Simple electronic dice
Ever wanted to make an electronic dice? I designed a simple and small circuit, that fits into every pocket.
You might wounder why this is better than a normal die. It significantly increases your geekiness level.
The biggest part is the battery, because we're using a 9V battery.
Step 1Parts
Parts
It's hard to understand, why some people build circuits with so many parts. You can build the same thing with less parts and it still works.
You will be surprised by the number of parts needed:
-1x ATTiny26
-7x LED (preferably diffused)
-7x 160 ohm resistor
-push button
-9V battery clip
This part is for the voltage regulator:
-1x 60 ohm resistor (power rating 0.3W or more)
-1x 5.1V zener diode (power rating 0.5W or more)
Sadly, I never take pictures of my parts. I always forget.
11 comments
Nov 14, 2009. 10:27 AMgodofal says:
u should make it more clearly what led is wich one...
in the diagram it only says led1-led2 etc, but its hard to figure out wich one is led1 in the 7led display...
Nov 14, 2009. 10:36 AMgodofal says:
btw, when i say hard to figure out, i mean the only way is to compare the solder tracks and the components to eachother to backtrack wich attinypin is connected with what led...
il show the pic as soon as im done, with the connections...
Nov 14, 2009. 10:55 AMgodofal says:
okay, compared 2 pics, and uploaded it, here it is :)
Nov 14, 2009. 10:58 AMgodofal says:
hmm,  a bit slow...
anyway here's the result, its in the pic, but a bit to small to see good...
heres a small txt version, the numbers are the pins the leds are connected to, and the place theyr standing are the place the leds are.
|20|     |14|
|19|17|13|
|18|     |12|
i hope its clear...
Nov 15, 2009. 2:04 AMgodofal says:
oh dmn, just figured out why the VCC and GND arent on pin 20 and 10, its attiny26, i thought all along it was attiny2313...
well, im gonna try and alter the code for attiny2313, il post it if i can figure it out...
Aug 21, 2009. 3:42 AMhamsamadiraju says:
excellent idea! its useful to the hobbyists n students....as a mini project...thanq...
Jul 23, 2009. 12:04 PMzoltzerino says:
Ive seen this done with a much smaller chip, I think it was a PicAxe 08M, Instead of a PTM switch there was a "shake to make" switch, making it more dice like.
Jul 19, 2009. 8:07 AMcoolrobot says:
it's kind of hard to understand how you soldered it together.you should do a drawind on paint or something to simplify it
Jul 19, 2009. 8:04 AMcoolrobot says:
very nice!
i'm going to do this as my first real project.
thanks for the instructable
P.-S. :do you know where to get the materials?radioshack?
-alex
Jul 4, 2009. 9:20 AMmacobt says:
Nice work.
Here is my double led dice
http://www.instructables.com/id/Led_Dice_PIC16F84/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:DemonDomen
