The panel is mounted to a frame, which is attached to two bike wheels. The wheels are mounted to a larger wooden frame, and the wheels and panel are moved by a 12 volt linear actuator. The sensor is an LED model and is purchased from Redrok Energy.
The LED sensor senses the path of the sun and tells the actuator how much to move to keep the panel properly oriented. At the front of the tracker are two legs that can be adjusted to the proper altitude for seasonal changes.
I used bicycle wheels because they are durable, strong enough to handle some weight, and best of all, in my case, free!
Remove these ads by
Signing UpStep 1What do you need?
*Several treated 2x4's (Lowes)
*Two wheels from a free bicycle- free or almost free bikes are pretty easy to find from the local landfill or thrift store
*A piece angle iron with pre-punched holes (Lowes)
*A 12 volt linear actuator-(~$75?)- (Ebay)
*An LED tracking sensor- (~$40)( http://www.redrok.com/led3xassm.htm#led3xforsale )
*Various nuts, bolts, screws, cable and wire -(scrounging around my workshop)
Duane
Red Rock Energy
No pun intended? Really? Because it sure looks to me like you absolutely intended to make that pun.
Thanks folks.
Obviously if you can find a free or cheap one from someone who is junking an old satellite dish that would be great.
But if left to buy one, other than the stroke and finding one of the appropriate voltage, how much force should one be able to exert on say, 2 45W panels and still be able to operate in blowing winds? It seems like you would want to minimize this in order to draw the lowest amount of current from your battery bank so that you gain the maximum power from your tracker and invest as little power as possible into driving the thing. Thoughts?
I have a question about the movement.
How many degrees do the panels move each day?
I'll have to give this some thought ... I'm working on a design for an "external Trombe wall" which I can attach to an existing window for the venting. Of course, making it insulated, situated off an existing wall, and now pivoting, I'm getting away from the simplicity of Trombe's design.
When it gets dark or with heavy storm clouds it heads toward the Eastern limit switch. If the sun comes back out it resumes tracking.
Duane
Red Rock Energy
1. I would suggest that the wheels be mounted on an A-frame so that struts could be placed from the outside edges of the panels to points tangent to the wheel to provide bracing against strong winds.
2. I find that sun position sensors aren't really necessary for pointing since we already know where the sun will be at any given time of the day. Also, some sun trackers may have difficulties tracking the sun's position on overcast days and may operate erratically on partially sunny days when clouds intermittently block and reveal the sun. A system built around small uProcessor with an on-board clock can be programmed to provide positioning information to your drives, and if you want to get fancy, the sky's the limit for adding sensors, providing web connections, what have you.
If you measure the power from the panel this other direction will be greater.
Furthermore, the sensor is influenced by other sources of light such as reflective sand and snow adding even more power.
Duane
Red Rock Energy
Brian
Go to: http://rredc.nrel.gov/solar/pubs/redbook/
I suggest going down to the middle of the page where they have individual state data. Note that for EVERY location they provide annual data for ALL the relevant mounting and tracking schemes. Your tax dollars actually at work!
Hope this satisfies your curiosity on this topic!
bwitmer: great instructable!!
http://pvcdrom.pveducation.org/SUNLIGHT/DECLIN.HTM
You then need to add the result, which can be positive or negative, to your COlatitude to get the current angle that the normal to the rotational axis should be at.
http://en.wikipedia.org/wiki/Declination
