Solar Panel Setup Around $100
142,061
1,376
65
Published
Introduction: Solar Panel Setup Around $100
About: I like finding new uses for things, making things, and improving things. I'm a student who is currently looking for a better job, one where I can make an actual difference.
My objective was to be able to charge and use, cell phones, tablets, laptops, and other devices that use less than 100 watts. Also I wanted to have the power ready and available day or night.
The parts I used are:
$39 Solar Cells Untabbed 0.5 volt 2.8 amp 1.4 watt
$11 CMP12 10 amp Charge Controller
$22 Chrome Battery SLA 10.5 Amp
$5   Old Picture Frame to encase the solar Cells
$8   Wood to build the frame to hold the panel
$4   Wood to build the Charge Station
$4   12 Volt Socket
$1    9 volt Battery To power the LCD voltmeter
$5   LCD Voltmeter
Things I had around the house:
Exterior Grade Wire 2 Conductor
Wire and Panel Mount Connectors
Fuses and Fuse Holders
Outlet Coverplate
150 watt 12 volt car Inverter
15 amp Blocking Diode
Step 1: Panel Construction
Tab the Cells and check the output of each cell before you solder them to each other, If you need help or need more information on how to do this use Google search and Youtube Videos. I used the backing for the picture frame as a layout and soldered them accordingly. Then I reassembled the picture frame with the wires coming out of a hole at the back. As soon as put it together I checked the voltage and amperage output and made sure that everything was connected correctly. 2 of the 40 cells I was sent had a much lower output so I did not use them in the final panel. I added the blocking 15 amp diode to the outside because it would not fit inside the frame along with a terminal block on the back. After everything was checked I sealed the panel with caulking and painted it.
Step 2: Stand Construction
The stand is nice and simple and the panel is also easy to remove if needed. I used metal clips that grab the frame tightly and used some pavers to keep it off the ground. I also used some bricks to weigh it down. The wire goes down about 6 inches into the ground and comes up by the house. Remember you lose dc current when traveling long distances, so keep the wire as short as possible. I'am losing about 50ma with the wire I used. My panel makes a little over 3 amps @ 19 volts, So less than %1.7 is lost.
Step 3: Running the Wire to Inside the House
I wanted to run the solar panel power connection into the house for convenience so I could diagnose or  try different setups from inside the house. Also the temperature extremes hot and cold outside would have shortened the life of the battery at the very least if not of the controller as well. I checked for studs and conduit in the wall the best I could and drilled a small pilot hole. once i was sure there was nothing in the way I drilled completely through. I used a dc panel mount connector and a blank outlet cover to finish it up
Step 4: The Controller Setup
I wanted something portable that could be used anywhere once charged up. So i built a little stand that also holds the battery,controller,12 volt socket, fuses and voltmeter. The controller prevents overcharging or draining and keeps the battery topped off as long as its plugged into the panel connection on the wall. I used a 8 amp fuse on the load side of the 10 amp controller so I don't have to worry about pulling too much through it. I also put a 8 amp fuse on the battery just in case. The 9 volt battery powers the LCD voltmeter and it measures the voltage on the battery. Its a really simple setup and so far its been great. I have used it with a 150 watt car inverter running a laptop with no battery in it for over 6 hours with no problems. I have also charged up multiple tablets at once using the same inverter. I have yet to see less than 11 volts on the meter, it seems like its always ready to go. I will be using this for all of my charging needs.
Spring's Coming Contest
Grand Prize in the
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    65 Discussions
    You will make it easy with INPLIX instructinos . just google it
    Very nice. I am wondering what brand is the meter?
    I use 'Astro Flight' to monitor 6-20 watt panels that charge a 'Trojan' battery.
    One for power coming in from the panels and the other for power being used.
    The readout lettering is smaller than yours and harder to read.
    The panel meter is 3-1/2" Velleman PMLCD/L , I don't really recommend this meter because it needs a separate power supply from what its measuring. That's why I used the 9 volt to power it. Also you have to solder some resistors to the back depending on how you plan on using it. There are better panel voltmeters out there that can be powered by what they are measuring and are ready to use.
    please help... ihave 20w 1 ampe panel...can i connnect panel output to battery and input to inverter together...then the power from panel will go to where ..to battery or to inverter or on both...in your picture i think u split the postive of the battery ..and one to panel and one to inverter..
    This is the Astro Flight Meter aka; WattsUp. Cost $50 in Hawai'i.
    It measures off the solar panel the voltage when the sun makes minimum 4.5v. +/-, watt hours and amps being produced.
    The other WattsUp/Astro Flight measures power being used out of the Trojan battery. The meters can be always on if they have a separate power source (Small Battery). I cut the wires as I only need the meters when the sun is up or power is being used. I take power for the meters right out of the circuits as it is used or produced.
    Problem is the numbers are too small for tired old eyes.
    Power Distribution Panel Battery Monitor.pngDSCN0017.JPGDSCN0011.JPGDSCN0004.JPG
    The meter has no back light to illuminate the screen. If it had that the meter would be better for me. Anyone know how to backlight this thing?
    This is the Astro Flight. It can be powered by an external battery but I don't.
    I cut the battery wires off. It is powered by the source (solar Panels) and the other one is powered by the Trojan Battery.
    As the sun comes up this meter measures volts, amps, watts produced and amps produced.
    When I plug in a device and turn it on the meter measures how much of everything the device uses.
    The drawback is the numbers are too small for tired old eyes.
    Here's a good substitution for that panel meter. This seller on eBay has dozens of styles for both volts and amps, many colors, bezels and mounts. I have bought several and use them often.
    http://bit.ly/1ngus7c
    It is great to know
    that there are more and more solar panels users around the world. Pakistan is a
    sun blessed city and quite logical if there will be more solar cities here. I
    have read an excellent article on this topic http://solarpanelscompany.com/blog/solar-cities/ It makes me feel that very soon we will be able
    to improve lives of many people in our country and throughout the world.
    hi. I have the same charge controller, are you able to use the load while still charging at same time. thanks.
    Yes you can charge and use the power at the same time, as long as you have enough power being provided by the solar panel.
    I have a 90 watt amp (boombox) connected to the load (lvd) on the charge controller not the battery. if I try to play music and use the solar panel to charge at the same time, the amp will turn on but no music plays. I have to turn off the panel charge for the amp to play music. The voltage on the battery read close to 13v. do I have to connect the amp to the battery instead. thanks for your help
    I'm not sure what's going on with your charge controller, but I have been able to charge the battery while using a load on mine. Make sure your panel provides enough power to run the load with enough left over to charge the battery.
