Grind slowly and don't try it with a wheel that is out of round, you will get hurt badly. Dress the wheel to be true before starting any grinding process. Always use safety glasses or goggles when grinding and if there are any questions, stop what you are doing and research it- SAFETY FIRST!!
The 59 degerees is the angle on one side of the bit to the centerline of the bit, so the 118 degrees that you mention is the same as what I'm doing. The finer the grit you use means that you will have to dip it in water or coolant more frequent but it will give you a better grind as well. I have used a 60 grit wheel and gotten good results, it's just a matter of taking your time and knowing what to do. Practice makes perfect, and then when you think that you've got it, then practice a lot more..... you'll see that there are ways to do the job and make it a lot faster and still not burn the bit! If you never have made the metal black or blue at some point during sharpening the first hundred bits, you have not really tried like you should. Know when it will turn blue and stop short of that. Small bits will turn blue a lot faster than larger ones due to the mass that will have to be heated from friction to cause it to turn color and burn the carbon out...
This is not something that you can pick up in a few days, maybe not in a year. I have sharpened bits for over 25 years (daily) to do as well as I do. The first thing that someone needs to do when attempting to sharpen by hand is to really study drill point geometry closely. Understand all the parts of the drill and what their specific function is and why it is needed to be the way that it is. Once you understand all this, you must try a few thousand bits before you get it close enough to perform well for your application consistently.
One point to remember is that the angle of the point must be reasonably close to what is recommended for the application that you are going to use it for. the more pointed it is, the more it will tend to pull itself into the material being drilled, so that material must be soft enough not to split the drill down the web. The harder materials will be better served drilling with a much less point on the drill - almost a square end. The relief behind the cuting edge has a bearing also - hard materials need to have a relatively low relief (.001 to .003") and softer materials like wood should have a more pronounced relief(.010 to .020"). If a material is not drilling fast enough, it is probably due to the web being too thick and must be thinned OR the relief is way too shallow. Be careful to closely inspect the lands for drilling materials like bronze, this material tends to wear out the lands and the drill will grab and split the drill down the web and break off in the hole - not a pleasant task to remove. It takes some homework to fully understand drill bits even though they are as common as they are.
[note: with this method, it is even possible to restore some life to other rotary tool bits, though i would use them for roughing work]
One tip on drilling large hole, if using a pilot drill, use a small diameter drill compared to the diameter of the finished hole. The the pilot drill should not be smaller than the thickness of the larger drill's web.
Thanks for your comments.
What amazed me was how many production "machinists" had no concept of a properly ground tool. I don't know how many times I tried explaining cutting tool rake and clearance angles.
$7.99
$16.95
There is one company making and labeling them for whomever wants to sell them. Just click on the hot linked price you wish to pay.
People that claim they can do it are just lucky once in a while. I say test a hole with a pin gauge; you'll find its cutting large.
You don't need two sides to the bit to make the bit cut. If you have a bit with two flutes, the bit will cut twice as fast as a singe flute bit.
Upon close examination, a two-flute bit will cut a triangular shaped hole! (trochoidial shaped). If you want the hole round, drill it 1/64" under and ream it out. If you need to thread the hole, you can skip the ream.
Search for "Draper Drill Grinding Attachment" brilliant only £17.02
Thank you. As you can see from the various comments, some people really like the Drill Doctor system. Others very much like sharpening by hand. I have always been pleased with the sharpening jig I demonstrated in the Instructable. I am just a guy with a home workshop and it does well for me. If you have many dull bits in all sizes you can have fun making gifts of sharp drill bit sets to friends.
