Simple Elegant Guitar Stand
77,383
727
46
Published
Introduction: Simple Elegant Guitar Stand
I designed this guitar stand to be universal and really simple:
  • no glue
  • no screws
  • no nails
  • just one piece of wood.
In this case I used a board of oak wood, 25mm thick, about 22 cm wide and about 38 cm long.
You can use the template I made and modify it to change the size. I found that a corner of 9º works best on all acoustic guitars, I haven't tried an electric guitar yet tho.
If you decide to make your own I would love it if you'd send me a picture of it at stand@lennartdemeij.com
Step 1: Transfer the Template Onto Your Board
I printed my tempate on an A4 sized piece of paper and punched holes in it on interesting points so I could draw inside those holes on the wood.
Step 2: Drill Two Holes
Then I drilled two holes with a drill having the same diameter as the thickness of the board (in my case 25 mm).
I wanted to keep the holes round and just off center to ensure a snug fit.
Step 3:
I used a fine saw to work inwards from the hole to be able to make the middle cut. This did require some patience however :-)
Step 4:
I first completed the middle cut to keep the structural integrity intact whilst working on the other hole and finally the last two cuts to finish the guitar stand!
Then I tried to fit the pieces together, sanded, tried again, sanded some more and then the stand was finished!
11 People Made This Project!
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
46 Comments
add the non hook side of sticky velcro so as to not scratch guitar
Nice!
My fiance' is making this tonight.
Perfeito Farei vários pra deixar na igreja, é simples e elegante.
Obrigado! Por favor, mostre-nos fotos! :-)
com certeza será um prazer!!
This is great! and the fact that its your frist Instructable I hope you do great I voted for you good luck.
that's so nice of you! i hope everybody does the same :-D thanks!
Very nice, simple, functional. I think I will make one.
We have a metal guitar stand, and it's hopeless. The guitar keeps tipping over sideways. I can see how this design would work with the curve of the bottom of the guitar in keeping it upright. Also can scale it down for a ukelele, too! Elegant
great idea! if you make a ukelele version, please share a pic with us here! :-)
this is perfect. thanks for sharing this. I'm going to give this a try.
Really nice "Why didn't I think of this?" design!
You also might like to check out the Nomadic Furniture books by Papanek & Hennessey. I still use its slot-together desk, many decades after making it in my college's woodworking work (see below for original drawing).
What an excellent idea for a unique gift. Would you please furnish the dimensions?? I intend to make a template so I can make several units as gifts. Once I can make one template, all I have to do is trace it and cut the un its on my band saw. Thanks.
I int
A clever idea. Only one question: is the front coated with something to prevent scratching the instrument ???
Adhesive weatherstripping would do the trick.
You could just stick some little felt pads on there, like for the bottom of furniture legs. Eight pads total would be good--four at the farthest points of contact and then two each at the interior right angles.
So simple! I love it! I will be making at least a couple of these, thanks for this. :)
