3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Skeleton Key
Skeleton Key
Clever saying when given as a gift not included.
Needed:
1 Coat Hanger
1 Paper Clip
1 Crystal
Solder
Flux
Heat Source
Keep in mind solder is a bonding material and not so much a filling material. So it can tricky to work with. Also, solder is softer the steel so it will file off faster.
Step 1Strip a coat hanger
Strip a coat hanger
Use sand paper to remove any coating on a section of coat hanger. To help speed up the process I spun a piece in my drill press.
CAUTION! If you do it this make sure to hold the wire before you turn the drill on. Otherwise the section of wire will turn into a whip / weed wacker. Be careful and work within your experience.
22 comments
Sep 8, 2011. 8:43 PMSpitfire690 says:
My solder doesn't want to stick. I'm using the same solder as you, and flux, but it just beads, no matter what temperature...
Feb 19, 2012. 4:19 AMbben46 says:
Most common beginner mistake is heating the solder and not the metal. For best results, heat the metal until the metal is hot enough to melt the solder. then apply the flux first immediately followed by the solder.
There are several kinds of solder and several kinds of flux. For jewelry the best solder is called silver solder. It melts at a higher temperature and is harder than electronic or plumbing solder when it solidifies. You will need to find the proper flux type for silver solder.
The purpose of flux is to clean the metal of any surface impurities and allow the heat to spread evenly - and it should sizzle and evaporate when you apply it to hot metal. Don't inhale the fumes.
Modern electronic solder is lead free and does not stick nearly as well as the older lead/tin electronic solder. - Silver solder is still the best for this type project
Feb 18, 2012. 3:21 PMEmsaid says:
I made one similar to this! except it was out of a solid piece of metal then I bent it and turned it into a bracelet, I meant to take a picture to show you but I dont have it anymore but it looks really cool
Mar 10, 2011. 10:36 AMscoochmaroo says:
I love this too! Do you have a shop where you sell your jewelry? This needs to be in my collection.
Feb 17, 2012. 7:45 PMPenolopy Bulnick says:
I second that! I love skeleton keys! And that one is beautiful!
Jan 14, 2012. 9:43 PMblack hole says:
You know, I saw pendants that looked like this going for $30.
Jan 4, 2012. 12:05 PMrapidkhan says:
i made this and turned it into a bookmark
http://ofkeysandclockfaces.blogspot.com/
Nov 5, 2011. 4:12 PMcninjette says:
could you possibly attach the rings with a jewel in the middle of them?
Apr 22, 2011. 8:26 AMvictorvector says:
Again, very nice indeed!
One question , if you don`t mind , about the solder ...
Is this just soft solder , or silver solder ?
What do you use as your heat source ?
Most impressive work , lovely to look at.
Mar 17, 2011. 9:25 PMIchmawida says:
how thick is a coathanger? like the gauge or mm?
Mar 31, 2011. 2:34 PMIchmawida says:
cool thanks :)
Mar 21, 2011. 5:22 PMehudwill says:
I am going to make this for my daughters. They would love it.
Mar 20, 2011. 2:18 PMtaueret says:
I love this! Also I think it would look even better a bit rusty. I would never have thought of using coat hanger wire. Can't wait to experiment.
Mar 11, 2011. 4:00 PMTehLonelyOne says:
Amazing! I love how you make amazing little things out of incredibly common things :) So many perfect gift ideas!
Mar 11, 2011. 9:40 AMMr.Sanchez says:
Weekend ^Project...Soon the Pics....thnks.
Mar 11, 2011. 4:16 AMiPodGuy says:
Please don't ever stop making instructables.
Mar 11, 2011. 2:00 AMB.F.L.M says:
Amazing! this is going on my todo list
Mar 10, 2011. 1:11 PMRedneckEngineer says:
Very cool! my wife is getting into jewlery makeing and has even talked about useing keys like this. Thanks you just saved me some money!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
965
Author:Mrballeng(Visit my shop)
I've opened up shop =). Click "Vist my shop" to check it out. Or write me at info@mrballeng.com
