3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple coke can engine
This is a simple coke can Stirling engine you can make in under an hour. No epoxy or RTV needed, just super-glue. It's all supported by steel wire, with spade connectors for all of the bearings.
Important note: It has been found that aluminium drinks cans need additional cooling around the top because the aluminium is so thermally conductive. Use steel cans if you can, such as Pepsi, Tango etc.
Thanks to David Williamson for the diaphragm design/ construction method. Check out his website here!
Materials1 Coke can
  • Steel wire wool
  • 1.6mm steel wire
  • Spring paper clip
  • Normal paper clip
  • 0.4-0.6mm fishing line
  • Super glue
  • Thin cardboard from a cereal box
  • A balloon
  • 6.35mm electrical connector/spade connectors .
Step 1Open the can with a can opener
Open the top of the can with a can opener.
159 comments
1-40 of 159next »
Mar 3, 2011. 7:57 AMpastorkirbyjohnson says:
Middle School Science Fair, here I come!!!!
Awesome!
I had never even heard of a Stirling Engine until this instructable.
My kids and I will have a blast (in a good kind of way) with this.
Mar 3, 2011. 6:55 PM8v92 says:
Trying to figure out why this engine runs is like figuring out why a bumble bee flys, it should not run but it certainly runs quite well. The counter weight in the center seems to resonate and the flywheel is low mass but high inertia. I am not an expert but there are principals at work here that need to be studied. This is a great example of thinking outside the box.
Mar 4, 2011. 5:26 AMburnerjack01 says:
The principle is quite simple. If I may.... There is a displacer inside the can.
This displacer moves up to allow the air within the can to make contact with the hot can bottom. This expands the air which drives the diaphragm up due to expansion. The displacer then drops to the bottom of the can which insulates the air from the heat thereby allowing the surfaces not exposed to the heat to cool the air which allows the air within the can to contract.
The REALLY cool thing about sterling engines is if you drive the shaft instead of the other way around, it becomes a heat pump! Not bad for 1880's tech!
Mar 4, 2011. 5:36 AMburnerjack01 says:
I think it's AWESOME that you are introducing your kids to this!
Not only is this device classified as an external combustion engine and is truly a flex fuel technology which can even run on solar or geothermal heat.
In fact, any heat difference between the "hot cap" and "cold cap" will make it run. This goes all the way back to 1880's Scotland and I have read that it was devised to take the place of the dangerous steam engines used in coal mining at the time. Not a bad job of design by a monk of all people.
Ther is a wealth of history associated with this device.
One last thing, it has been said that this device is one of the most thermally efficient engines ever devised. Good luck with the Science Fair!
Mar 5, 2011. 6:52 PMrwcrocker says:
Very cool! We built it today. It took a little more finesse bending wire than I had anticipated. If you don't balance it well enough, it wobbles like crazy on the wire legs even if you're holding the base.
We added a 15 mm strip of wet paper towel around the top of the can to act as a better heat sink - it helped a lot.
Thanks a lot for the great instructable!!
Mar 6, 2011. 6:28 PM8v92 says:
I did not see the fishing line going to the displacer in the movie so I thought it was resonating somehow. I still think it is a good design and would work with multiple cylinders. Perhaps an affordable and practical vehicle could be built using a stirling engine.
Mar 7, 2011. 6:37 AMchristpher says:
I gust watched tow helicopters go by woooooooooow
May 6, 2012. 10:51 AMrikardom says:
Awesome!
May 3, 2012. 7:04 PMtobune says:
Very good concept. Trying to make it reality now.
Oct 16, 2011. 12:59 PMtokin says:
Cool!
Apr 6, 2012. 6:25 PMmattle says:
Yes it is!
Mar 27, 2012. 8:00 PMstumitch says:
fantastic! i want to build one!
Jan 21, 2012. 5:55 PMteniva says:
Just love it and I certainly must try it
Nov 24, 2011. 3:27 AMbhaskar0kumawau says:
can i use a steel wire instead of fish line and tell me how it works??????
Nov 17, 2011. 3:25 PMbegunia says:
Amazing work my friend!
Nov 5, 2011. 10:02 AMkuruting says:
Amazing...
Oct 1, 2011. 10:50 AMlepar says:
Awesome work. Thanks for sharing it with the community.
Sep 21, 2011. 7:24 PMmerkuri2 says:
Interesting I must say.Trying to make it now.
Sep 1, 2011. 10:41 AMkokina2 says:
You are awesome and creative!
Aug 20, 2011. 4:39 PMtorina2 says:
Excellent work!
Jul 16, 2011. 9:35 PMChowmix12 says:
I really want to do this project. I have all the things but the wire. Would paperclips work as wire? By the way, would a few drops of water make Stirling engines more effective? I know steam is 100 times the volume of water.
Jul 20, 2011. 11:34 AMChowmix12 says:
the paperclips worked for the crankshaft, I made a flywheel of cardboard and glued it onto the crankshaft. For some reason I couldn't get the engine to work.. I gave up on it...
Jul 5, 2011. 7:13 AMsandra-1 says:
Mar 4, 2011. 4:57 PMMCzone says:
learn to measure
how does 15 cm get that far
you made me waste 30cm of wire.
Mar 4, 2011. 5:29 PMMCzone says:
oh im sorry i made the mistake
Mar 9, 2011. 4:46 AMMCzone says:
I started using it for the stand and the loop above the basket <:(
Apr 2, 2011. 4:32 PMwiinick says:
I almost id that too, but my base looks nothing like the picture, but does it work, yes.
Jun 12, 2011. 5:34 AMMCzone says:
I never did get that tin can working, but its cool
May 20, 2011. 12:58 AMnishi biswas says:
I have tried to assemble a Simple Coke Can Engine, but after several attempt, I failed, so please let me know how would you help me if i become a paid member.
May 18, 2011. 7:48 AMpauli2 says:
Amazing work have you done.
May 15, 2011. 11:13 AMantonio23 says:
I found this project very interesting! Trying to make it now.
Apr 24, 2011. 3:59 PMwiinick says:
well i assembled the thing sadly it doesnt work, its my fault so i am going to see if i messed up with the counterbalace, and there maybe a lot of friction.
Apr 19, 2011. 5:09 PMjoehudy says:
this is probable a dumb question bot what does the displacer do?
Apr 18, 2011. 8:25 PMwanzaidi says:
Hi every one,
I found this project very interesting. But one question keeps bugging me - why fishing line, not a wire as the conn rod for the displacer?
Wan
p.s. I will be making one soon.
Apr 18, 2011. 3:31 PMbryahn says:
Sorry if this is a stupid question, but instead of a candle, could you heat this with say a wire coiling around the bottom 2-3 inches of the can? similar to say a water heater element maybe.
1-40 of 159next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
313
Author:scraptopower(Scrap to power)
Always a brew in hand, I like to make stuff.
