I've been reading a bunch of blogs this fine Earth Day morning and have noticed that most of them are posting little write ups about green solar powered USB gadget chargers.  They're all quite nice, but also quite expensive.  I don't think I've seen any for less than $60, and I've not seen one that really suits my style.
Instructables has quite a few guides on how to make Solar USB Chargers, including the very well done guide on how to combine a Lady Ada Minty Boost circuit with a solar + lithium ion battery.  Great, but a bit expensive to make and not a very simple project for the weekend DIY person.
Well luckily for us I know how to make one for under $20 that is better in nearly every way and also completely fits into an Altoids Tin.  Covert style.
(If you want a more powerful USB Charger, a Heavy Duty one, I have an instructable for that as well.)
Step 1: What You Need
Parts:
USB Charging Circuit
Solar Panel 4V or greater
AA Battery Holder
AA Rechargeable Batteries
1N914 Diode
Altoid Tin (or whatever)
Wire
Tools:
Soldering Iron
Solder
Tin Snips
Melt Glue Gun and Glue
Tape
Cost is less than $30.  I can make one for under $10 when I buy parts in bulk.  I have a kit available at my website BrownDogGadgets.com which has everything you need to make this project.  Also, if you're lazy, I do sell made versions in a variety of tin styles.
1-40 of 248Next »
Schmidty16 says: May 28, 2013. 9:29 PM
I was wondering if I could use another usb connector if so can I fond 1 at RadioShack if so what is it called and if I can where can I find one in stuff ling around my house
Schmidty16 in reply to Schmidty16May 28, 2013. 9:31 PM
I don't have access to your store
Schmidty16 says: May 28, 2013. 9:17 PM
can I find another dc to usb converter that is cheap on RadioShack that will work on my iPod or is there a cheaper 1 that I can find in an old device if there is 1 at RadioShack what would it be called?
Schmidty16 says: May 28, 2013. 9:13 PM
cool thx I have a few questions
Houghie72 says: May 17, 2013. 3:41 PM
I have got the USB charging circuit from a USB car charger that turns 12v into 5v. Does this mean in order to charge, I have to have 12v going into the USB charging circuit?
scientist44 says: May 15, 2013. 7:40 PM
On the brown dog gadgets website I found a 6V solar cell, and a 1.5V cell which would be best? I don't completely understand the voltage situation.
ccc2 says: May 11, 2013. 10:38 AM
I made this, and I am able to charge my simple keypad phone, but I can't seem to charge my ipod touch. I keep getting the message, "charging not supported with this accessory." I am guessing that this is because my ipod needs more power to be charged, but 'm not sure. Any ideas on how I could fix this?
ttawi says: May 1, 2013. 8:53 AM
Hi~ u said "just connect all the red wires with all the black wires", but u r actually connect the red wires to the red wires. i dont know what to do. i think i should connect the postive wire from the solar panel to the postive wire from battery, right?
yoji says: Apr 7, 2013. 12:46 PM
hello, i have a question. how can we know if the battery is fully charged? and is it possible that battery may explode due to overcharging? how to prevent it?
thanks.
lg90221 says: Apr 3, 2013. 4:23 PM
i have a question im new to this but i was wondering can you use the usb circuit found in car chargers? because those are 1.99 compared to the 8.99 dc to usb circuits. i know it takes 12v and drops it to 5v volts but if it receives 6v wont it just drop it to 5v? not really into the whole elctronic thing. or where can i buy cheap dc usb
rev512 says: Mar 29, 2013. 2:28 PM
Hey so it started charging for a few seconds and then my phone said something about my phone is not comparable with this accessory and now it won't charge!?!?
tripperman79 says: Mar 27, 2013. 7:07 PM
Sorry if this has already been asked, but will this one work with an iPhone 4s?
bulletbkr says: Mar 21, 2013. 4:16 PM
just a note, if you use hot glue to secure and insulate the connections and wires on the back of you solar cells, be sure to put something under them when you put them in the sun to charge. I now have a ruined dashmat in my truck because the hotglue melted into the fibers as I was charging my batteries. Boo for hot glue. I thought it had a much higher melting point than that.
BillMetrey says: Mar 4, 2013. 4:19 PM
Hello, I tried to access y our website several times with no success. Are you still accepting requests? I would like to buy at least one of your solar chargers. Thank you!
Bill Metrey
kldtia says: Feb 25, 2013. 12:12 PM
I attempted this project. I have one question I'm charging a samsung Gs2 phone and I pluged it in. It says it's charging but when I look at the phone it seems like my battery is losing charge. What did I do wrong.
Thanks
budhaztm says: Feb 14, 2013. 8:57 AM
Would one be able to use lets say a (or a couple) li-po battery for rc airplanes and have a dc-dc converter?
tboultwood1 says: Jan 12, 2013. 2:50 PM
Hello there, me and a friend have a project idea. We are planning to use a 12v battery of arrays of AA rechargeable batteries, also using a 12v panel. Will we need protection against overcharge?
