3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Squintasaurus: cybernetic dynamically adjustable vision enhancement system
I can't see things very well at a distance. I used to wear classes, then contact lenses, then nothing. I hadn't worn any corrective lenses for years because glasses were annoying and my contact lenses were messing up my eyes. One day I was thinking about the reason for near-sightedness and I figured that if it's caused by an inability of the eye's lenses to flatten out, then maybe I could physically assist them in some way instead of just optically correcting for the problem like 'corrective lenses' do. Then after trying some things I realized that I could pull back back on the skin at the sides of my eyes and this seemed to do the trick. Since then I've been in several seminars in which I successfully used this trick to be able to read the screen or chalkboard that was too far away for me to otherwise make out clearly. So I decided to make a simple device to do this for me. What I made probably wouldn't be something that most people would want to wear in public, but a professionally made, miniaturized version of such a device might have more widespread appeal, and it was fun to make and test in any case.
Note: Squinting is thought to work by decreasing the amount of light entering the eye as well as by slightly flattening the eye's cornea. The cornea is a lens of the eye that is responsible for a majority of the eye's focusing power. If one squints one can notice a decrease in the field of vision indicating a decrease in eye's aperture. However, when pulling at the eyelid corners with your fingers you will notice an enhancement of distance vision greater than that achievable by squinting, and without any noticeable decrease in field of vision. So it seems that this system works more by flattening the cornea than it does by decreasing the eye's aperture. A final possibility for how this system works is related to the eye's length: In near sighted people light from distant objects converges slightly in front of the retina (the part of your eye that actually detects the incoming light and sends the information to your brain). Using this system the pulling back on the eyelids may be compressing the eye slightly, thereby allowing the convergence of light rays to occur further back in the eye: at the retina, allowing clearer vision of the distant objects.
Step 1Get the linear actuator
you'll need a pretty strong linear actuator to be able to pull your skin enough to have the desired effect. I remembered that CD players had nice worm gear motors in them to move the laser back and forth across the CD, so I looked through my junk pile and found an old CD walkman. I tore it apart using screwdrivers etc. and took out the linear actuator assembly, this will look different depending on the CD player but it's easy to identify if you know what you're looking for. I didn't take photos of this part so you'll have to look at the photos I got from wikipedia (http://en.wikipedia.org/wiki/CD_Walkman, http://en.wikipedia.org/wiki/Compact_Disc_player).
= The first photo shows a portable CD player, you could also take apart a non-portable CD player but those are usually a little harder to take apart.
= The second photo show the inside of a CD player. The black region on the green board on the left is what you're after, it has all the necessary motors and gears attached.
= The third photo shows this same mechanism from the underside, showing the motors and gears. You do not need to disassemble this mechanism, you will use it as is. All you need to cut are the wires leading to the rectangular motor (as noted on the photo).
Looking at the third photo: We'll be interfacing with the rectangular motor which is connected to the worm gear which is connected to the laser lense. The laser lense gets moved linearly, up and down along the worm gear. A 'worm gear' is the best way to allow low torque motors (such as the small rectangular one in the photo) to be used in high torque applications (like this one), but some cheaper CD players won't use worm gears. These alternate gear configurations will also work ok for this application.
46 comments
1-40 of 46next »
Mar 14, 2012. 6:47 AMskrubol says:
So you're using NPN transistors for all 4? With that H-bridge design, you'll get a bit of a voltage drop across the high-side transistors.
Probably not an issue for driving a tiny motor like that though as long as you use oversized transistors.
Mar 6, 2012. 11:35 AMlove4pds says:
how about the minimally invasive face lift product? Useing it where the tape is under the skin?
http://www.quickliftmd.com/
Mar 1, 2012. 6:51 AMFik says:
I can't believe no one has made a Borg reference
Feb 26, 2012. 1:46 PMatterack833 says:
also how do you get the tape to hold? what kind of tape is it
Feb 29, 2012. 12:58 AMw0ot! says:
You could also use Breathe-Rite® strips.
Feb 28, 2012. 7:27 PMbeff50 says:
seriously, your eyes are not something you should mess with. we wear corrective lenses to prevent eyestrain, we wear polarized sunglasses to prevent cataracts, and we don't wear eye skin stretchers as to not cause astigmatism and possible retina damage. more then likely your ophthalmologist will have an entire barnyard if he finds out about this device. it could make your eyesight worse in the long-run.
