If you commute regularly on your bicycle, the lack of sun in the winter can be a bit intimidating, particularly if your journey is not well lit. I ride my bike to work all year around, and in November, much of my commute is in the dark. I have a good set of lights (front and rear) to see where I'm going, but in the dark, people often don't notice hand signals. And of the folks that notice, many don't understand. I guess the left turn signal is pretty straight forward, but nobody really seems to get the right. And forget about stop and slow down... but I digress.
My goal is to create a very simple set of turn signals that anyone can build with a few basic tools. Where possible, I've used commercial, off-the-shelf parts, all of which should be available at your local bike shop, electronics shop, or online if you don't have access to these things in your town.
Disclaimer:
The recommended way to indicate turning is by using hand signals, and these shouldn't replace that. These are rear turn signals only. You still need to indicate you intention to turn to the people ahead of you.
Remove these ads by
Signing UpStep 1Required Parts
Parts:
1- Two Rear flashing bike safety lights: $10.50 each
I used Blinky7 lights from Planet Bike. I got them from Mountain Equipment Co-op here in Canada. Probably REI in the US would have the same thing. Important: The lights must have a blinking mode, and the blinking must be sustained when the batteries are removed, and put back in. The lights I used have a capacitor that slowly discharges. This means that if I don't use my turn signals for 20 minutes, the light gets reset to a solid light and I have to press the switch on the light to set it back to blinking mode. Ideally, your light will have a switch that will remember the blinking setting indefinitely.
2- One AAA x2 battery holder : $1. Get one with a case to keep the batteries dry.
3- One Double Pole Double Throw (or DPDT On/Off/On for short) switch. $5.50
I picked up both of these items at Lee's Electronic - my goto shop for electronics in Vancouver. Probably Radio Shack would have something similar. My battery case has an on/off switch, but that's not really required, as the switch will be used to turn them off. If you can find a waterproof switch, that would be ideal.
4- Wire. Red and Black. 6 feet of each should do, or enough to go from your handlebars to the just at the top of the seat stays and back. 26 gage or so should be fine, but anything reasonable will work.
5- one extra long screw that will fit the nut of the Blinky mounting setup.
Tools:
6- a little silicon , similar to the stuff that you would use to seal around your bathtub. Caulking, Shoe Goo, or Goop will also work.
7- A little strip of adhesive Velcro (both sides)
8- Solder and a solder iron. Or you could use silver conductive epoxy if you don't have access to a soldering iron.
9- Xacto knife
A set of helping hands (the mechanical device, not another person), and a set of wire cutters were also used, but you could get by without them.
look up Part s for scooter
than hit lites and you will find all the lites you want
1) Put the turn signals on a timer so they would shut off automatically after an extended period of time. Not ideal really.
2) Some sort of beeping, or flashing LEDs near the switch to let you know they're still on. I think I like this a bit better.
Does anyone else have any ideas? I guess if it was that easy, motorbikes would have signals that shut off too.
I pretty much did what you did, only twice the lights and batteries, and clip on safety flashers that I could only find with transparent cover, so I replaced the white leds with amber. Probably could've used orange cellephane behind the lens instead though.
Wish I could show pics, but I' m restricted to library computers :(
Like the arrow idea.
Why didn't you use the bike itself to pass the ground signal ? Is it possible ?
At any rate, there's no reason why you have to depend on the commercial blinking component. They probably have a 555 timer inside you can just disconnect and use.
I think the solid, dim left light and the blinking bright right light would indicate a turn much better than just one blinking light that might be on either side of the bike.
1) have the lights on solid (even dim) when they are not flashing
2) use orange lights. Here in Canada both red and orange are used to indicate turns, but I think orange on a bike would be a little more clear.
3) Have the flashing light in some arrow shape.
My plan for this is to design something in Sketchup that will mount to a bike frame, allow any off the shelf light to clip into it, and have some arrow shaped cut out in the back so the light appears arrow shaped. Then I'll print it on the Makerbot and upload the file to thingiverse.com so people can print their own.
I'll call it 'Difficult (but effective) turn signals for the bike ;)
I'll definitely check out the 555s
Also, some lights will automatically go into flashing mode when batteries are inserted, or if the switch is held down and batteries inserted. If it's the kind that needs the switch held down, just take apart the light and solder over the switch contacts so the light will go into flashing mode automatically whenever the power is applied.
Using amber lights with a central red light would also distinguish them as turn signals.
The only real problem I can see is that drivers aren't used to seeing turn indicators on pushbikes and might just assume that you are being extra careful in being seen. To be honest, I wouldn't rely just on these when changing lanes or turning. drivers are blind enough to cycles as it is, but they should help to reinforce the turn hand signal.
As an aside, I found the upward bent left arm signal interesting, but don't try it in the UK, they'll just assume you're waving at them or pretending to be Hitler on a bike.
Yes, amber lights would be better. I've added that under the future enhancements section. I'm curious how people indicate a right turn in the UK? Is it the 'right hand out' method?
I also remember signalling using the right hand out, and moved up and down to show you were slowing down or pulling into the kerb when stopping on a motorbike.
I could also mention a few non-Highway Code signals I used when I was cut up by cars, but I think they are mostly international and well known and occasionally still come in useful.
Wire the diodes like this: Left turn: Power flows through third base diode, then in paralell through the two base path diodes to the second base diode to ground (and the home plate diode to ground). Right turn: Power flows through first base diode then in paralell through the other two base path diodes to the second base and home plate diodes.
You can expand the arrow to 12 LEDs by putting two (or more) diodes in series on each base path. Use dimmer diodes for first and third base since the other diodes will only get one half current.
Total voltage drop red LEDs: 3 diodes= 5.55v, 4 diodes= 7.40v, 5 diodes= 9.25v