Gigean says: Jan 9, 2013. 2:56 PM
How do I know if I should use a 4V Solar Panel or something else? Also, where would I find a solar panel, a battery holder, and the diode? This may be the first Instructable project I tackle, so sorry for so many questions
jpman says: Jan 2, 2013. 9:51 AM
f i use one of those Ipod charger usb thingos would it work??? i really dont have money to buy the minty boost usb circuit i have one of this usb charger things for ipods and phones so yea Email me @ jpaolo.ortega@gmail.com
kenkenken44 says: Dec 6, 2012. 5:30 PM
hi this project is cool so i made 1 with a car charger and it seems to not work any help?
b.t.w im using a 6v solar panel
valiantX says: Dec 5, 2012. 6:04 PM
In regards to batteries, I think people should try buying some of these new japanese 'water charging', that's right, batteries instead. Excuse my language here, but these batteries can be charged by any form of non-acidic water including urine, sewage water, creek water, your sweat, etc.
Check out the site info right here: http://waterbattery.com/
A cheaper site to buy from: http://shop.conics.net/nopopo-3pk.html
Fashiondez says: Dec 2, 2012. 2:51 PM
Hey, does anyone know what to do when you hook everything up, and it is working/shows that the Iphone is plugged in, but it doesn't charge it? Should I cut all the wires and re attach them?
pertamax11 says: Nov 22, 2012. 11:27 PM
how much current can be drawn from this dc-usb converter?
agqy2801 says: Nov 4, 2012. 8:43 PM
Can rechargeable batteries above 2000mAh - 3000 mAh be used? I managed to find one claiming to be 3500mAh. Plus, the battery claims to be AA Lithium Ion and not NiMh, will that affect anything?
electro18 says: Oct 28, 2012. 10:37 PM
I bought a 5v solar panel and connected a diode to it....... and connected it to my phone. It was charging well so is there any need of the DC-USB converter?
Fashiondez says: Oct 13, 2012. 12:47 PM
Okay, I finally began putting together the usb solar charger. I got all the supplies from your web, except for the usb circuit board.... I got that out of a cheap usb car charger. Anyways, when I got the solar cells, i wasn't sure what the soldering tabs were and found out the hard way that, without them, it is not really that possible to connect the wires to the glass of the solar cell lol. Anyways, I needed to attach a diode to the positive wire, so i had detached it from the solder tab, and ended up detaching the soldering tab itself (not knowing it was useful...as it wasn't in the picture in the instructions and this was my first time). I am wondering if there is any way to recover my supplies now that two of the tabs are gone.
I hooked up two cells in a series and connected it to two AAs and then those to the circuit board, even tho I am not 100% sure that i am hooking them to the correct place, because it does not have a + or -, so I am just trying to use common sense and I picked a place :). Currently the charger is not working, so i am trying to evaluate. Hope this was understandable.
JoshuaZimmerman (author) in reply to FashiondezOct 20, 2012. 11:28 AM
Car charger won't work. A car charger takes 12V from your car battery and lowers it to 5.
The circuit I uses takes 2-3V (such as 2 AAs) and boosts it up to 5.
Two completely different circuits.
I emailed you about all this as well, so check your inbox.
electro18 in reply to JoshuaZimmermanOct 27, 2012. 6:55 PM
Can you email me the circuit diagram of the DC usb charger? Having a bit trouble with it :) .
Fashiondez in reply to JoshuaZimmermanOct 20, 2012. 9:55 PM
yes, thank you. I am pretty sure I got all of yours! I had written you via this and e-mail at first. I don't know if i received a reply to my last one though.
paintphone says: Oct 14, 2012. 3:04 PM
What was your USB charging circuit originally from?
JoshuaZimmerman (author) in reply to paintphoneOct 20, 2012. 11:28 AM
Surplus from a commercial charger.
4lifenerdfighter says: Oct 3, 2012. 10:42 AM
I would also like a schematic. It looks simple enough to cobble together.
JoshuaZimmerman (author) in reply to 4lifenerdfighterOct 8, 2012. 9:23 AM
Quite simple.
4lifenerdfighter in reply to JoshuaZimmermanOct 9, 2012. 11:47 AM
So give it to us!
johnestan says: Oct 8, 2012. 8:50 AM
Could you please tell me what the advantage of having a separate battery charging circuit is. Many of the other instructables use lithium batteries and require a LiPo charger circuit. Is this not needed when using NiMh batteries, or are you just saving money. Is it worse for the batteries in the long run?
JoshuaZimmerman (author) in reply to johnestanOct 8, 2012. 9:23 AM
Lithium batteries need a charge controller because if their very specific power requirements. NiMh batteries do not.
It's a connivence and price thing when you choose batteries. Lithium are better, but are more expensive and are more work to wire up. NiMh are cheap and easy to use, but are not as effective.
skeys2 says: Sep 8, 2012. 3:45 PM
I salvaged a USB thingie from a DC-USB and am using that. It looks just like the one you have pictured; however, I can't seem to fing the negative or positive connections. It would be amazing if I got a response... Thanks!!!
JoshuaZimmerman (author) in reply to skeys2Oct 1, 2012. 2:14 PM
They should be labeled. Or marked on the board.
Or you could just take a 2AA battery pack and just touch the wires to the board. If it works, you have things right. If not, switch the positive and negative spots and try again. (Guess and check)
Diggyx17 says: Sep 23, 2012. 7:47 PM
Will the solar panel charge the batteries when its not in use???
JoshuaZimmerman (author) in reply to Diggyx17Oct 1, 2012. 2:13 PM
Thats the idea.
1-40 of 248Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