Feb 26, 2012. 10:59 PMlperkins says:
I would be hesitant to use this system for any prolonged period of time. My ophthalmologist is very chatty and likes to discuss his research. One of his projects is assessing the correlation between squinting and the development of astigmatism. Basically, if you don't flatten your cornea evenly, it will cause it to deform and no longer be a perfect dome, making it even harder for your eyes to focus properly. On top of that, pulling on your skin like that is likely to give you the oddest-looking set of wrinkles when you get older.
Feb 27, 2012. 8:43 AMbpark1000 says:
Hard contacts force the cornea to take their shape. That's how most cases of astigmatism are corrected by contacts. (Most of the refraction occurs at the cornea surface. Most astigmatism is due to the cornea not being spherical.) Soft lenses conform to the cornea, and cannot correct astigmatism unless they are weighted to prevent rotation.
Want another way to correct nearsightedness? Ride in the leading car of a roller coaster and look straight forward! The air blast flattens the cornea. It corrected my 3 diopters of nearsightedness on the fast parts of the ride.
Feb 26, 2012. 6:33 PMbpark1000 says:
This device does correct nearsightedness, but I suspect it also introduces astigmatism when activated, as it is pulling outward, but not up/down. Have you tested your refraction when it's activated? You can do that with a handful of diopter lenses from Superopticalsystems.com ($0.75 each) a white wax candle, and a 5 mW green laser pointer. Set the pointer shooting into the side of the candle (stable on a table). The candle will glow green. View from 20 feet away while being still. You will see a graininess to the light. If you move slightly left/right, the grains will shift. If you are nearsighted, the grain motion will oppose your motion, if farsighted, the grain motion will follow.  With the device activated, look through diopter lenses (-0.25, -0.5, -.075, etc.) until you find the one that stops the grain motion.  That is your correction.  Repeat the test, but move up/down instead.  I'll bet you find you need a different lens to correct for the up/down test.  The difference between the 2 lenses is your astigmatism.
Another question: would prolonged pressure raise the eyeball pressure, and damage the retina?
Feb 26, 2012. 9:22 PMgreatpanda says:
FWIW, William H Bates wrote a book on natural vision exercises nearly a hundred years ago, it's a free pdf online as the copyright has run out. It takes time and dedication once you're already near/far sighted, but Meir Schneider is one of the most famous of cases, went from blind (only seeing shadows across his vision in full sun) to being awarded his driver's license in CA with no restrictions.
Feb 27, 2012. 2:00 AMnwlaurie says:
Aldous Huxley (Brave New World) used the Bates Metod and wrote a book about it called (IIRC) The Art of Seeing.
Feb 25, 2012. 4:06 PMtinker234 says:
i like the concept but for me i was wondering about how to make something that willlt ake normal vison and bring it to super natural levels
Feb 26, 2012. 7:08 PMtinker234 says:
or maybe pepole with less than perfect vison to see with 20/20 or add magnfining glasses for diffrent lenses viewing using a sevro
Feb 26, 2012. 6:27 PMlumi3005 says:
Cool idea but I wonder how to improve the performance.
How does the idea sounds to hook that up to a microcontroller, combined with a distance sensor (and maybe a laser pointer to aim the target) for an automatically focusing?
Feb 26, 2012. 5:34 PMbstott says:
Pretty geeky cool. Now, will your grades get better and will you get a raise? Testing, testing, testing..... :-)
Feb 26, 2012. 2:54 PMElectorials says:
interesting! :o
Feb 26, 2012. 2:52 PMunlearny says:
Nice idea!  You may not know, but Aldus Huxley (Brave New World) wrote a book on eye exercises to improve vision. He was almost blind from a life of writing and reading in the dark to flickering oil lamps.  You may want to look it over for future machines!
