The Spooky Tesla Spirit Radio and Mrfixitrick are now featured in a PC game called "Tesla". Monsters and bats are battled, while helping Mrfixitrick find the seven parts of the Spooky Tesla Spirit Radio. Intriguing background music. From GODD Games at: www.goddgames.com/tesla.html
Have a look at the Crystal Quantum Radio devices of EJ Gold that helped inspire this instructable: http://www.yoyodyneindustries.com/
"My first observations positively terrified me as there was present in them something mysterious, not to say supernatural, and I was alone in my laboratory at night"
- Nikola Tesla, 1901 article "Talking With The Planets"
The Spooky Tesla Spirit Radio is more than just a crystal radio circuit in a jam-jar. It's a sound maker that plugs in to a computer, and makes awesome spooky sounds by responding to electromagnetic fields or light sources in real time.
Athough Tesla used different parts, this radio's basic L-C (Inductor-Capacitor) circuit uses a similar schematic to what Tesla experimented with in his early days. The versatile 1N34A crystal germanium diode used here, substitutes for the tricky rotating nickel detectors and sensitive relays, used by Tesla in the late 1800's.
You can listen to AM broadcasts with this radio, but it was made to have fun with in other ways. (Besides, AM radio wasn't exactly what Nikola Tesla was interested in...in fact, he believed it was a waste of energy to transmit and receive Hertzian waves!)
By using a program like Audio Hyjack Pro (Mac), the radio's output is tweaked at the computer to give some great real-time sound effects...and you can record them at the same time.
In the following accompanying movies, I show how the Spooky Tesla Spirit Radio reacts to lightning, radio frequencies, the light spectrum, the computer screen, RF pulses, electromagnetic fields and more!
In the following video, the Spooky Tesla Spirit Radio is used to give voice to a Mac Hyperspace screensaver! The simple crystal circuit is apparently sensitive to the screen synchronization RF frequencies, and so it provides awesome background sounds...check it out:
The next movie shows "Spooky", the radio, beside a Dancing Ghost homopolar motor. The motor emits electromagnetic waves that are picked up by Spooky's antenna coils, and we hear the results translated through computer software in real time...spooky!!
Here's a movie of the action in the new PC game "Tesla", featuring the Spooky Tesla Spirit Radio;
Remove these ads by
Signing UpStep 1Parts List And Schematic Diagram
1- Small Jam Jar, (Mason Jar) with large mouth
1- 3 1/4 inch dia Plexiglas (or polycarbonate) cover lid, 1/8 inch thick
1- C1 - 60/160 pf Variable Capacitor (ComtrolAuto #VAR160-1)
1- Extension Shaft and Knob for above (ComtrolAuto #ExtKnob-1)
1- L1 - 680 uh Ferrite Loopstick Antenna (ComtrolAuto #LSA680-1)
1- D1 - Germanium 1N34A Diode (*Allied Stock#: 935-0301) $2.16 ea
1- C2 - .001uf Capacitor (marked 102) (*Allied Stock#: 507-0822) $.21 ea
1- R1 - 47k Resistor (*Allied Stock#: 296-6641) $.05 ea
1- Chassis Banana Jack Red - (*Allied Stock#: 528-0158) $.53 ea
1- Chassis Banana Jack Black - (*Allied Stock#: 528-0159) $.53 ea
2 - (or more for each antenna) Banana Plug (*Allied Stock#: 528-0302) $1.21
2 -3.5 mm Mono Chassis Jack (*Allied Stock#: 932-0260) $1.16
a few inches of 20 gauge hook-up wire
solder
1- Audio Patch Cord, 1/8 inch plug ends
Total Cost less than $30.
Note1: Most of the above crystal radio parts are available in kit #SC-Kit-1 from ComtrolAuto
Note2:Complete crystal spirit radios that can be adapted are available from EJ Gold at YoyodyneIndustries.
Note3: For Each Spiral Pancake Antenna,
6 feet of #14 gauge solid copper wire
Banana Plug
Note4: For the Football Style Antenna,
4 feet #10 gauge solid copper wire.
40 feet of #30 gauge coated magnet wire.
Heavy Paper
Scotch Tape
Hot Glue
SuperGlue
Banana Plug
Tools
Needlenose pliers
Wire Cutter
Soldering iron
Computer w/ Audio Hijack audio software (Mac), or equivalent
Crystal radio parts and kits available at http://comtrolauto.com/
Where is your definition of "radiant energy", and what real and working radiant energy device do you refer to?
