Remove these ads by
Signing UpStep 1Disclaimer and what you need
first of all the disclaimer:
***Disclaimer*** The following is for informational purposes only, I take no responsibility for what you do with this knowledge.
it is just a prototype in the pictures, i did not care the welding and soldering so its a bit a mess. :)
what you need:
- 1x DC-Motor 10 or 12V (10 is better)
- 3x 6A diodes (in my case i needed 6A diodes, you will select yours according to the power of your motor)
- you can use a diode-bridge instead of the 3 Diodes.
- some meter of wire
- 1x old Hi-Fi.
- 1x switch(optional)
- 1x plane model propeller
I would hazard a guess that the reason the motor works better with the extra diode is because of back emf (a.k.a counter emf, cemf and counter electromotive force). also if you used a stepper motor and the right circuitry then it would change speed depending on the frequency. that would be better in a way because on car/bike games the faster you go the higher frequency the revs get to (until you change gear).
-Cosmostrator