Feb 26, 2012. 2:47 PMPattymouth says:
I love that you said, "glasses were annoying" and then created a big thing you wear on your head and something with batteries that you have to strap onto your hand. I don't know if you could market these for many of us women (unless you add some glitter?), but it's a fascinating tool. You people are smart!
ok dont mind me but i cant help but make a racist comment here , activate Chinese vision (or chink vision , it rolls better but its more racist sorry)
Feb 26, 2012. 12:08 PMturiddhu says:
in an emergency if you lose or break your eyeglasses maybe you could do as i did: cut out of cardboard a pair of eyeglasses measured to fit your eyes,bend back the clasps that support the eyeglasses on the ears,then proceed with a needle to make a pinhole from the inside out, right on the spot where the pupils are ,you can make them bigger or smaller depending on whats better for you just by using a smaller or bigger needle. you may have to cut out a few until you make the right one but i found out that it works for me as i was able to watch tv with them,also for your protection use the needles definitely away from the eyes.
Feb 26, 2012. 10:03 AMgearhead1214 says:
that looks painful
Feb 26, 2012. 7:52 AMsitearm says:
@Leevonk; You are The Visionator! : ) Site
Feb 25, 2012. 3:42 PMXenonJohn says:
One more suggestion perhaps:
If you want a product that sticks to skin tightly over a small contact area consider using half a "breathe-right" strip at side of each eye.
These have a sprung ? metallic centre section you could attach your mechanism to and are designed to hold your nostrils open to reduce snoring. I have seen some athletes use them too. To work they have to be very sticky and not come unstuck due to the spring effect, so might be good for your application. Also the adhesive is already licensed for use on skin.
Example:
http://www.superliving.co.uk/index.php?option=com_virtuemart&category_id=19&flypage=flypage.tpl&manufacturer_id=77&page=shop.product_details&product_id=1845&Itemid=45&vmcchk=1&Itemid=45
Feb 25, 2012. 3:29 PMXenonJohn says:
I wonder if you had thought about trying the principle of air muscles These are a length of rubber tube encased in such a way that when you add compressed air, they shorten.
There are probably none small enough for what you want but the principle might be quite neat as minimal moving parts near your eyes, control unit of some sort in your shirt pocket.
Great idea.
John
Feb 22, 2012. 10:58 PMmrwolfe says:
Freaky instructable, love it! Won't work for me though becaue I am very myopic (not sure about "short sighted" - makes me sound a bit conservative!). Squinting stopped working for me years ago as well.
Just as an aside, the way squinting works is to reduce the effective aperature of your eye. As any photographer knows, when you stop down the aperature, you make the aperature small, which increases the depth of field. This means that objects are in focus over a larger range of distances. Conversely, opening the aperature up reduces the depth of field, which allows a photographer to take a picture of a persons face, for example, with everything in front and behind out of focus.
A camera obscura (pinhole camera) works on the same principle, but with a very small hole as the aperature.
Feb 21, 2012. 9:53 AMmh76dk says:
I realise that this is 99% done "just because" so I will just comment on the last 1%.
I am not sure I see how this is a better (in any other way than "much more fun to do") solution than glasses - and it may also have some skin/flesh-related sideeffects (strain from being pulled back often/for very long time, tape-rash(?))
I would also think the tape sticking part is very individual (as our skin is different, dryness, sweatyness, etc)
When that is said (and I could be wrong :), for what it is, it is quite an interresting project.
Feb 22, 2012. 8:13 PMthe cat expert says:
Yes, and if you have to look at something close-up and then something far away (i.e. a child writing down what the teacher is writing on the board while in class) it would be pretty annoying if you have to take off your glasses every few seconds as to not harm your long-term vision.
Feb 22, 2012. 8:34 PMmh76dk says:
That is a very good point.
Feb 22, 2012. 11:27 AMmh76dk says:
I just thought I would bring up a few things worth considering - just in case you had not.
The one thing regarding this vs. glasses is that glasses seem to me to be less intrusive and also very portable (taking them off also turns them off - so to speak).
Having said that. I do not need eye correction (or rather, I might need it, but I dont have/use it) so I am not so familiar with the issues they might have.
Good luck with the improved version!
Feb 22, 2012. 2:59 PMmh76dk says:
But will your system not require a carrying case too? it will likely also get annoying wearing it all the time. (I hope this does not come across as negatively as I make it sound - I really do like the idea/solution)
Feb 29, 2012. 1:03 AMw0ot! says:
Instead of putting this on your eyes, I think it would make a bang-up steam punk torture device to force ones victim to smile.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