I am studying how to step this up to get more amperage as well as volts so I can possibly build a device that provides voltage without the use of batteries or any other form of man-made voltage.
I already know that if I connect 2 of these circuits together that it will double the output.
I am trying to find plans on a suitable antenna that will harness energy waves such as your antenna, for input of the energy I need.
Tesla also notes that the best in insulation (mica in his time) must be used for the antenna because the slow accumulation of power from such a set-up might get bled off otherwise. A good ground is also very important.
There might be some kind of scalar antenna that will work for you, as new ideas are coming out regularly.
this 1 s awesome...but can i know wat is the software u used..???
http://xhttp://www.rogueamoeba.com/audiohijackpro/
If you have a PC, you can try "Audio Mulch" at
http://www.audiomulch.com/
Is there a circuit you have seen for converting Tesla coil output to music/voice ?
The Mac with Audio Hijack acts as both an amplifier, and as a pitch (frequency) changer in real time. This enables one to hear what would normally be static, for example, as enhanced sounds with deep texture and ambiance.
Signals we might not normally hear get amplified and "translated" by the software. This requires an extreme gain (volume) increase and a shift in frequency, otherwise the subtle sounds are lost.
I needed it for sound effects for a horror movie I'm working on.
Any suggestions what mods I can implement to achieve the "spooky" effects?
Thank you!
First, are you using the Audio Hijack Pro software for Mac OSX, or Audio Mulch for PC? Audio Hijack works really well to alter sounds. The AUPitch control is one easy way of doing that. Even a strong broadcast can be made alien-sounding.
-My custom patch for Audio Hijack is here: https://files.me.com/mrfixitrick/6axuh4
-My patch for Audio Mulch is here: https://files.me.com/mrfixitrick/0f04x2
Second, the radio you have made happens to be overwhelmed by strong local stations. You need to be able to tune BETWEEN stations if possible. When you turn the variable capacitor do you hear only strong stations? Is there any place on the dial where there is not a station?
-You can try adding or removing a few coils from the 10-coil winding that goes over the induction coil.
-If necessary, you can "re-tune" the radio to to other frequencies by using an antenna induction coil that has taps for different frequencies.
-A variable capacitor with more range will help too.
Some effects are done by resonance with the induction coil, such as running a drill close to it will produce a sound. Some effects are done with light played on the diode. The antenna is less necessary in those cases, and so it could be shorted with a piece of wire to ground, which should stop the reception of local stations. Or, try removing the antenna altogether for those type of effects!
I will try all the suggestions and report back!
PS Trying to use both Mac and PC.
PS 1 These links don't work anymore, by the way:
Otherwise, to get the sounds that I got, you need to try what I suggest with the crystal circuit and a computer. A PC computer with the program AudioMulch can also be used, but it doesn't work so well as a Mac and Audio Hijack.
For my browser, http://comtrolauto.com does an automatic referral to Scott's electronic page here: http://www.angelfire.com/electronic2/index1/index.html
the weird part was that it didn't sound like the mother of the korean family that lives next door, so i don't know how far off the the signal came from.
please advise?
There seems to be three basic styles...
1.) Wind the coil starting from one end and right through to the other end, all one piece of wire. that will give a connection point at each end of the coil.
2.) Wire one end clockwise and the other anti-clockwise, join them in the middle.
3.) Same as 2 above, but don't join the wires in the middle.
The original Tesla football coil used high voltage to activate it, so the purpose here as a crystal radio antenna is different...therefor, there's certainly room for improvisation.
Besides, by experimenting, you may come up with something interesting that has been overlooked!
all the best!
can I use 2,5mm or 2,65mm also the wire is coated...also unable to get uncoated!
14 guage I am able to get 1.6 mm only
much appreciated!
Then I made a form using 2 of 4 inch diameter round pieces of clear 1/4 inch polycarbonate plate. Drilled a 1/4 inch hole in the middle where I inserted a bolt, with nut and washers.
Bolt the two halves of the form together with the bolt after beginning to wind on TWO pieces of stripped 14 gage wire about 5 to 6 feet long.
Leave a gap between the two plates equal to the exact wire thickness, and then wind the two wires around the bolt simultaneously. When finished winding, you are left with two intertwining perfect coils that can be removed after separating the plastic plates.
Hope that helps!
Would you happen to have any images that show the plates you used to coll the pancake antennas?
Thanks!
Two wires are used, as one is the spacer for the other. Then two antennas can be removed from the form when finished winding and then separated.
Or they can be wound in a Bi-filar way, and then remain together.
The completed antenna or coil can either be left in the form, or set loose.
