Solar Food Dehydrator (Dryer)
Dry your fruit, vegetables, and other goods with your own sun powered dehydrator. Electric Food Dehydrators can be expensive and consume unnecessary energy.
This solar dehydrator was made entirely of recovered materials. It was constructed with scrap ply wood, 2x4s from an old ladder, a house window, and other items which could be considered trash. It was created as a project at Maharishi University of Management in Fairfield, Iowa.
Why We Dry: Removal of moisture prevents bacteria from ruining your values fruits and vegetables. Drying is a form of preservation.
Step 1Learn the Design
Learn the Design
Become familiar with the design to minimize mistakes...
There are vents underneath in the front which are hidden in this picture. The darker section is a piece of heat absorbent material, we used painted metal for this particular dehydrator, but other materials will do as long as they are dark. The food itself is placed on the shelf, which will be made out of a cloth screen. Other screen-like materials can be used, but take chemical leeching into consideration to prevent contamination. The back piece of ply wood can be opened to remove the shelf and provide additional ventilation.
21 comments
Sep 13, 2011. 4:47 PMsthomas8 says:
Well this is simply lovely and i would love to try it with the local apples that are just coming into season here in new england but its too dern cold. But I had an idea of using the suction from an overhead stove fan to move heat from a gas burner through a dehydrating chamber and out of the house through the fans exhaust duct. Any feed back that might help me on my journey or prevent me from burning down my house?
Sep 24, 2011. 5:03 PMbeatyruth says:
You'll have to be careful not to cook the apples instead of drying them- a light bulb gives of plenty enough heat to dry them. Should work, though, as long as you can keep the heat down
Aug 4, 2011. 12:21 PMgodbacon says:
Good project!
I like the simplicity of the build/design.
some thermal mass would help even out the temperature. and it would be nice to have some kind of a swivel to follow the sun or another pane of glass to take in wider sun angle.. early morning to late day.
a more automatic temperature control is needed. something based on the expansion of metal to open a vent or flap, maybe. Some kind of leveling/stability is needed for those of us that don't live on flat land, don't want it tipping over.
Overall a really good job on the project and the instructable.
Apr 15, 2011. 2:33 PMTAnderson7 says:
Great plan! I am going to start building one this weekend, I think I can find all the parts by then. This should work great in the summer time and allow me to find a greener way to dry my food.
food dehydrator reviews
Oct 8, 2009. 10:13 AMgcai_fwb says:
Great Idea and instructable!
However for use in more northern climes the sun is not enough during the cooler months and we have to resort to electrical methods.
Rather than using a stand alone dehydrator I've found a single 100W incandescent light bulb placed at the bottom of the oven of my stove works very well, creating sustained 150-160 degree heat.  I've added a light dimmer to vary the bulb intensity ie. a heat control - a little expermentation and I have a cheap and effective dehydrator with relatively low running costs. For more heat add light bulbs or a combination of different wattages.
Note: CFL bulbs will NOT create the desired heat.
Oct 6, 2010. 5:53 AMafridave says:
just a tip ...try instaling a hairdryer motor on a timer ...we use it for making biltong (jerky) and it really works great.
Oct 30, 2010. 6:30 AMmadwilliamflint says:
Now THAT I like. I might be able to wing that in my little brooklyn apartment.
Isn't it a bit loud?
Nov 1, 2010. 12:02 AMafridave says:
YIP its a bit loud but mine is outside in a shed.Just run it when your not around to hear it.All its doing is speeding up the drying by evacuating the warm air with the moisture in it. It works well with just with A 100W globe but takes longer.Do not try to run a hairdryer on the hot setting as you want to dry not cook and i assume you do not wanna burn the building down.I run it 15min in the hour so as not to burn out the motor.
Jan 21, 2010. 5:12 PMPeter Mckee says:
If the climate is too cold for a solar dehydrator you can make this wood fired one that will also be adaptable to  your amount of dehydrating crops. Also most of the materials can be picked up for relatively inexpensive.
www.backwoodshome.com/articles/hooker41.html
Feb 28, 2010. 3:28 AMANDY! says:
I read a book on this! I made something similar with a pizza box.
Nov 2, 2009. 1:17 PMmaria jorquera says:
quiero ke me dejen bajarlo para poder hacerloooo¡
Jan 1, 2010. 9:10 PMmannyisdead says:
Para bajarlo tienes que registrarte ser Pro Member
Nov 22, 2009. 12:14 PMjoanofarc says:
 What is the purpose of the "feet" on the front legs?
Nov 18, 2009. 7:34 PMunlvdating says:
Thanks a lot for the post. I really want to learn how to grow plants using hydroponics but I don’t have much knowledge about this method. I appreciate your effort in writing articles or posts about hydroponics which helps me a lot in understanding matters about this amazing method of planting.
Climate Control
Nov 11, 2009. 8:52 AMsyed najam javed says:
its really great to see some best thing created out of junk
Oct 22, 2009. 8:34 AMDrChill says:
For cooler climates, consider - double glazing. This can be glass or clear plastic film wrapped around the window.
Also consider thin insulation; either rigid foam or aluminized bubble pack.
This may solve the - not hot enough problem, but it may tend to over-heat sometimes.
Yours is a nice design/ idea, but my only concern is that there is no temp/humidity control mechanism.
There are green-house roof window controls that open & close depending on the temp. Maybe something like this could be added to the design.
Oct 14, 2009. 3:59 AMnfarrow says:
What software did you use to make this?
Oct 5, 2009. 9:35 PMjessimata says:
VERY NICE!
Oct 5, 2009. 7:35 PMAwesome-aniac says:
I live about four hours away from there. It's been so cold and rainy lately, that this wouldn't be of much use. I do agree that electric dehydrators consume lots of energy. They are kind of like ovens that run all day long.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Permaculture
