Introduction: Solar Cooker
Picture of Solar Cooker
Make an easy solar cooker. It doesn't work that well as I was only able to cook cheese and not an egg, but it is relatively fun and easy to make. You are probably better off buying a solar cooker.
Materials: Pizza box, black construction paper, duct tape, plastic wrap, aluminum foil, razor, and any acessories that float your boat
Procedure
1. Take the pizza box and cut out a square section like I have.
2. Peel back the flap that you have made and put tin foil on it to reflect light into the box.
3. Put black construction paper on the inside to absorb light.
4. Put whatever food you want to cook into the box(make sure that it is something light) as it can only cook lighter food items.
5. Put plastic wrap over the top of the oven and duct tape it in place.
6. Duct tape the rest of the openings in the box as much as possible to create an air tight seal and trap in the heat.
About This Instructable
1,184views
3favorites
License:
Bio: I am the type of person that tries to make the most out of life. I take what opportunites I can and make the most ... More »
More by ajensen19:The Milky RainwayHomemade ElectromagnetSteam Powered Vacuum
Add instructable to:
