Spooky Led Lamp
Spooky Led Lamp
This is a hollowed out light bulb filled with fluorescent liquid and two UV leds plus one red led immersed in the liquid. When turned on the light bulb flickers for a while then starts to pulsate randomly with the UV leds giving a spooky but rather nice look.
The bulb is held to the box by two small magnets that also is used as contacts for the power to it.
I got the inspiration for the project when I stumbled upon a web site describing a similar project.
imakeprojects.com/Projects/glow-crystal/
In the last step of this instructable there are two videos of it in action.
Step 1What you need
To make this project yourself you need the following items:
  • Two UV leds
  • One red led
  • One PIC12F675 microcontroller
  • Three 120 ohm resistors
  • One diode
  • Two light bulbs, one should have clear glass
  • Two strong small rare earth magnets
  • Two small screws
  • A small piece of flat plastic
  • A box
Then you need some tools and other equipment like:
  • Some tiny wires
  • Soldering iron and solder
  • Wirecutter
  • Hotglue or epoxy
  • A PIC programmer
  • Clean water
  • A highlighter pen
34 comments
Dec 3, 2011. 12:54 PMfsfshsyhh says:
Can you help me please? i want to have LED lamps in serial
power supply 3V
forward voltage 3.2-3.4
20mA
How many leds can i light up with 3V? Do i need a resistor for that, and how many OHM? Im a really beginner and i need help.
Nov 27, 2011. 6:43 PMnodoubtman says:
i used a 1n4148 diode, only one led light up :( please help;. .me
thanks!
CYa!
Apr 11, 2011. 6:23 AMstone820319 says:
Yes.it's really cool. why dont use 5800-6500K CT to make the CRI much higher?
Aug 22, 2009. 7:08 PMsquawker says:
Very Cool! Could you use this as the primary light source for a room? That would be an awesome prank. Change the light bulb in the room to one of these. Add an ultra-sound generator at just the right frequency. Finish with stacks of dry ice hidden under all the furniture. That has to freak out someone. OMG I'm going to do that and post an instructable on it. I wont forget to give you a mention Mat. Thanks
Mar 20, 2008. 8:47 AMArtificial Intelligence says:
Very cool. What is the best way to remove the cement from the screw base of the bulb.
Jun 25, 2009. 1:55 PMYokel says:
Isopropanol Alcohol / Rubbing alcohol will dissolve it.
Jun 28, 2009. 1:50 AMArtificial Intelligence says:
Okay. Thanks.
Apr 23, 2009. 9:15 AM12V says:
is this suitable with a pic 12f629 or 16f627(may need different code) or should i just buy one?
May 9, 2008. 6:41 AMYokel says:
A little tip. The 'dark glassy stuff' and the 'cement' is (AFAIK) shellack. Soaking in it IPA (isopropanol) should dissolve it. Nice instructable!
Feb 16, 2008. 2:11 AMPrometheus says:
A quick and quiet suggestion: Pure antifreeze solution (automotive) is highly fluorescent, and could be useful for this project. Some may have noticed that it seems to have an eerie "glow" on it's own in plain sunlight, but is highly reactive to "blacklight". The effect might be more desireable. Some food for thought....
Apr 18, 2008. 10:16 PMCaspar says:
Fluoroscein is the dye in antifreeze which look yellow, fluoresces green. Also in spirit levels, or just buy it. One gram should last you a lifetime. It's a red powder, not expensive. I still have 100 g I bought 40 years ago. Yes tonic water glows blueish, I think. Maybe the quinine in it...
Feb 16, 2008. 4:00 AMPrometheus says:
Extraordinarily so, it is.... You should be able to find it in any auto supply store, regardless of your temperate region, as it is an ideal for all conditions despite local freezing points, even in Hawaii, for more than it's temperate qualities, it is a water-pump lubricant. Green antifreeze should be available everywhere, and being a hawaii local, it is still available there, where minimum temps dip as low as 65F at the coldest (at least on Oahu, but it is a typical range throughout the islands and all other tropical regions). Antifreeze serves also as a better coolant than water alone for cars no matter what the ambient, so it should be widely available anywhere. Just ask your local auto parts supplier. Dilution will lessen the effect, so I suggest a plastic that is immune to a nearly pure ethylene glycol content, such as those labeled "HDPE", or many other poly-ethylenes for a transparent globe....
Apr 8, 2008. 7:09 AMblckscab says:
The Project that this one was based on only had 2 LEDs in it, so how would the schematic of looked with the extra UV LED taken away?
Hope that makes sense =P
Great Instructable by the way
Feb 11, 2008. 8:45 PMqdogg says:
I've cast a large 4" ball using the resin. You just go easy on the catalyst. If it gets too hot it'll crack. I used a big glass christmas ornament for a mold & it didn't crack so I think a bulb would be safe. You want to make sure you're using casting resin & not laminating resin.
Feb 8, 2008. 1:09 PMqdogg says:
You could try polyester resin instead of RTV. You just catalyze it & it gets hard in a few hours & you can mix in dye. However, you'll need a dye that isn't water based because it won't mix w/ the plastic.
Feb 10, 2008. 1:00 AMWoodWinds says:
(removed by author or community request)
Feb 7, 2008. 7:02 PMRob K says:
The UV LEDS work well for it.
Feb 8, 2008. 1:16 PMRob K says:
Maybe a little bit of laundry detergent. That made one of my glowing bottles cloudier. The red/orange one has it in it and the green bawls bottle has the liquid from an entire highlighter in it with a bamboo plant.
Feb 8, 2008. 7:39 AMWoodWinds says:
Feb 8, 2008. 11:01 AMMalaclypse says:
You may also want to look into UV Reactive powders and paints from www.glowinc.com I believe they make water soluble powders that would make this effect even more pronounced.
Feb 8, 2008. 1:57 AMLo-couk says:
Nice.. But what happens when some idiot puts it into a 240 Volt lamp? I think to be on the safe side of things, the screw should be packed out so it won't fit at all, or tape put around it.
Feb 7, 2008. 11:50 PMcsf0137 says:
ROTFL the question is WHY? %-) (a new thanatologic tool)
Feb 7, 2008. 12:48 PMBongmaster says:
haha nice :)
Feb 7, 2008. 3:35 PMdarkmuskrat says:
totally awesome, and I love the haruhi pic Bongmaster :P
Feb 7, 2008. 11:28 PMBongmaster says:
Haruhi rox :)
Feb 7, 2008. 3:03 PMGorillazMiko says:
At first I thought it was a dumb idea because I didn't know it would light up. But wow, really awesome idea! I look forward to trying it out.
Feb 7, 2008. 12:54 PMTh3H4rRy says:
That is pretty frickin sweet, I like
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:matseng
Swedish expat living now living in Malaysia after spending some years working in Dubai.
