The only light on the PC is the power light and the HDD light, the power LED isn't too bright, the same for the LCD monitor and the HDD led is in the back of the PC case, the keyboard leds can be easily turned off so it isn't an issue. Now the real problem comes with the optical mice included in the PC. My older mouse will get bored of being red-shiny all time and will turn off but this new mouse won't, it keeps shining bright red light all over the desktop all night long.
Something has to be done...
The goals to this instructables are:
Kill the red light.
Keep the mouse aestetics nice and unscratched, since it's brand new and good looking.
Same or better functionality.
No analogic/mechanical electronics involved (forget about putting a switch or anything like that).
Well, the goal was achieved very easily and with a very few tools.
I'll show you on the next step.
Remove these ads by
Signing UpStep 1Testing, testing, 1, 2...
-Small philips screwdrivers
-Soldering iron
-Some flux and solder wire
-Cutting pliers
-875nm Infrared LED
The specification sheet of various optical sensors for mouses say that it can work with no problem using infrared light, but not all sensors are the same so, first, you need to make sure that the particular one you have, can move on IR light, to test this, go get your IR TV remote and turn off the lights, (the HT, sat or audio remote will work too as long as it uses IR Light and has enough batteries) point it to the optical sensor of the mouse and press a key on the remote, keep it pressed and see if the mouse reacts to the invisible light, you can be aware of this because of the change in intensity of the LED inside the mouse or by the cursor moving on the computer screen.
If the mouse reacts fine, then go ahead and try the next step, if it doesn't do anything, you can't modify your mouse using this method.
As it has no light emitting LED ;)
I don't get it...
I have a wireless battery operated mouse and it drain the battery quite fast...
You can't connect two on the same place.
